Headlight replacement
E55AMG, Lexus ES350, Lexus LS460, AudiA6
Hello gentleman, I have a 2006 E55 which needs the yellow / hazy headlights replaced. Can anyone recommend a web site where I can find replacements. They are HID, self leveling. I don't care about the leveling, and can replace with either HID or LED. All I can find is replacements for original halogen head lights
thank you in advance.
FCP Euro. These may or may not be what you need.
Left side.
https://www.fcpeuro.com/products/mer...lla-2118202361
Right side.
https://www.fcpeuro.com/products/mer...bly-2118202461
Left side.
Right side.
Here is something I’ve done several times with good results.
https://mbworld.org/forums/w211-amg/...eadlights.html
J R (11-04-2023)
https://mbworld.org/forums/w211-amg/...rome-swap.html
Extra notes
1. if you resolve with non active lights you will need to code them out
2. if you want new active lights like I went with, getting them can be hard. Many will list active but will come as reg HID
3. any led bulbs you swap in vs staying HID will not perform well. However you can make HID perform like LED as you can see in my thread vs the LED on my G.
don't forget that not only do lens's need replacement or polishing, that also reflectors may have their foil burned off. lenses are available through various places online. haven't tried replacing to see how difficult it would be. if not too difficult, replacement of lens will always be clearer than polishing due to any micro divots from rock chips you may have.
The old lenses were discolored on the inside as well as the outside. No amount of polishing was going to fix that.
eightysixtuned (11-06-2023)
Replace the lower fogs while you're at it. Replaced mine at 44K miles, made the front end look brand new - eBay.
Here's the thread w photos:
Replacing fog lights and bulbs... - MBWorld.org Forums
Or, if only swapping bc lenses are hazed or yellowed, try using the wet sand/spray method I’ve been doing on my e39, and now E55. Requires a little time and elbow grease, but results are only topped by buying new - imo. I considered doing the heated outer lens
swap method, but feared an imperfect seal and moisture getting in…. I use 3M wet/dry sandpaper (320* 400 600 & 1000) and SprayMax 2 Headlight clear. SprayMax is a professional grade two part, acrylic spray that includes UV protection and dries very hard, yet retains a bit of flex to account for seasonal temp changes. Follow directions on their website for superior results. First pull lenses out of the car and clean with denatured alcohol. *(Depending on how crapped out the lenses are and if there are failed layers of previous spray clear, start with 320 grit and aim to just remove previous clear coats or flaws.) Otherwise, start out with 400grit. I cut the sandpaper into four pieces and fold each piece in half to work one lens only then get a new piece (or sooner depending on your situation). Use a spray bottle of water and keep the sandpaper and surface of the lens wet. Sand in the long direction of your lenses, or as in case of the E55, a sort of circular motion. You should spend about 10 min per grit, per lens (this is the elbow grease part…). You’re looking for a uniformly smoothed and hazed over appearance after each grit. Dry the lens and take a look once in a while and check your work. Redo spots that aren’t smoothed and or give the lens an overall hazy and smooth look. Proceed thru the 400-600-1000 grits until you’re happy with results. Then rinse and dry them, wipe with a tack rag (Home Depot or any paint store) and clean with soft cotton cloth and denatured alcohol (if in California, can use rubbing alcohol since denatured is on the sh*t list). Then mask everything beyond the edge of each lens with 3M blue masking tape and newspaper to protect from overspray. Spray in well ventilated area (outside preferred) at temp above 65° and wear a respirator bc the fumes of this stuff are nasty. The instructions say to put 2 coats, but I’ve been doing 3, just because. I start with one light pass, wait 10 minutes then 2 more medium passes, 10 minutes apart. Wait at least 3 hrs before removing masking tape, but not more than 12hrs. Let dry a day and don’t wash or go over 100mph 😜for a week or so…. I’ve done 3 of my cars this way, and a friend’s son’s car and they’re all still looking great - at least at the 6 month mark.
https://www.spraymax.com/en-us/produ...oration-clear/
Not terrible, but less than great
Sanded, prepped, ready for spray
Drying after spray - big difference!
Like new!
Takes 10 yrs off
Sees and looks good…
Like new!
Takes 10 yrs off
The following 2 users liked this post by Eljefe71:
nd-photo.nl (11-17-2023),
tlambert (11-17-2023)
Nice job. They look great. I’ve done several like this and so far results have been good.
