Front License Plate Mount
Old Sep 19, 2015 | 12:14 AM
e63amgeee's Avatar
'12 E63 AMG, '04 E46 M3
Just got my first ticket. No front plate.
Big thanks to Ace and Jordan for the great info/solution from this throwback thread:
https://mbworld.org/forums/w212-amg/...ook-plate.html
Considering it was from 2014 though, I wanted to ask for more current advice. For those that purchased a vehicle with no front plate mount, what option did you go with? Based on that thread, along with searching online shops, I as well think the tow hook idea is best. Hoping some of you have found other quality tow hook mounts that I could compare/contrast before purchasing. Am also open to other forms of solutions as well!
Much appreciated and hoping you guys can save me from a second ticket soon!
Old Sep 19, 2015 | 07:51 AM
PeterUbers's Avatar
Honestly I think the oem front plate mount looks the best and I had it installed about a year ago and have no regrets
Old Sep 19, 2015 | 10:52 AM
dbldpr's Avatar
Veteran: Navy
Sorry to hear about ticket but usually if you bring in receipt that you bought bracket they will throw the ticket out.
Old Sep 19, 2015 | 07:38 PM
sdg1871's Avatar
2019 E63 S
I originally had a hide the plate under the bumper but it was way too low and it came off like four times in the space of about six months. So I gave in and screwed in the OEM bumper mount
Old Sep 19, 2015 | 08:56 PM
PeterUbers's Avatar
I read a few horror stories about those hideaway license plate mounts where at highway speeds they came off and either destroyed the underbody of the owners car for the car that was approaching the vehicle from behind !!
Old Sep 19, 2015 | 09:13 PM
sdg1871's Avatar
2019 E63 S
In my case it kept getting ripped out on driveways there just wasn't enough ground clearance. Even when I would go in sideways and at a crawl. After four them at $200 apiece I said **** it. I gave up on it and just mounted the plate.
Old Sep 20, 2015 | 08:47 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
I made myself a holder similar to this. https://mbworld.org/forums/w212-amg/...ml#post6101377
A local guy that fixes rims welded things together for me.
Attached Thumbnails Front License Plate Mount-20150831_164945.jpg   Front License Plate Mount-20150831_165027.jpg
Old Sep 21, 2015 | 11:49 AM
BrabusNYC's Avatar
2014 E63S
There is also a flip plate I have seen recently...It folds in so its not seen then flips out i guess when parking or pulled over. Not sure exactly how it works but im sure a lot of hardware.
Old Sep 21, 2015 | 12:54 PM
PeterUbers's Avatar
Things to consider with these alternative plate holders
- does it reduce ground clearance
- do highway speeds affect safety
- does it affect the parking sensors
- does it look better than the oem holder?
Old Sep 21, 2015 | 01:24 PM
Lenin's Avatar
I would also add:
- does it effect airflow from the front vents
- does it effect the view from the front parking camera
In my case, I only see some interference with my front parking camera view. I can't see the ground right below the plate. Not a big deal. I needed 3" between the plate and the bumper so that I can fit my hand to hook/un-hook the holder. Nothing else is effected. I have done multiple runs to NYC and at least 1K miles to the beach house at highway speeds and everything is fine. The plate didn't even move.
Old Sep 21, 2015 | 02:07 PM
PeterUbers's Avatar
Great points
Old Sep 21, 2015 | 08:08 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
What about getting a local print shop to copy and print the license plate on a vinyl type of material?--Just slap it on when you want it, and peel it off whenever you like and repeat. It will solve all the problems mentioned above.
Old Sep 21, 2015 | 09:58 PM
e63amgeee's Avatar
Great advice. Thanks for all the input!
Old Sep 21, 2015 | 10:00 PM
e63amgeee's Avatar
Originally Posted by Lenin
I would also add:
Thanks for the info. Will make sure to consider all this
Old Sep 21, 2015 | 10:04 PM
e63amgeee's Avatar
Will be purchasing a tow hook mount that I found online. If quality and functionality are both on par, I will post direct link onto this thread along with installed pictures.
Thanks again for all the input everyone. Cheers!
Old Sep 22, 2015 | 02:43 PM
HPMan's Avatar
2014 E63 S
+1. To each their own, but I prefer the look of the factory mount to any of these jerry-rigged methods. My $0.02.
Old Sep 22, 2015 | 04:40 PM
Lenin's Avatar
You didn't like my plate holder? Oh well. Drill away.
Old Sep 22, 2015 | 05:44 PM
HPMan's Avatar
2014 E63 S
I think yours looks fine, but I prefer the look of the OEM plate holder. I realize that not everybody shares my view. One concern I have with yours is that it will likely cause damage to the paint at the contact points (i.e. vibration from driving will scratch the clear coat).
Old Sep 22, 2015 | 07:08 PM
Lenin's Avatar
I'm not trying to convince anyone nor am I selling anything here. Just trying to answer the original question vs. just providing my $0.02. My front bumper is covered with Xpel and the inside of the holder mounts are covered with felt paper. So, the paint should be safe. And if somehow it is not, I will just cover it with the OEM license plate.
Old Sep 24, 2015 | 12:04 PM
TXE63's Avatar
'14 E63
I remember seeing one of those "James Bond" type front plate mounts years ago that concealed the plate via key fob under the bumper area but could be activated to pop up when needed.
Anyone know what company made those and if one could be made for our cars?
