E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Old Oct 31, 2024 | 02:22 PM
  #276
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by jcarsnz
Hi again Joe,
Could I please request instructions to remove/replace the Oil Drip Pan (A2730100162) for the W166 ML63?
VIN: WDC1660742A440774
Procedures attached. You may need more or less of these. So let me know if you need others.
Regards,
Joe
Old Dec 31, 2024 | 07:54 PM
  #277
JayGonz's Avatar
2015 E63S
Great information!
I’m new to the forum, but wanted to say that I’m gonna love getting to know this community. Sooooo much great info just in THIS thread…thank you GOD…😎😎😎
Old Dec 31, 2024 | 09:00 PM
  #278
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Regards,
Joe
Hi Joe,
Can you please post the procedure for spark plug installation for M157 application?
Old Jan 1, 2025 | 03:54 PM
  #279
san40's Avatar
2015 e63 wagon
Originally Posted by Faast
Hi Joe,
Lots of good details in the forum:
https://mbworld.org/forums/w212-amg/...ing-video.html
https://mbworld.org/forums/w212-amg/...8-biturbo.html
Old Jan 1, 2025 | 05:59 PM
  #280
Faast's Avatar
Thanks for the links but I am actually looking for factory installation procedure
Old Jan 1, 2025 | 07:08 PM
  #281
san40's Avatar
2015 e63 wagon
I got these M157 spark plug related docs somewhere on this forum
File Type: pdf
Old Jan 1, 2025 | 07:55 PM
  #282
Faast's Avatar
Attention PeterUbers
So no mention of any special procedure for Indexing besides using the factory plugs and the required torque number, right?
Should be up in sticky section---
Old Jul 13, 2025 | 02:13 PM
  #283
dustinN's Avatar
09E350, 07E63, 13CLS63
Hello Valvestud,
Do you have instruction to remove the front driver side headrest? IIf you do, can I please have it. Or anyone have it or know to remove it, please let me know. I
broke it myself. How stupid I was! Anyways, I saw some videos for the W12 but the last step for the 2 classes is not the same, The video for W212 does not have the 2 red circle as in my picture.
Old Jul 13, 2025 | 02:32 PM
  #284
dustinN's Avatar
Never mind. I didn't pull it up hard enough. Thanks.
Old Oct 26, 2025 | 02:34 PM
  #285
jongarcia's Avatar
2015 E63s AMG
Attached are many procedures to get you started. Let me know if you need others.
Regards,
Joe
Hey Joe, Can you post the torque Specs for the Axle Bolt as well as the torque specs for the two strut bolts that go to the knuckle. And can you tell me if either of these bolts need to have loctite? VIN IS WDDHF7GB1FB125321
Old Mar 27, 2026 | 05:27 PM
  #286
dustinN's Avatar
Hello all,
Do you have the procedure to replace the thermostat? I got P012800 error code. I regret not to replace it whenI changed the broken turbo coolant line. It's 4 or 5 years ago and I can't remember how to get there. I remember that turbo coolant lines are very easy to break.I hope I won't break them again this time.Thank you.
Vin: WDDLJ7EB3DA079389
Old Mar 27, 2026 | 07:53 PM
  #287
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Temp control test...
Originally Posted by dustinN
Hello all,
That code does points to engine temp issue, not specifically to an open thermostat.
Don't rush to replace your coolant Tstat until it is confirmed bad.
Reset the fault and let the ECU adapt to working with Summer heat.
You can test this easily by holding hot coolant hose after cold start... How soon does it beging warming up: 5, 10, 15, 20mn ??
Old Mar 28, 2026 | 09:46 AM
  #288
dustinN's Avatar
The fan runs at cold start. I dont remember seeing this before. Problem with coolant sensor?
Old Mar 28, 2026 | 09:50 AM
  #289
dustinN's Avatar
Oh, maybe its warm in the garage. Fan didnot run outside. Coolant was still cold.
Coolant hose warm after 5 minutes. Engine oil 130, water 195. It took 25 minutes for engine oil reach 176, white.
Old Mar 28, 2026 | 10:13 AM
  #290
dustinN's Avatar
Coolant was at mịn level. Add some, it seems like the engine warm up faster. I just cleared the code, will driver a few day and see. Thank you.
Old Mar 28, 2026 | 03:27 PM
  #291
Duplicating Fault Confirmed ?
Fan did not run outside. Coolant was still cold.
These observations confirm your coolant is warming up your oil through the heat exchanger. Under these conditions Oil was not removing pistons heat.
Your cooling circuit is forced to operate under harsher conditions that may shorten tstat life.
If the fault returns, it will be an indication the Tstat operation is getting marginal at controlling coolant temperature... normal wear & tear maintenance.
When Tstat sticks partially opened it hardly moves either way. Normal operation is smooth.
If the fault confirms under harsh conditions, it's best to service to prevent extreme heat issues. Heat must be well controlled within range.
If your have ECO feature... use sparingly.
Engine Cut Off multiplies heatsoaks from accumulated pistons heat. This creates extreme coolant pressures.
Old Apr 5, 2026 | 07:01 PM
  #292
Jtaveras13's Avatar
2015 e63s
Just need help finding this part number. Its a hose with a bracket thats screws into the top of engine right behind top pulley.
