Motor Mounts Done - Steering Rack Method and BoostedBenz Mount Review
-Unhook battery negative on passenger side engine compartment (you're working near the starter, don't neglect this!)
-Remove air boxes, engine upper and lower trim, rubber things under the air boxes etc. Get that engine nice and naked.
-Unplug Vacuum line that goes through first firewall on the passenger side rear, by the battery, it's bigger and the only one that passes through the metal (this will pinch lifting the motor if left plugged in)
-Remove front wheels
-Remove fasteners from front struts (lower mount bolts, electrical connectors to shock, brake sensor, and sway bar link nuts)
-Undo steering shaft coupler bolt and slide off coupler (marking it's alignment before)
-Remove steering rack bolts (2 main, 2 forward for the metal plate, and drivers side bushing bolt)
-Lower rack and secure with tie down strap or similar
-Loosen passenger side downpipe (2 bolts at front, brackets further back, crossmember in center of car, exhaust connection to resonator)
-Remove O2 sensors on this downpipe (don't bother with finding and unplugging connectors, just unscrew and be sure to wind them the other direction first before re-installing. Be VERY careful to not touch the end of the o2 sensor, or find something without any oils on it to cover and keep out of the way while you work)
-Now you can fully remove the downpipe and reach the rear lower bolt and upper bolt for that mount.
-Remove lower engine mount bolts and upper bolts, you can reach all of them now. Drivers side upper bolt needs a bunch of extensions and a swivel to get to, passenger side front bolt needs a stubby 13mm ratchet as the clearance is really tight there.
-Loosen bolts to transmission mount (leave crossmember in place).
-Pop out axle on passenger side using a pry bar from the channel where the steering rack was.
-Now the engine is loose, you can jack from the oil pan in the center to get the drivers side mount out.
-Once that is done (and new mount is in on that side - doesn't need to be fastened yet), move your jack to the passenger side further (by the diff) and jack up that side of the motor. Clearance is really tight here, keep an eye on stuff in the engine bay above as there is a cluster of vacuum hoses and plastic stuff near there. It comes out by the alternator and there is an oil line there too, but with enough clearance and movement it will come through. I think I had to use my pry bar by the diff too to kind of push the motor towards the drivers side, but it will come out. Also watch where the axle shaft is rubbing and catching as you don't want to scrape it up or split the boot.
Reinstallation is just the opposite, with a few notes:
-If you didn't secure your steering wheel, leave fastening the coupler as your last step before putting the belly pans back on. Mine had swung a full 180 so when I started it and put it into reverse, the reverse parking guide lines on the screen inside were turned despite the wheel being straight. A super easy fix, just annoying to have to rack again and take the coupler off and turn the steering shaft back over again.
-Popping the passenger axle back in - get one of the lower strut bolts in (not both) and you should be able to rock it and snap back into the diff pretty easily (rotate the brake rotor a little to make sure you're engaged in the spline correctly).
-You should replace the transmission mount, it's a few more bolts and will be as worn as our motor mounts.
-Get new lower strut bolt nuts, they are locking and the dealer gave me an updated style of nut. I'm sure every piece of MB literature says to replace every nut and bolt, but honestly I don't see a need on most of the others. I ended up pulling the struts out to replace the upper mounts and rubber to get rid of a creaking noise on turns (which worked!) so I also replaced the 6 upper strut mount bolts as they have blue loctite on them, as well as the locking nuts for the sway bar links which I also replaced.
BoostedBenz Mount review: Overall I am very pleased. There is more vibration through the steering wheel at idle than the stock mounts, but that doesn't bother me the least bit. The mounts were getting worn when I bought the car and it just always had a German muscle car feel to it which was probably due to 70k mile mounts...What's gone now is the 'bad' vibration feeling, one that continued at lower speeds until you got to cruise, and a sloppy drivetrain feeling. Everything now is tight, power seems faster to come on when tossing the car around tighter corners, everything is just super solid. It's not an S class, so a little NVH at idle is not a concern.
I will rate them a 4.5/5 because of one annoying issue - the heatshields prevent you from getting the bolts into the upper mount threads. It causes the engine cradle to sit about 1-2mm higher and you can't get the threads started. I didn't realize this until after getting everything in place, so I had to start all over re-jacking the motor and making enough space to pull the heatshields off and modify (see pics below). I had to cut the center circle out so the top of the mount sat flush with the engine cradle and then we were in business. It really doesn't detract from the heat shielding effectiveness, but I'd be really annoyed to have spent an extra $100-$150 for these only to have to cut them with kitchen scissors. Luckily I got them for free as part of a sale, so the only pain was noticing this when I did. I also had to email them to clarify thread pitch and got a response in about 10 minutes, so great customer service! I love that they are serviceable too. Yes, you use your factory bolts, but the coating on the threads makes it tough to go in which is why I wanted to ask them. I always find this a little unnerving but that's a big bolt to cross thread...just trust the initial start and carefully tighten with a good ratchet.
That's all, if anyone else is tackling this and has questions please post or reach out! The cheapest labor price I got from an independent was $1800 so this saves a lot to do yourself, and is a definite wear item in these cars. Happy wrenching!
Making room dropping the steering rack
Inner part on the left
Now a flush fit!
this!
how is the steering vibration with the new mounts? About to change my mounts next month and address front diff seepage
Edit: Once I got into it, I ended up needing both hands and didn't get pics like I wanted. Total fail on my part. However, I have much to add to this thread.
First things first: If any of the following statements apply to you, DO NOT ATTEMPT THIS METHOD:
1. You don't have access to a lift, high capacity Quick Jacks, or proper jackstands capable of raising the car 20inches or higher.
2. You lack access to a wide variety of tools and high capacity, high lift, precision jacks. Also recommend extra lift/jack pads if you're doing it on QuickJacks or high jackstands.
3. You are a novice mechanic or your first time trying to wrench on a car.
Doing the mounts this way is not impossible, but has a degree of difficulty that will get a novice into trouble quickly.
Both mounts will fight you getting the main mount bolt in. The trick to getting them in is to install both mounts with the mount base bolts loose first, then slightly lift the motor back up and install the the main bolt semi flush but not torqued, lower the motor and then torque all the mount base and main bolts down.
The passenger side mount will fight you you tooth and nail on install almost as much as on removal as described above. Reinstallation of that mount is not the exact reverse of install. To get the mount set, first get it in place WITHOUT installing the base bolts. bolts.incrementally lower the motor positioning the top main bolt hole in the motor and disregarding the base holes. As it gets lower, the mount base will naturally slide into position. Once it sets all the way down, lift the motor slightly to allow you to slight be able to move the base to adjust for the base holes, and hand install the base bolts with some slack left over.
Parting thoughts: If I were to do this again, would I choose the Kennyd or the Gindistiller method? If I had access to a lift taller than quickjacks, I'd recommend the Kennyd method as it takes a little less skill and is faster. If you don't, then the Gindistiller method is your best bet provided you're confident in your ability to do the job. I know exactly what I'd charge to correct a bad attempt at this method, and it's not cheap.
Is it any easier to replace the pcv valve once the pass. side downpipe is removed - this could be from the top anyway haven't dug into it ?
Also - in response to your last post, I would now add just replacing the right axle seal to your list. Mine is seeping now, probably got a small bit of debris in it during the job or a small cut, so I've got to redo that at some point.
Best of luck!
https://mbworld.org/forums/w212-amg/...ml#post8610762
You will need a special pass through socket to remove and replace the top strut bolt that holds the top spring retainer, or make one like I did.
I used the “death sticks” spring compressor - never again lol. I’m taking struts to a shop to swap springs from now on.
Edit oops if you are talking about just the three bolts that hold the strut in it will need the weird “E” reverse torx socket
