Park Button is Intermittently Working
Old Nov 3, 2024 | 03:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
RELIABLE DOORS + WINDOWS + KEYFOB...
Originally Posted by Jaybird123
Repeat with next module you want to make reliable.
Suggested are the 4x door modules aka DCU's.
+++ To fix powertrain timings:
You'll need to deal with CAN-C VIP'S when you're ready
How do I access DCUs? 😅
> DCU's Proverbial Cake-walk:
Start with 2 rear doors, passenger front then last the driver's door.
Worked on 1x at the time is suggested
​​​​​​You'll need to remove couple screws to drop the door plastic cover liner.
Then you'll get a small plastic enclosure with couple connectors waiting for your 5mn solder.
Very user friendly much-much easier than a sparkplug job with brital coil plastics. The door plastics never got overcooked.
> POSITIVE OUTCOMES:
-- The reliable DCU will positively turn around "battery drain while parked".
-- You'll notice your windows wind up faster under 14.4V and side mirrors blind spot warning sign glows much brighter.
-- You'll notice zero latency in doors remarquably unlocking and popping up all at once strongly.
> GRAND FINALE:
In addition the driver door button modules are all solderless for windows/mirrors and seat positions. An extra 15mn of fun.
The next installement is the EIS Ignition switch to complete saving battery while parked.
It will be good for 2 or 3 weeks instead of 2 or 3 days with MB factory stock setup.
Have a look here....
Old Nov 4, 2024 | 10:47 AM
PeterUbers's Avatar
Impressive
Old Feb 21, 2026 | 08:33 PM
Cls63samg's Avatar
Cls63 SAMG
So did the soldering fix the issue for you?
WELL I’LL BE DAMNED!! Woo hoo it is WORKING!
I will sincerely hope it continues working, but it was completely nonfunctional all last night and this morning. Just functioned 3x after reinstall
@CaliBenzDriver sincere thanks
