Oil pump solenoids
But guess what? No oil temp sensor on my S550. It's calculated. I have not done a test like shown above but based on the behavior of the display reading, I believe the model/calculation is fairly accurate. It is clearly NOT a made up number and is actually trying to model the actual oil temp based on engine load, rpm, external temp and coolant temp (because of the oil to coolant heat exchanger, and engine RPM dictates flow of each fluid through this heat exchanger so this can be easily modeled). If it was totally fake it would just warm up on a timer and wouldn't track coolant temp. To be clear when the thermostat would stick open, I could watch the coolant temp gauge drop. I would ALSO see this on the oil temp display. It's at least somewhat smart to drop after the engine warmed up (as opposed to a dummy timer or something).
I'll be going through this with my car one step at a time
I got an engine light that came on last week on my car that is just a generic code w/e that is called again ( i'm not at home to put the scan gun on the car ). I'm suspecting and hoping i'm wrong that oil is tripping one of the sensors from the cams
Eventually this should automatically get relearned with normal Rpm driving around 1750 where heat removal can become effective.
I'll be going through this with my car one step at a time https://www.youtube.com/watch?v=6JT-..._channel=Ginco
One of the rewards of improved engine control is normal heat management.
Currently your engine has extreme heat even in winter with easy driving.
> STOCK SETUP :
Laggy engine + confused gearbox + extreme heat
> STABLE SETUP:
Strong engine + nimble gearbox + cool engine
Given normal conditions engine timings will come under excellent ECU/TCU control.
> STOCK SETUP :
> STABLE SETUP:
Did anyone report the problem to MBUSA customer service? Did Mercedes recognize the mistake and get the responsibility for the repair (recall??!!!)
It's not exeptable on over $70000.00 car to have issues like that!
Choose the Disable related threads radio button and hit save changes.
MB is definitely not in business to compete with Lexus.
They carefully design and build cars to help sustain a thriving business. Luxury service is an essential part of the Mercedes ownership experience.
Please follow up with us about MB USA feedback. They have top specialist ressources on staff. Rest assured your request will be dispatched professionally.
Thank you.
++++ JUST REALIZED...
Defeating extreme heat means very positive things:
Cam sensors will stop leaking oil
It will stop "10k-oil-in-harness" lottery
Extreme heatsoaks will stop
long lived radiators and heat exchanger
I'm doing my first steps thanks to an error message P06DA00 (f) which is recorded under the MED177 section N3/10.
It's since 2000 miles for a total of 10 occurrences
I'm understanding that what is named by MB Xentry "Valve of the oil pump" seems to be the same part but other naming of "oil pump solenoid"
The full error message is "The actuation of the valve of the oil pump in the combustion engine has an electrical fault or open circuit"
On the basis of the xentry test section I was able to read the valve %. in different condition.
- 0% at initial warmup
- 0% when above 3500
- 0% when using "engine braking" to slowdown
- 45% when running between 800 and 3500
- 0% means that the full oil pressure is released
- 45% means half pressure (to reduce consumption)
- Value displayed is the signal sent by the ECU to the valve ?
In other words, could I trust the displayed xx% as the true position/flow and therefore consider that my valve is not defective or is the recommended test (listening the noise) the only way ?
It seems surprising that the voltage doesn't change whatever it is 0% or 45% - On the basis of the previous thread, if I wish to "desactivate/unplug it" it's better to do it after Oil pan cleaning / change
Thierry
Thierry
This is usually coined as "LUCKY CODE": you now have a natural MOD-1.
Initial engine improvements from better lube will be limited by the your choice of oil viscosity.
The solenoid PWM signal is used by the ECU to sense the coil current, not to actuate various pressure against the dual-rate single-stage pump return spring.
If you decide to get effective VVT positioning your engine will further benefit from stable voltage.
ALT-LIN without MOD-4 may register limited timing improvements.
Gas savings vs. oil pressure :
Power is produced more efficiently with less gas and less frictions.
MOD-4 uses less gas than stock by building better fuel map.
So, if you want to be sure you don't have a problem, I would actually disconnect the wire to the connector on the block (so it doesn't mysteriously start working again) and actually measure the oil pressure. There is a test port near the oil filter. If you have a copy of the WIS, look it up. Once satisfied that the solenoid is in the default, non-restricting position, plug in a dummy/sacrificial solenoid so you don't get the code. Again, this has been covered above.
Thierry
as there is no feedback sensor to verify that position.
But the ECM does monitor power consumption of the solenoid and if the driver in the ECM for oil solenoid powering..... get overloaded as in short circuit, ECM will declare DTC.
Open circuit of oil solenoid or its wiring will also produce DTC.
That zero volt you are getting maybe the result of open circuit .
However, that 2V limit voltage of oil pump is wrong, I do not know why Xentry software is "faulty" for that section. Mine is M276.820 engine.
The power delivered to Y130 oil pump solenoid is 12V but PWM pulsed.
Watch here :
A failed oil solenoid valve or its wiring, means the oil valve stop working, but in OPEN state and thus no more lowered oil pressure by ECM.....
However, if you want to confirm that the oil solenoid did not "die" in a semi-closed position, only mechanical oil pressure test can verify that.
Stuck semi-closed oil solenoid valve has happened, but rare. Master Tasos video has the rare sample of such failure.
That is a lot of "premium" information. I did my first research in the pdf hosted on this website and found a document explaining "howto measure oil pressure".
It took me more time than expected, believing that B42 xentry test was giving the ability to retrieve the pressure (as highlighted in the thread). Too bas, it is not the case for my 157.981 version (no oil pressure sensor).
I double checked the above xentry screen (which are normally designed for "TEST" and not for displaying value while driving.
If I press on the test RUN, it will close at 90% with a V value of 1
The provided explanation is brilliant. It's full of sense that potential defect will be detected by the lack or too high current intensity.
Being "an open circuit diagnostic", I guess that we could not directly "it's oil leaked in the connector".
Since I have discovered thanks to you, how the lack of pressure could cause potential issues, I'm systematically using the "engine braking" (which seems to fully open the valve).
Does it bring any value to plug an "on purpose external valve" to let the ECU believe that it is still operational or the fact that the ECU diagnoses the valve as defective doesn't impact the way that it is normally operating ?
One more time, thank you, thank you so much for your help and time to share all this valuable expertise.
