Oil pump solenoids
On my SL400, I've been disconnected just over a year and 9000 miles. On my 2014 C350, it's been a year and 6500 miles. Both cars run great!
I was using Mobil 1 0W-40 at the time I made the recordings. This is oil pressure measured from the oil pressure test port on the engine near the oil filter housing, per the WIS.
cheers
cheers
cheers
-- Actual oil pressure is hardly linked to timings and LTFT.
-- How can sticky oil have such incredible impact with performance ??
> Where we were:
-- Earlier we saw drafty rings cause timing jitter that cause misfires that cause lean fuel maps that cause laggy weak throttle response.
-- Better oiling help clean and seal rings that smooth out timings thus fuel map... great!
> So what is the limit to that?
-- The limit is worn out cylinders that can not seal. That type of genuine unbalance can not be turned around with wet rings... shocks!
> So what's the deal then?
-- Here I am going to argue that your best chance to not get stuck with lean misfire and weak fuel maps is to preserve cylinders from wearing near TDC.
> So what can we do ?
-- The old proven way that works is viscous film.
... not diet thin oil for turbos !!!
-- Slick cylinders save gas at the expense of... cylinders wear.
-- Wet cylinders film prevent metal contact carving grooves.
Our best interest for longevity is to prevent cylinder wear - Duh!
Mobil1 Supercar is an excellent answer to prevent wear.
Worned out engines can not regain much improved timings - Switch to W50 protection at your own pace.
What best protects the cylinder bores is both molecular SN/SP chemistry + viscous film.
Lower viscosities disable film resilience.
... that's not all new, right?
cheers
You hooked up with Master Tasos who crafted couple videos to answer your Q's
-- We started experimentions not knowing what we discovered later...
-- Back then most people were concerned about using normal oil pressure.
-- Nowadays we are cancelling lag with matched viscosity
I think Xentry shows some type of tracking of engine smoothness/jitter we are dealing - - Perhaps Master Surya can help us fish solid numbers straight from the ECU using Xentry ?
cheers
thanks you 3 especially as well as all the others that have contributed!!!!
what a powerful forum.
Many elements and efforts were contributed by a pool of savy team players.
MOD-0 Limited stock lubrication is amazin it even works...
Corrupted bottom fuel map appears as if our engines longevity is negatively impacted by reduced lube.
Our ECU controls are unable to manage marginal oiling rodeo well.
We can't extend the missing ECU logic to match the engine, so we match the engine to the ECU expectations!!
We can undo stock oil-game to restore missing engine driveability: MOD-4.
> You will positively gain reduced cylinder blow-by right away but dirty rings will still be stuck.
> VVT Positioning will be somewhat confused for about 2500.RPM.
> Do not expect ECU/TCU to start acting like nothing happened during the oil upgrade. It's still going to take a good 2 or 3kMi to sort out.
Engine response will be unsettled initially... don't gun it, specially the tranny is going to be "like a deer in the headlights" confused not knowing what to do.
> You can monitor express upgrade with numbers:
-- measure cylinder compressions
-- plot relative compressions
-- Then based on results, you decide when is safe to open up heavy loads!
Meaning no WOT for 3kMi since you ask me.
> You like fast-track results... I suggest you consider ESTER oils in 5w40; 0w50; 15w50 API-SP staying away from heavy ZDDP "racing formula" to preserve Lambda/Cats unless cutout.
Why not run the cleaner 0W40 SP formula longer until it gets dark (1500.Mi) then upgrade it to your selected target.
Result will be delivered by improved viscosity meaning no performance improvement in 0w40 ballpark.
Since I'm transitioning directly from M1 0W-40 SN @CaliBenzDriver has suggested I avoid WOT pulls for 3k miles, which I think is good advice.
First impressions: not much yet, only change I have observed is my oil temp was previously around 98C/208F after a half hour drive on a warm day, but seeing this now:
Early days I know... regardless, I will stick with 5W-50 for the added wear protection these engines deserve.
Notice how both heads rapidly quiet out in less than 50Mi from SP chemistry.
This week driving will not be better until the weekend or 500Mi... then VVT positioning and TCU will be zeroed-in and fuel map will replace the missing bottom RPM's with rich torque at 900.Rpm.
Don't push it while it's confused.
Normal short trips are best.
The Turbo fuel map performance will benefit transitioning from neutral/rich 1500.Rpm.
Meaning: solid throttle from 900.Rpm and up
+++ I am surprised to see oil cooler than water... (engine idled, not driven?)
+++ You did cleanup your bypass valve, right? (if not you can still do so after oil change).
+++ Reset the IC Trip-Counter to track miles since oil change
All the hard work by the aforementioned forum members are paid off and much much more!
Their product knowledge and expertise is greater than most salespersons and technicians and engineers at the dealership.
A forum is great because of the existence of such members, words cannot describe how thankful I am and please, again, allow me to express my greatest gratitude to all these members and please, everyone enjoy such prized gift from these members and enjoy them in good health!
