Oil pump solenoids
2014 E 63S
2014 E 63S
it’s an entertainment trolling on 🏳️🌈
😂😂😂😂 that sensitivity will be your demise one day my guy. Too much estrogen🏳️🌈 in men these day. What a shame.
salute to your research😉
Honestly, most of the articles touting mileage efficiency are marketing material….
It’s possible you may be interpreting efficiency as emissions, This paper is focused on efficiency as stated in the summary/conclusion below.
Though related, technically It’s not the same: you can see mileage is not the focus of that study but rather efficiency, mileage happens to be a byproduct.
Not a lot of fuel savings in their findings right? But rather power savings is the focus of this research second pic. 40-60% gains depending on pump configurations. Wow!
It’s important to keep in mind these are research papers that won’t always transfer to real world conditions.
These should be considered a guide NOT religion.
Over and out folks….
Good Luck!
@CaliBenzDriver I’ll post some replies to your questions, I’m not ignoring you, just have a lot of stuff going. I want to answer some of your questions with concise and detailed replies. keep an eye on your PM’s. It will be more productive at this point.
This place has a lot of different posters trying to pull discussions in different directions.
I feel you always put out informational and well thought out posts. And that’s appreciated by all.
kudos…
The valve stems love vaporized oil carbon deposits... helps 'em warm up faster.
Joke aside it help evaporate crankcase oil contaminants from combustion: gasoline + water.
Another good reason to dump oil near 5kMi Max.
How would we know? If the engine is designed for low pressure operation for 40ft lbs of torque 60 percent of the time, if we increase that load to 80ft lbs aren’t we the ones redesigning how this system is designed to operate. Aren’t we the ones ARTIFICIALLY increasing pressure? There are hundreds of post with people well in the 200k mark and no mods right?
How do we know with all the conjecture and no solid measurements.
Sorry maybe you can clarify this, not sure what you mean?
These engines do have some known weak spots but generally the lubricating subsystem (aside from the solenoid craziness) is not one of them. The oil pump and bottom end are probably capable of an easy 200k of driving time if not quite a bit more (again, if cylinders didn't score, or if rods didn't bend, the latter of which particularly has nothing to do with oil pressure). Over the span of 200,000 miles, the engine (and thus the oil pump) rotate somewhere between 300 million and 1 billion times, different on every car, and different load for every rotation for every car. Mercedes and every other automaker designs components for this and that's what I mean by factor of safety. I mean, using your rear defroster more frequently probably wears down your alternator brushes a little faster than the next guy: who, except an internet troll, would make a big fuss over this?? It doesn't matter, no one cares, it rounds to zero.
What would you think this is causing this Kev?
This is an old road racer trick to advance cam timing a few degrees. Nothing new here. Except we’re achieving this through oil pressure timing.
Normally downside of this is the loss of top end power. (Not a concern with the VVT here) and the propensity for detonation/pre-ignition…
As I said, I’m not here to convince anyone to do anything, just trying to present some solid engineering here.
You can easily google “advancing cam timing degrees detonation pre-ignition”
Theres a LOT of variables here and is this happening currently and detrimental to these motors?
F—— if I know, as I don’t have an engine Dyno and neither does anybody else here.
But the engineering says when you advance cam timing, the results are an improvement in bottom end performance but a higher probability of detonation/pre ignition….
When there is insufficient oil pressure at the cam adjuster, it is designed for the locking pin to insert (like for engine startup). If oil pressure falls below a threshold, the adjuster may sort of try to partially lock, or actually lock and then unlock, and this may be another explanation of why some adjusters experience high wear in this region. If so, unplugging the solenoid is beneficial to their longevity. I already established it is beneficial to their performance.
- WIS explanation for what the oil pressure control solenoid does and why it exists (fuel economy). Posted above somewhere.
- Logging of oil pressure before and after unplugging by a few members, with posted data, showing how much it decreases, under what conditions, and what the performance curve of the oil pump actually is when operating as a normal, single stage oil pump. Oil pressure generally tracks RPM, as it does with virtually every other internal combustion engine. Posted above or in Surya's thread(s).
- Significant anecdotal data that engines run smoother and are more responsive post unplugging. I will note some have said that didn't notice anything. But it is probably the vast majority. I don't think it's a placebo. I think some engines are just in a state of tune where decreasing oil pressure (when the solenoid is activated) doesn't impact anything and this is probably what Mercedes originally intended. But as the years and miles rack up, more and more of our engines deviate from this ideal mechanical state and probably really need oil pressure to work normally, not reduced sometimes. I don't know if anyone has logged VVT operation and proven that cam timing is more precise post unplugging. It is possible that someone has and I forgot. It's been a journey. It could be that there are other factors and Cali has spent a lot of time on those other possible factors. Posted above.
- We are extrapolating from the M270/274 that the solenoid (which has the exact same stated function) is not actually critical to safe engine operation. Rather, it is critical to emissions/fuel economy compliance and this is why it throws a CEL on some cars, and why Mercedes may have an updated engine software to trigger the CEL for other cars.
- Am I missing anything?
There is also no evidence, anywhere, that dual stage oil pumps were introduced across the markets for anything other than fuel economy/emissions purposes. Please present the evidence that these systems are designed to increase engine or component life. I'll wait.
I have been SOOOOOO busy....in recent days it feels as if my trans has been slow, I mean super slow to engage. About four weeks ago the car asked for oil (added 1.25 5-40 Liquid Molly). I could 'hear' I need an oil change (I know that makes sense).
Checked out the dash yesterday - the car is "due" in 2500mi (to me, that means I am over 6000 on the oil that is in the car - shame on me).
Ten quarts of Molygen will be here Friday via FCP....see what that changes. To this day, engine oil altering the trans is still an odd one.....
