Oil pump solenoids
Old Apr 22, 2025 | 03:38 PM
  #3526
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Source
Old Apr 22, 2025 | 03:40 PM
  #3527
Pennzoil Platinum Euro VS Motul Excess Gen2
which one will you be using?
Old Apr 22, 2025 | 05:46 PM
  #3528
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Are these both API-SN oils samples?
Calcium is through the roof (SN!)
Viscosity 13 very similar
Old Apr 22, 2025 | 05:47 PM
  #3529
Pennzoil is rated SP
Motul is rated SN
Old Apr 22, 2025 | 05:50 PM
  #3530
SAMPLE ANALYSIS
-- Calcium is through the roof (SN!)
-- Viscosity 13 are very similar
Personally I would concider using cleaner API-SP formula for "LSPI protection".
Some contamination will remain during first oil change that will serve as a rince cycle.
Find the best oil that meets your criterias:
  • Group 3-Synt. or 4-PAO
  • Viscosity grade: 5W-40 or 5W-50
  • Formulation SN or SP
  • MB Approved or greater
All synthetic oils are good lubricants.
Old Apr 22, 2025 | 07:47 PM
  #3531
Pennzoil it is for you Cali?
Old Apr 22, 2025 | 08:10 PM
  #3532
yes, as long as it meets your criterias, it's all right.
I think @JettaRed has tried the PennzOil/Shell with satisfaction.
I was surprised by similar high level of calcium in both your oil samples. It would be better to stay with one formulation either SN or the cleaner SP. These oils lubricate & clean with a different mix of chemicals.
Old Apr 22, 2025 | 08:26 PM
  #3533
JettaRed's Avatar
Veteran: Army
I am currently running Pennzoil Platinum Euro 5W-40 in my bi-turbo M276 and Molygen New Generation 5W-40 in my non-turbo M276. The Pennzoil is API SP and the Molygen is API SN. Both cars seem to like what they have. I've seen a 10% or better improvement in my mileage with the Molygen over the previous Castrol Edge 5W-50.
Old Apr 23, 2025 | 09:56 PM
  #3534
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Did you run through the mileage and needed the change or just wanted to change 5/50 to 5/40?
Old Apr 23, 2025 | 11:27 PM
  #3535
JettaRed's Avatar
Veteran: Army
A little of both. I had about 2700 miles of the 5W-50 in the SL400 and 2,630 miles in the C350. I am now shooting to change oil at 3000-5000 miles.
Old Apr 24, 2025 | 02:36 AM
  #3536
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
stealer says is fine.. mhm
i dont have what to say anymore for stealer /post taken from fb group/
Old Apr 24, 2025 | 05:53 AM
  #3537
VVT Connectors
The VVT gear solenoids are not the primary leakers like CPS. They have a cooler position on the upper timing covers.
epoxy sealed 2-pin VVT solenoids
Old Apr 24, 2025 | 07:40 AM
  #3538
when i reseal my cover i did not notice my cam sensors to have epoxy
Old Apr 24, 2025 | 11:00 AM
  #3539
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
That’s probably Dielectric grease….
Mr. Goodwrench may have worked on the car.
Ford, GM and others use it in some of their connectors.
Amazon Amazon
Amazon Amazon
Mercedes has their version.
https://www.autohausaz.com/pn/MB-002...RoC-PcQAvD_BwE
Since tech and owner reported it as having “grease” consistency I.e soft. And visually, it looks like what that Dielectric Grease looks like once it has aged a bit. Consistency is similar to Vaseline, see pics below
Good Luck!
Old Apr 24, 2025 | 03:01 PM
  #3540
dspecialistb's Avatar
'14 CLS550 , '86 420SEL
a week or so after the oil change to 5w-50 I finally drove more than the initial trip around the block yesterday! I am very satisfied so far; engine is quiet and vibration is minimized at start up, idle and throughout the powerband. Shifts are smooth, throttle is responsive and engine feels solid at all speeds. I wish I drove the car more before the having the AMG dash menu and Agility Mode unlocked, but the timing did not work in my favor. Regardless, fuel efficiency remains about the same during my normal commute to the office.
Old Apr 24, 2025 | 03:02 PM
  #3541
DIELECTRIC SILICONE ....
Lets keep in mind differences:
-- 2-pins VVT Solenoids (aka. "magnets") are the ok actuators. Located on timing cover front.
-- 3-pins Camshaft Position Sensors (CPS) Mfg. by Continental are the failed ones. Located on valve covers top. Use pigtails!!
Using dielectric grease on hot ECU related connectors brings out question...
-- Will melted grease travel around hot engine harness towards ECU like engine oil does??
-- Is dielectric grease helping or hurting low-voltage connections ??
In the long run... I have a preference for dry metal-to-metal connections without any anti-oxide oily film. When "protective film" hardens, the connection get marginal.
This is what happens with DeOxit magic spray. It helps then hurt to need repeated applications.
We know the hot/cold changes the qualities of thin film. Granted silicone can take 1500F temps...
> This can be a split topic:
Does protecting ECU connections with silicone hurt reliability??
Personally I think it does. Protective film can become an extra maintenance item.
Old Apr 24, 2025 | 04:41 PM
  #3542
SUPERSONIC FAN > > OFF!
Here are my inputs towards taming the ineffective FAN:ON in winter/summer.
Control heat at the source...
then FAN can stay OFF with normal heat ECU can manage.
Old Apr 24, 2025 | 04:46 PM
  #3543
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
Well I think it's time for Me to take next step. I have 8000 miles on Motul 5-40 Sn. 5000 on 1st batch and 3000 on this batch. I have Motul 5w-50 SP on the shelf, warmer weather coming so upgrade it is.
Old Apr 24, 2025 | 05:06 PM
  #3544
W205C43PFL's Avatar
Old Apr 24, 2025 | 06:01 PM
  #3545
If you’re referring to my post, sorry if you misunderstood. I was identifying the type of grease most likely in the connector, since we had mentioned EPOXY. I probably should have elaborated more.
LOL! As far as using it in this application….
You may not have gotten my joke about Mr. Goodwrench (old term for factory trained GM mechanic) who probably had worked on the MB mentioned in the FB post.
Several years back GM and Ford (and others) used to use Dielectric grease on their exposed connectors such as parking and brake lights, etc... These connectors weren’t as sophisticated as what we see today, as far as sealing and would corrode over time. MB nowadays does a decent job of sealing their connectors. (Though that grease works well on spark plug boots). I believe that was probably the handiwork of an independent or DIY’er, who probably applied dielectric grease inside the connector.
Agree, It’s the wrong product for this application and we definitely need to keep Mr. Goodwrench away from our MB’s
Cheers!
RIP Mr. GOODWRENCH!
Old Apr 24, 2025 | 07:30 PM
  #3546
JettaRed's Avatar
Veteran: Army
Originally Posted by dspecialistb
....I wish I drove the car more before the having the AMG dash menu and Agility Mode unlocked, but the timing did not work in my favor. Regardless, fuel efficiency remains about the same during my normal commute to the office.
How are you liking those mods?
Old Apr 25, 2025 | 11:42 AM
  #3547
I love them! Only wish I could see transmission temperature. I am not sure my model has a sensor but I will investigate. UPDATE: looks like I need to convert the entire cluster to an AMG cluster in order to see the Transmission Temps, currently I just have an additional menu.
i am contemplating a TCU tune but am on the fence. Do I need it? Defintely not, but I have FOMO of having power that I can’t access in the lower gears. Opinions and experiences welcome!
Old Apr 25, 2025 | 02:48 PM
  #3548
JettaRed's Avatar
Veteran: Army
Generally, I have not heard good things about a TCU tune. The good thing about adding Agility/Sport+ mode is that you are not "tuning" anything; just enabling a factory feature.
I really don't understand your FOMO comments about missing out on power.
Old Apr 25, 2025 | 02:58 PM
  #3549
gearbox masters driveability
I am gonna volunteer to say: be patient and do leave your tranny alone!
Concentrate on shaping up the engine so ECU can gains fine throttle control. That's will transform tranny work to near perfect.
What sucks buckets about powertrain... :
  • the wrong gear choice: 5th gear at 20mph
  • the shift timings: delays bangs gears up/down
  • the sloppy shifts: slipery clutch instead of instantaneous
The TCU is unable to partner up within unstable environment. It is extremely dependant on precise engine throttle activity.
Sloppy slippery:
Given enough slippery long shifts the fancy "gas saving" thin blue ATF gets heated up ultra thin. Controlling clutch pressure becomes increasingly challenging.
Normal shifts happen seemlessly where gearbox keeps engine Rpm in the zone for it to run well.
Normal gearbox shifts keeps engine running around 2000Rpm with great ability to rev up. It can readily hang on to 2nd, 3rd and 4th gears as needed.
Shifts can easily be delayed by throttle pressure to Rev up engine much higher.
Throttle doesn't need to be floored to redline. It can easily control consistent shifts at 2500, 3000, 4000 ... awesome driveability control by accelerator pedal.
This precise throttle is made possible by self-adapted matching fuel maps. Chaos makes Rpm control uneasy to challenge tranny.
If you recognize your tranny is struggling, take it easy with your high-power shifts. Deal with engine conditions.
Old Apr 25, 2025 | 05:22 PM
  #3550
I am with you about Agility/Sport+ mode. Granted I have only driven the care twice in that mode but I am enjoying it.
From my understanding is that the torque limits are lower than what the (tuned) ECU can provide within the first 3 or 4 gears, so the TCU tune would raise the limits in earlier gears. Now, I have definitely read conflicting information about TCU tunes so I am taking my time making the decision. Here are a few blurbs from various reputable tuners on TCU tuning:
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
