Oil pump solenoids
Old Nov 14, 2024 | 09:10 PM
  #2301
JettaRed's Avatar
Veteran: Army
Originally Posted by Baltistyle
Im sure you remembered when filling, but these Castrol bottles are quarts and not liters. I messed that up and got a low oil light pretty quickly. First time for everything.
Yes. I suctioned out 6.5 liters and filled with 6.87 quarts. 👍
Old Nov 15, 2024 | 03:34 AM
  #2302
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Good score. I had not run across that pricing. The Mobil 1 fs x2 5 50 is a tiny bit cheaper than the supercar and also sp grade.
In terms of the mobil supercar vs x2, the x2 is more appropriate I believe.
https://bobistheoilguy.com/forums/threads/mobil-1-fs-x2-5w50-vs-supercar-5w50.366927/
https://bobistheoilguy.com/forums/threads/mobil-1-5w50-european-car-fsx2-api-sp.375449/
Can you pls post these specs... I can't open the files without being a member.
MOB1 5W50
MOB1 5W50
Let's see which Mobil1 product works best with high heat.
Old Nov 15, 2024 | 05:53 AM
  #2303
E63Wisken's Avatar
I tried doing this at the weekend and couldnt get the solenoid out slightly broke the grey part on the clip lol have now received the proper tool in the post to try remove this again.
Old Nov 15, 2024 | 08:34 AM
  #2304
Cla1111's Avatar
2015 E63 S
Old Nov 15, 2024 | 11:32 AM
  #2305
Cla1111's Avatar
2015 E63 S
Just curious: does the different grade 50 vs 40 affect the hydraulic lifter?
Old Nov 15, 2024 | 01:52 PM
  #2306
VISCOSITY... as essential factor
The valve lifters are not affected. Oddly enough, there never seem to be any issue ever with them.
What is positively affected is the hydraulic mapped VVT positioning.
With MOD-0 and stock viscosity, when the piston squirters begin to open, it royally screws up VVT positioning that silently confuses the ECU without code - This is the cause for laggy fuel map.
With better oiling this pressure transition happens right outside idle Rpm before engine develops power. So that ECU never sees VVT positioning jumps.
In addition the oil temperature being controlled without heatsoak preserves the working viscosity such that runtime hot engine VVT map remains valid.
(Smart TCU uses multiple ATF temperature maps *BUT* the kludgy VVT does not).
Meaning... better oiling cancels the engine runtime moody weaknesses caused viscosity variations. This is a big deal because extreme heat corrupts maps as it affects runtime. The ECU has limited ability to work with wildly variable viscosity.
The engine operation can/should remain precise without extreme heat impacting viscosity and fixed-map computations (**).
The key contribution has been to identify factors that help the engine retain predictable smooth timings ie. performance.
​​​​​​Poor oiling DeTUNES engine output. Many times I've experimentally found & confirmed:
"MOD performance is based on the oil being used".
Ppl on MOD-1 are stuck in "preview mode" without much driveability improvement.
> Top Limiting Factors Involved :
  1. runtime viscosity
  2. stored core heat
  3. VVT Mapped position x4
  4. rings blow-by losses
  5. CAN-C bandwidth
  6. ECU+TCU fixed-map computations
> ECU + TCU Mgt Team:
-- The ECU/TCU respond well to experimental improvements.
-- Our engine computers are unmatched for stock oiling.
-- Limited engine driveability under 2500.Rpm is squarely pinned onto oiling condition.
Using an hybrid electric engine and turbo to make up for limited oiling is amazin solution for missing torque.
(**) the single target of engine mgt is optimal computation of mechanical variables.
Deutch pragmatism dictates to optimize factors under control.
Give it oil.
Old Nov 15, 2024 | 03:24 PM
  #2307
MOB1 5W50 SELECTION
Both are excellent high quality oils with high flash temps (400/430F) for less impact on viscosity variations.
Given the choice, I'd pick the right side oil for its cleaner formulation with less zinc contaminants.
Left side oil has higher protection package for higher output applications.
The flip side is higher deposits... necessary for protection!
High power output needs proven solid anti-friction besides a viscous film. This has not changed!
Thin lubricants with clean-lean formulation wear out engines more rapidly.
Mixed city driveability: right side oil
Spirited power protection: Left side oil.
Old Nov 15, 2024 | 06:28 PM
  #2308
momo a's Avatar
2014 W212 E63 AMG S model
@CaliBenzDriver would you say 700+ horsepower m157 motors Qualify for left side oil over right side?
Old Nov 15, 2024 | 07:20 PM
  #2309
RACING APPLICAT°
From 500 to 700+ HP application:
that would be left side : "MOBIL1 Supercar" with additional friction modifiers - Viscosity alone can not protect high output engines nor trannies.
That's when ZDDP steps in and Lambda/cats are replaced by mapped fuel. MOTUL has a ZDDP RACING oil.
This must be a true blast to handle!
Old Nov 15, 2024 | 08:02 PM
  #2310
momo a's Avatar
thank you for the great info! Really tough choice between M1 Supercar versus Motul 8100
Old Nov 15, 2024 | 11:00 PM
  #2311
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
sorry, I couldn't open them either. I was going off of the mobil website, which has changed a bit since they've upgraded their sp offerings. I figured posting would lead to a good convo about the zinc
Old Nov 15, 2024 | 11:03 PM
  #2312
Baltistyle's Avatar
Drive it a bunch and try them both
Old Nov 15, 2024 | 11:09 PM
  #2313
momo a's Avatar
hopefully we can see a couple testers here shortly on both to see which will be better in the long run. I know a couple people had issues back then with M1 5w40 burning sometimes, but seems their chemistry changed with their M1 5w50.
Old Nov 15, 2024 | 11:10 PM
  #2314
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
motul 8100 power? Or …?
Old Nov 16, 2024 | 02:09 AM
  #2315
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
i guess he meant Mobil 1
Old Nov 16, 2024 | 07:35 AM
  #2316
momo a's Avatar
mobil1 5w50 supercar
Old Nov 16, 2024 | 03:52 PM
  #2317
Baltistyle's Avatar
Would this be a question of cats vs no cats?
Old Nov 16, 2024 | 03:54 PM
  #2318
Baltistyle's Avatar
Correct on the old mobil but it seems the new sp is better performing in the lab. Like you said, lots of testers would be great and with this popular thread, Im sure there will be many to follow.
Old Nov 16, 2024 | 06:01 PM
  #2319
JettaRed's Avatar
Veteran: Army
Change the oil on my 2014 C350 with M276 NA engine using the Castrol Edge 5W-50. Put around 50 miles on the car today and it seems to really like the new oil. I am glad to have used the Pennzoil 5W-40 for about 3500 miles first as a transition from the M1 0W-40. The car does seem to have a better throttle response. I almost don't want to believe it because I've never had a simple oil change make such a noticeable difference. Then again, I haven't used such a high viscosity oil since around 1981 when I used 15W-50 (or maybe 20W-50 -- it was so long ago) in my 1981 Volvo 245 wagon (loved that car).
Old Nov 16, 2024 | 06:15 PM
  #2320
W205C43PFL's Avatar
Great stuff!
Old Nov 16, 2024 | 07:50 PM
  #2321
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I'll have to wait until next season to join in on the fun. Just discovered a leaky right front inner axle boot also.
Old Nov 16, 2024 | 09:36 PM
  #2322
minimizing blow-by...
JR, I know... this is really HARD TO BELIEVE what a simple oil upgrade can do to these engines!
The best part is when you escape the vicious cycle of vanishing viscosity you enter a virtuous path where everything keeps improving:
The ECU tunes the fuel map from 900.Rpm
The TCU becomes more nimble to downshift
The chassis feels super light and responsive
The throttle is hard without any sponginess
No misleading numbers, just simple bliss.
Welcome to the party.
We've just pushed back a limit by improving pressure containment.
Now that we discover how touchy pressure is, it makes me want to know what else we're missing ...
The non-turbo ECU MAP setup is particularly sensitive to intake pressure... so I am going to go service my PCV disphragm & its restrictive discharge pipe.
At 65kMi I am sure my PCV refurb is going to register a difference now that blow-by is under control.
(I am going to pass on dealing with the well lubed HPFP roller to only replace silicone check-valve and vent tube).
I am due to lift up intake plenum again for old CPS.
Old Nov 16, 2024 | 09:42 PM
  #2323
winter repairs
What maintenance do you have lined up for this year's winter?
Old Nov 16, 2024 | 10:45 PM
  #2324
W205C43PFL's Avatar
Look forward to your impressions of such oil on your 3.0 BiTURBO as well once the time comes : )
Old Nov 17, 2024 | 08:01 AM
  #2325
JettaRed's Avatar
Veteran: Army
As mentioned, I did the change to 5W-50 on the M276 biturbo a couple of days ago. I don't drive as much as I used to when I was working, so it is going to take a while for all the benefits to take place. However, for now, I continue to enjoy the smoothness and throttle response. I am finding that giving a little more gas than usual that I do trigger traction control, especially in S or A mode (1st gear start).
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
