Freaking now what.
Old Jun 5, 2025 | 01:30 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Freaking now what.
With brand new battery
https://youtube.com/shorts/cAcvfqsrI_4?si=FKuD6CbnW0sXWrfj
Old Jun 5, 2025 | 01:39 PM
51north's Avatar
2003 e55, 2014 e63s wagon, 997 911.
Confirm voltage of both batteries.
Old Jun 5, 2025 | 03:10 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
When recently doing my auxiliary battery in my 13, I would only get the code for safety systems related to distronic and Eco being disabled. Previously after doing a main battery change, I would have lots of symbols that would pop up initially, but would go away after driving. I did not get as many warnings as you and they were generally related to ESP. I’m not sure if you hooked up a diagnostic, but it will likely register a battery error and you can reset it and see if that gets you anywhere. I know you’ve had a lot of work recently, was your alternator removed and reinstalled at any point?
Old Jun 5, 2025 | 03:55 PM
Gets weirder. Disconnected both. Rear is good. Front is new...
Old Jun 5, 2025 | 04:13 PM
Running
Old Jun 5, 2025 | 04:14 PM
PeterUbers's Avatar
When installing the new battery - there wasn't any accidental polarity mixups with the terminals was there?
Old Jun 5, 2025 | 04:43 PM
No. Really the behavior is the same with the old one and the new one.
Old Jun 5, 2025 | 04:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SELF INFLICTED PAIN
Originally Posted by OldManAndHisCar
I see... IC shows every possible module upset.
The long story short is you just need to do a proper REBOOT sequence and clear faults afterwards.
You disconnecting main AGM freaked out the chassis that's what all the IC messages are saying.
This should go easy.
What triggered this is chassis seeing a low main voltage with only AUX connected - This triggered EMCY response.
Old Jun 5, 2025 | 04:56 PM
what were you trying to fix ??
Old Jun 5, 2025 | 05:30 PM
Fix? I was JRA...parked the car for about two hours. Got back in and this....figured it was low voltage. Tried to jump it...same error. Went and got a new battery. Same. Unplugged rear battery....let it sit an hour or so. Plugged batteries back in....same.
Mechanic is thinking some motor on the trans or a trans resister plate....said to take the blue and white wire out of the CAN (pass foot well) and see if I can scan the car after that....
Old Jun 5, 2025 | 05:59 PM
CHAOS NATURAL CAUSES
I see... it's not "battery swap gone wrong !".
The X-Mas Tree started seemingly by itself.
The ISM going into lock-mode is a consequence of low voltage. Let's ignore it for now.
What is your scan report like ??
Do a timely reboot
clear faults
rescan
report
Old Jun 5, 2025 | 06:02 PM
The scanner does not see the engine or the trans...moves on to the Dash that says it can not see the engine. Looking at TCU and Trans stuff now (about 45 minutes from the car).
Check the video on post 4....
Old Jun 5, 2025 | 06:28 PM
ECU + TCU missing... need IGN:ON
Old Jun 5, 2025 | 06:34 PM
Baltistyle's Avatar
Maybe do a cursory check of the ecu connection to check for oil infiltration? Ive used xentry/das for about ten years so im not sure about how to further diagnose with a foxwell. Im sure you tried to reset but the codes say and stay active. You could ask someone for the wiring diagram from wis or I actually think its called web etm but I cant remember (sorry I dont have connectivity on my system) and see if all of the issues you are having are along one CAN network. If the damage is not something you can literally see, you need to at least find what to test. Xentry usually walks you through the whole process digitally, but the wiring diagram is very simple and concise. there's a few trees and you need to figure out which branch to take.
after watching your third video, are you doubly sure the accessory battery is good. verified with an old fashioned meter?....I think even the transmission pump that is supposed to run during an ecostop is powered from that rear battery. maybe even the fuel pump that is supposed to keep the injectors primed. And did you test the old battery with a meter before recycling it just to see if it was indeed a root cause?
Old Jun 5, 2025 | 06:49 PM
Baltistyle's Avatar
Not to be annoying but making anew post so it separate. this is a person going through can diagnostics and shows the diagram.
https://mbworld.org/forums/e-class-w...-topology.html
Old Jun 5, 2025 | 06:53 PM
@Baltistyle First thing I checked 😀 Cali....yeah, thats what is odd. Was thinking dead CAN
Old Jun 5, 2025 | 07:37 PM
51north's Avatar
Put a meter on the new battery and see if it is rapidly discharging. Try key on and off. I had a similar problem to this once on my Duramax.
Old Jun 5, 2025 | 08:02 PM
PeterUbers's Avatar
Is there water in the sills? Trunk? Rodents chewed up something - Christmas tree happened to my neighbors suv thanks to mice
wait.
THE SNAKE
Old Jun 5, 2025 | 08:11 PM
PRELIMINARY CHASSIS TESTS
In this type of large chaos situation everything is confusing such that it's difficult to sort things out. The modules are confused, we are confused...
One thing leads to another and another... in the end it's hard to understand the root cause. So ppl replace batteries out of convenience.
It seems this involves low voltage
You need to have charged up battery
and good ALT / battery voltage
Once you can rely on voltage then you can wonder what makes modules disfunction... reboot/scan with engine running, not key Off or timed out.
Troubleshooting with scanner data, you should be able to conclude what's wrong.
Can you shift PARK - Neutral - Park with IGN:ON + brakes:ON?
If yes CAN-C is working, ECU/TCU needs SAM Power.
Old Jun 5, 2025 | 09:17 PM
I am currently about 40 miles away from the car but this video looks to be exactly like what is probably going wrong.
Old Jun 5, 2025 | 11:21 PM
This video is about a bad gear shifter
Have you been driving in more rain that usual?
ISM has the ability to short out ECU + TCU + ESP + Tank controller. I saw something about no ECU Coms in your video...
Use scanner to enumerate all your modules and confirm ghosts.
Next well be disconnecting suspects.
Old Jun 6, 2025 | 07:47 PM
Turns out the issue is a transmission Servo motor that is about $800 and requires proof of ownership of the vehicle including driver's license to even order the part
Old Jun 6, 2025 | 08:15 PM
51north's Avatar
ISM. They're for sale all over eBay and it looks like they can be rebuilt as well.
Old Jun 6, 2025 | 08:22 PM
ISM is a mandatory failure.
You can further troubleshoot networking Bus by disconnecting the ISM off the CAN-C. (WIS Doc needed)
You can look for water in ISM connector.
Old Jun 7, 2025 | 08:17 AM
51north's Avatar
This may be helpful.
File Type: pdf
