E63 S shifting issues
Old Aug 10, 2025 | 12:46 PM
Dnice24's Avatar
E63 AMG S
Hey everyone. I ran into a problem where once I get home and try to put the car on park or reverse and the car does not shift into any gear. It stays on “D”. The only way it shifts back into Park or any other gear is when I turn the car off and back on. Any input in what it can be? This has been happening everyday now. I do not have any warning lights on the dash either or codes.
Old Aug 10, 2025 | 12:57 PM
Sathinas's Avatar
S65
The car goes into park when you shut it off, then back into drive when you select drive after starting.
KISS and start with the shifter stalk.
Old Aug 10, 2025 | 01:07 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 Coupe, 2013 E350 Wagon
Your push button switch for Park on the console has gone south, as best I can tell from your description. Assuming you have the gear selector on center console with the P button top left?
The module that lies under that button is basically unobtanium (no longer made/stocked). There is a procedure where you can remove it and solder some pins that might work…it worked so far for me, though I still search for that replacement part occasionally
Old Aug 10, 2025 | 01:09 PM
Jaybird123's Avatar
Wait, it won’t go into reverse either? Now that’s weird…question: if you open the driver door (while foot firmly on brake of course), does the car shift into Park?
Old Aug 10, 2025 | 01:10 PM
PeterUbers's Avatar
From the sticky
https://mbworld.org/forums/w212-amg/...park-help.html
Old Aug 10, 2025 | 01:42 PM
Dnice24's Avatar
E63 AMG S
I mean nothing works. It does not shift into any gear. Nothing at all. I shift up and right and nothing. I literally have to shut the car off from D and then turn it back on so it can go into Park on its own
I mean nothing works. It does not shift into any gear. Nothing at all. I shift up and down, and nothing. I literally have to shut the car off from D and then turn it back on so it can go into Park on its own. It does this sporadically. Once a day or maybe twice at most. It happened when I first bought the car and now it’s been happening for a week straight.
Old Aug 10, 2025 | 04:08 PM
PeterUbers's Avatar
it's either the shifter mechanism ($700) or a problem in the canbus or ISM
https://mbworld.org/forums/w212-amg/...into-park.html
Disassembly of your current mechanism to repair:
https://mbworld.org/forums/w212-amg/...y-working.html
more reading:
https://mbworld.org/forums/w212-amg/...oblem-fix.html
consider replacing main and/or aux battery:
https://mbworld.org/forums/e-class-w...ck-park-2.html
clean the mechanism:
https://mbworld.org/forums/w212-amg/...to-gear-2.html
This guy never solved it - even replaced ISM
https://mbworld.org/forums/w212-amg/...011-e63-4.html
Old Aug 10, 2025 | 06:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
OXIDIZED PRESSED PINS
Follow the research links from Peter, it's all laid out waiting for your scanner troubleshooting.
These good looking control buttons feature pressed-pins LIN modules.
Old Aug 10, 2025 | 06:06 PM
Dnice24's Avatar
E63 AMG S
more reading:
Thank you so much for the info. I’m going to look into it and worst case I’ll take it to a benz tech.
