Knocking Noise - P0307 P
Old Apr 13, 2026 | 01:38 PM
sknypizza's Avatar
2019 E63 AMG S
2019 E63
Suddenly the check engine light came on and started to hear this weird knocking sound. The car is basically shivering as it drives.
The OBD 2 scanner said it’s a misfire code.
Any thoughts on what is happening? Car is drivable but should I risk it ? Or have it towed to the shop ?
Old Apr 13, 2026 | 01:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by sknypizza
2019 E63
Your engine is now heavily misfiring with live DTC for some reason... what are the fault codes?
I would get it towed on flat bed to your MB specialist. No need in causing engine damages on the way to repair.
Old Apr 13, 2026 | 02:19 PM
sknypizza's Avatar
2019 E63 AMG S
P0307
01/02
02/02
Old Apr 13, 2026 | 02:40 PM
single cylinder misfire...
P0307
01/02
02/02
Okay: P0307 is only a single cylinder misfiring... not the whole bank off.
It can still be couple things:
  • bad ignition
  • (bad injector)
  • (bad cylinder)
Likely heat soaked coil...
Once proven bad, replace all 8x coil identical to fire exactly with the same voltage, at the same time.
(FYI: Injector gets halted as ECU recognize low contribution)
Repair is Not one coil + one plug... 8x of everything.: coils + boots + plugs
The underlaying troublemaker is stored extreme heat soaking heads at engine stops.
Old Apr 13, 2026 | 02:43 PM
sknypizza's Avatar
2019 E63 AMG S
Okay ! P0307 is only a single cylinder misfiring....
that is not the whole bank2.
It can still be a few things:
  • bad ignition
  • bad injector
  • bad cylinder
Got it. It also smells like gas. My euroshop is 15 miles away, i am thinking i will just drive...
Old Apr 13, 2026 | 02:51 PM
gas leak + misfire
yes, that's very reasonable.
> Smell of gas... heat soaked rail!
-- Can you hear your engine hissing 10mn after shutdown??
-- That is the overheated 3000Psi fuel rail off gasing back into tank that blows up tank seals or EVAP relief.
Flammable gas leak should be your top priority, right ?!
Old Apr 13, 2026 | 05:15 PM
sknypizza's Avatar
2019 E63 AMG S
No engine hissing. Car drove perfectly fine, no spikes in engine temp. Only when it came to traffic stops, it was vibrating and stuttering. Euro shop thinks it could simply be the spark plugs.
will keep you posted. Thanks
Old Apr 13, 2026 | 06:46 PM
Dual Iridium spark plugs are kept on a short 50k.Mi schedule (truly good for much longer).
It's nice to have a trusted Euro shop nearby.
Old Apr 16, 2026 | 02:43 PM
sknypizza's Avatar
2019 E63 AMG S
Update - see screenshot
It was the ignition coil that failed causing cylinder 7 to miss fire. Apprently spark plugs were changed only 6K miles back so I ened up changing all the coils. Warranty covered a little bit and my net out of pocket was 2440.
Got the service A due in July
Old Apr 16, 2026 | 02:59 PM
Invoice details show only HALF the 8 coils got replaced, right?
QTY 4Pcs
QTY 4Pcs
Keep that record in mind.
Old Apr 16, 2026 | 03:08 PM
sknypizza's Avatar
2019 E63 AMG S
QTY 4Pcs
QTY 4Pcs
Mechanic said only 4 coils are needed for this V8 because engine is split in two banks 2 per 4cycl on each bank. Dont know what that means but ChatGPT seems to agee
Old Apr 16, 2026 | 04:42 PM
mixed new coils
Your two banks of coils fire up as follow:
M177 firing order: 1 - 5 - 4 - 2 - 6 - 3 - 7 - 8
The timing of both banks are mixed together :
Bk1 Bk2 Bk1 Bk1 Bk2 Bk1 Bk2 Bk2
With 7 years difference old vs. new coils put out different high voltage. That ignite with slightly different delays. That is ok but not best for ECU timing work. New coils will fire a hair sooner than older ones. ECU will adapt to engine.
The rational is you shall be replacing remaining over heated coils within a year or two and you better match exact same one, not just new ones.
Retail M177 MB.coil : $428 Ea.
At that price point... don't worry mixing old + new coils. It is done everyday everywhere - A common practice.
Old Apr 16, 2026 | 04:50 PM
sknypizza's Avatar
2019 E63 AMG S
Your M177 two banks of coils fire up as follow:
Firing Order: 1 - 5 - 4 - 2 - 6 - 3 - 7 - 8
The rational is you shall be replacing remaining over heated coils within a year or two.
Oh boy so another 2700 another ?
idk seems like this euro shops always screws me over..will have to find another place or go to the stealership to see what they have to offer.
I also didn’t appreciate the breakdown they gave regarding wary coverage. I have a $500 deductible and then the warranty kicks. Got a very good warranty that covered 100% of my RMS leak cost.
For this repair because only 1 of the coil was broken, the shop said warranty would only cover that + some labor.
An expensive hobby to own this car but I love it. Hoping to get an S65 sometime soon.
Old Apr 16, 2026 | 05:09 PM
I can see warranty covering only 1 single coil... that's part of the exclusions in the fine prints.
At over $400.Ea... I think you can shop around for a substantial discount genuine NIB parts.
Same brand same P/N... then go for it - If not it will work nearly as well until time comes for other bank misfires.
Old Apr 16, 2026 | 05:20 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
At over $400.Ea... I think you can shop around to find a 40% discount for genuine parts.
where do you find 40% off on genuine parts?
Old Apr 16, 2026 | 05:28 PM
Here's my go-to list in no particular order:
trusted supply-chain suppliers
trusted supply-chain genuine parts suppliers
Do you know other good suppliers ?
(I forgot "ECS Tuning" in my list)
$3,400 + Tax for 8x bare coils wakes up creativity.
Old Apr 17, 2026 | 08:29 AM
PotatoHeadII's Avatar
Here’s the problem with owning a Mercedes: Either you don’t care how much it costs to own, or you learn to do stuff yourself. Lots of people think that if you own a late model Mercedes, especially an AMG car, you fit into the first category. Always, always, always ask for a detailed estimate up front. Then, do some homework. I know it is easier to have everything fixed at once, but you will pay for the convenience.
From FCP’s website, it appears a single coil assembly supports two plugs. I don’t know the complexity of swapping out coils on your engine, but certainly you were screwed on the price for the coils. I would get a quote from the Mercedes dealer for the parts.
The “good news” is that it appears all of your coils assemblies (4) were replaced.
Old Apr 17, 2026 | 08:33 AM
The FCP price of $1005.28 is for a set of 4 coil assemblies. Each coil assembly is $251.32
Old Apr 17, 2026 | 03:23 PM
Strong Ignition Setup
That's very good news! OP has ALL new ignition !
DUAL COILS...
M177 only has 8 plugs, not 16 here.
The coils are dual-in-one package.
(Not legacy "wasted-spark" in exhaust).
PARTS SUPPLY...
The high parts mark-up is usual cost of repairs.
Wholesale: $1000 only for 4x genuine MB
Imagine cost of OE units...
Bottom line is great reliable ignition for balanced cylinders output. The pro hooked you up with nice gear.
Old Apr 17, 2026 | 04:00 PM
ALL Good Ignition
@potatohead
Thank you for digging into this.
You came up with important info on total count & cost for MB Genuine parts.
These complete kits are gonna be great purchased with free lifetime warranty exchange.
