handheld lowering module
Old Apr 13, 2018 | 05:36 PM
  #176
Ariesfamous's Avatar
2015 cls550
No matter how you cut it these cars are awesome
Old Apr 13, 2018 | 09:49 PM
  #177
Wolfman's Avatar
Super Moderator
Originally Posted by Vic55
Module works nicely- and Im running -10mm front and -15mm rear plus my previously lowered car via my tech (assuming about 22mm). I took the car up and down my local toll roads and hit speeds past 130 mph and went thru the undulations with no rubs and no bottoming out.
Love the drop
Envious! I will drop the car more once I get rid of the snow tires. Can't believe we are supposed to get 12" snow over the weekend...
Old May 22, 2018 | 02:46 PM
  #178
relaxhero's Avatar
Mercedes-Benz
Originally Posted by Corrado79
Who is manufacturer? Looks great, BTW!
There is open the new store on Amazon. Here you can buy the module from the manufacturer at the lowest price. The first 10 modules will be sold at a price of $ 399.
GREAT PLEASE, leave your comments on Amazon, it is very important for us.
CONTACT E-MAIL: SHAMAICHART@ICLOUD.COM
AMAZON AMAZON
Old May 22, 2018 | 04:42 PM
  #179
limeypride's Avatar
2018 AMG E63S
This pic shows her lowered 32mm I think front and back. The module makes it so quick and easy and works every single time.
Old Jun 5, 2018 | 01:18 PM
  #180
jdhertz11's Avatar
G
I just put my car back to factory settings and there's no way it's stock height. It looks slammed. I unplugged it twice to verify and it says that the current setting is factory but I highly doubt it. Thoughts?
Old Jun 5, 2018 | 01:21 PM
  #181
Vic55's Avatar
Administrator
Originally Posted by Roman Morel
It would be unpleasant if at speed of 130 mph to rub the bottom about asphalt.
It would be great if the module set the level of suspension depending on the speed of the car.
It sure would if I actually did but I dont and we all know pictures dont always show the correct depth as there is a lot of clearance still. I run 130 and beyond daily and I have zero issues. The suspension is very stiff at speed (not that its soft at slower speeds LOL)
Old Jun 6, 2018 | 03:24 PM
  #182
kponti's Avatar
E63
post pics
Old Jun 6, 2018 | 05:04 PM
  #183
jdhertz11's Avatar
G
Originally Posted by kponti
post pics
Imagine slammed!
Old Jun 7, 2018 | 08:19 AM
  #184
jdhertz11's Avatar
G
post pics
This is definitely not Factory
Old Jun 7, 2018 | 10:30 AM
  #185
Wolfman's Avatar
Super Moderator
Just leave in factory height mode, raise the car,drive the car around the block and the drop it again.
That may just reset it. Good luck
Old Jun 7, 2018 | 12:16 PM
  #186
jdhertz11's Avatar
G
Raise the car? Connector on it?
Old Jun 7, 2018 | 01:58 PM
  #187
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
Not to scare anyone who is using the Ebay lowering module, particularly the blue lowering module to have your suspension/alignment checked. I purchased this from the seller about 3 months ago and once installed, I was liking how it sits lowered, however after less than 2K miles, I've have notice the " OUTER " front 2 tires where going bald. Mind you this is a brand new MY17 S63 Sedan that I upgraded from my old W212 E63 where the tires are prematurely worn out on the INNER side of the tires which I understand is common with AMGs. Long story short, took it to my local dealer to have them check the car out and was told the 4matic and alignment were so off that it needed a whole day just to re calibrate the 4matic and alignment.
Needless to say, I took the module out and have not used it since ( after re calibration and alignment ). I drive the car gently especially during the brake in period so it must me the lowering module. If you have not notice anything out of ordinary, that is great, BUT I would suggest having your suspension check. I was told by my dealer my S63 was siting on different height for the front and back ( forgot if it was front and back or left to right ) so the car was uneven. FYI.
Old Jun 7, 2018 | 05:28 PM
  #188
Wolfman's Avatar
Super Moderator
No, just the raise button on the left side of the dashboard.
Old Jun 7, 2018 | 05:43 PM
  #189
Wolfman's Avatar
Super Moderator
Just FYI. W222 S-Class 4matic's are notorious for front wheel outer tire wear. Primarily on S550's. Our S-Class was not lowered, aligned to spec and front tires were going bald on the outside. Alignment spec tolerances apparently weren't good enough to keep the tires in good shape.
That said, recently swapped the snows from our lowered E63s and the fronts had some inner tire wear. This would be as expected, but the rears were perfect. Go figure...
Old Jun 7, 2018 | 05:50 PM
  #190
jdhertz11's Avatar
G
Tried that, still driving the slambulance.
Old Jun 7, 2018 | 06:08 PM
  #191
Wolfman's Avatar
Super Moderator
I remember a couple of guys had problems with the initial module and got a replacement. Was yours one of them?
Old Jun 7, 2018 | 10:13 PM
  #192
jdhertz11's Avatar
G
Yes I'm on number 2.
Old Jun 9, 2018 | 01:20 PM
  #193
S63AMG888's Avatar
Thanks. The tires were bald at 3k miles so I did't think it is normal so took it into the dealer and was told the 4matic and alignment was wayyyyyyyyy off. Just saying have your alignment check if you have this lowering module.
Old Jun 9, 2018 | 01:22 PM
  #194
S63AMG888's Avatar
That is one sweet E63.
Old Jun 9, 2018 | 01:51 PM
  #195
Wolfman's Avatar
Super Moderator
3K miles? If the car drove straight and this happened on both fronts, the dealer should get you a set of front tires! It's impossible for a lowered car to wear on the outside as lowering increases the negative camber.
Lowered cars can benefit from alignment to preserve tire life but some like the improved handing, tires be damned
Old Jun 9, 2018 | 01:55 PM
  #196
Wolfman's Avatar
Super Moderator
Our module works as promised. So the question is if your software is quirky or if it was the module programming. Honestly could be either. MB can obviously override it back to stock and perhaps update the suspension software. Otherwise, connect to the Ebay seller and have him assist you in the fix.
Good luck!
Old Jun 9, 2018 | 02:24 PM
  #197
S63AMG888's Avatar
Car was new when purchased and yes it drove straight. Dealer was puzzled why the front tires would wear so fast so it was replaced thus the 4matic and alignment which my understanding was costly. The first thing the dealer asked was the car lowered because that was the only reason the shop foreman can think of that would require 4matic and alignment done at the same time.
Not trying to scare anyone, just sharing my experience.
Old Jun 9, 2018 | 10:42 PM
  #198
jdhertz11's Avatar
G
What did they do to the 4matic?
Old Jun 10, 2018 | 05:34 PM
  #199
S63AMG888's Avatar
I believe they had to re calibrate the 4matic and according to the shop foreman, he's never seen a new car with less than 4k miles had to replace 2 front tires and 4matic re calibration and alignment. The funny thing is I never mentioned about the car being out of alignment, I was there for an software update and the tech said he thought the car didn't look siting right so he checked and was right and the alignment and 4matic all need recalibration.
Old Jun 12, 2018 | 01:25 PM
  #200
Clk63blkseries's Avatar
2018 E63 S (white wagon), 2016 Viper ACR Extreme, 2005 Porsche GT3 Cup race car,2020 GLE
Anytime you adjust ride height you then have to re-align the car. Anyone that says different is kidding themselves. Also make sure you didn't lower the car and change the rake . If so driving results could be really bad if not dangerous .
