handheld lowering module
Old Aug 2, 2018 | 11:28 PM
  #201
CALBenzo's Avatar
'18 E63S AMG
Originally Posted by Clk63blkseries
Anytime you adjust ride height you then have to re-align the car. Anyone that says different is kidding themselves. Also make sure you didn't lower the car and change the rake . If so driving results could be really bad if not dangerous .
I was speaking with the AMG tech today since I'm bringing my car in tomorrow to have my tires changed over to my new set of wheels. Anyway, I asked him about an alignment tomorrow if I lower the car using a lowering module. He mentioned that he may or may not be able to bring the suspension into proper alignment due to the limited adjustments they can make. He also mentioned several times that while he understands why enthusiasts want to lower their car, this will void the warranty for the suspension components, and that I should wait for the warranty to run out.
I'm still lowering my car, but bummed I can't bring my car into this dealership (the closest one to me) for an alignment.
Old Aug 3, 2018 | 06:38 PM
  #202
CALBenzo's Avatar
'18 E63S AMG
Originally Posted by Roman Morel
How does the dealer know that you are using the module?
I mentioned that that is how it would be lowered, but hadn't yet. Either by lowering module, or by mechanically adjusting the sensors, the lowering will be obvious, and will create the same alignment issues.
Old Aug 3, 2018 | 07:21 PM
  #203
jkob5's Avatar
19 E63s
Could raise it back to stock height and disconnect the module...
Old Aug 4, 2018 | 07:32 PM
  #204
CALBenzo's Avatar
'18 E63S AMG
That is my plan. However, I was hoping to have it aligned when lowered, but now I cannot, at least at this dealership without getting flagged.
Old Aug 5, 2018 | 01:45 AM
  #205
CPD SLK's Avatar
2009 C63 AMG
Does the module work by just letting air our? Does this diminish ride quality at all?
Old Aug 5, 2018 | 11:51 AM
  #206
Wolfman's Avatar
Super Moderator
No, it changes the ride-height sensor defaults to the current calibration value plus the adjustment value you enter. The Airmatic software does the rest based on the reading. This is the software version of links (or adjusting the sensors manually via spacers/bending or other manipulation)
But anytime the car gets lowered the suspension geometry/travel is impacted. The lower you go, the more the ride quality is impacted.
The cool thing with ELM's is that you can adjust it until you find your sweet spot and it's about as cheap as links or similar. The wiring harnesses of the old modules were ridiculous...
Old Aug 5, 2018 | 11:53 AM
  #207
Wolfman's Avatar
Super Moderator
Never seen a dealer flag a lowered car unless it's slammed. If worried, a performance shop will likely do a better job on the alignment anyway.
Old Aug 5, 2018 | 07:15 PM
  #208
CALBenzo's Avatar
'18 E63S AMG
Yeah, that is just what the AMG tech told me (that the warranty for the suspension components would be voided). Regarding bringing it to an independent shop, that is a great idea! I was just thinking about bringing it to another dealer.
Old Aug 5, 2018 | 07:49 PM
  #209
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
One of the advantages of the eBay lowering module is that you can have it at basically any setting you want and when a dealer visit is called for, put it back to factory setting and take the module out when you give your key to the dealer.
I go to Firestone and can get a alignment every month ( I believe it’s $299 lifetime alignment ) when I have time. If road force alignment is needed, they can do that too for an extra charge of course. Dealers charge like $199 for a one time alignment and keep in mind, dealers aren’t alignment experts like Firestone.
Old Aug 6, 2018 | 06:48 AM
  #210
soulsea's Avatar
☐ Rekt ☑ Not Rekt
If anyone wants to buy my unused ebay one for $300 shipped to the US lmk.
Old Aug 6, 2018 | 11:57 AM
  #211
CALBenzo's Avatar
'18 E63S AMG
Thanks for the tip, as I will try them. It sounds too good to be true. How do they not lose money on this??
Old Aug 6, 2018 | 12:58 PM
  #212
jkob5's Avatar
19 E63s
Question for anyone who has the ebay or the rentech... I would like to know if it's possible to have the car lowered only when parked. I'd like to have the car stock height for driving (houston roads, trust me), but lowered when parked, and I'd like it to be automatically done. Is this possible with either one?
Old Aug 8, 2018 | 02:14 PM
  #213
Mandarin's Avatar
e63s
I have eBay one and you can not do it with that module. But you can plug it in every time you parked your car ))) What the point to have lowered car at parking?
Old Aug 8, 2018 | 02:32 PM
  #214
jkob5's Avatar
19 E63s
Just for the looks. How easy it to lower the car using the module? Just a few seconds? Renntech tells me thir module cannot do what I want so probably will just get the ebay one since neither can do what I want.
Old Aug 8, 2018 | 02:39 PM
  #215
Mandarin's Avatar
e63s
Oh ok. It takes about a minute or so but I'm thinking this is really not convenient to do it every time before parking and leaving. You can check a video on eBay seller has it there.
Old Aug 8, 2018 | 06:07 PM
  #216
jkob5's Avatar
19 E63s
Yep, it will have to just be for parking at car events ha.
Old Dec 28, 2018 | 04:15 PM
  #217
s26singh's Avatar
2015 Toyota Corolla LE
Giving some thought to lowering and putting on spacers.
@@jdhertz11 - 15 mm drop front and 20 mm drop rear sounds pretty good to me. How would you compare ride quality with this degree of lowering via module in comfort VS no lowering (no module) and suspension in sport+ (which to my understanding also lowers car by 15 mm)?
Old Dec 30, 2018 | 02:40 AM
  #218
Mike Youngs's Avatar
How is your guys experience with the meat lowering module ? I’m about to get one but I’ve heard some good and bad things about it .
Old Dec 30, 2018 | 03:31 AM
  #219
S63AMG888's Avatar
I know most people who uses the eBay lowering module has had some success, but I’m not one of them. First module didn’t work and the second one threw all kinds of warnings on the dash. Dealer said a code was stored that was through the OBD port that messed up the car. Car went into limp mode, check engine light.... The car is all stock, just the lowering module. I’m done with this module, not worth it to ME.
Old Dec 31, 2018 | 11:18 AM
  #220
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
Ride quality remains stock..
Old Jan 7, 2019 | 03:39 PM
  #221
S63AMG888's Avatar
Originally Posted by ronin amg
I went the Benzworks route with oem sensor adjustment and have zero issues.
This is my car with spacers at sport+ ride height, zero rubbing on rough roads.
Once it's set there is no need for any other adjustments, all oem height functions raise/lower with the push of a button..
Hi. I plan on going to Benzworks to have the OEM sensors adjusted as well. So how does it work exactly, do you need to be in sports+ mode for the car to be lowered ? Can you still retain the right height adjustment where you can raise the car?
Did you get any cell or service issues?
Thank you.
Old Jan 8, 2019 | 11:41 AM
  #222
ronin amg's Avatar
Thank you.
Hello can you hear me now ?
Let me update you, I bought the Ebay module after I had to have an air spring replaced but to have it done under warrantee I needed to return the car to stock ride height.
This was a really pain in the *** with the benzworks sensor adjustment.
The Ebay setup is clean and easy to return back to stock ride height for dealer service.
Zero issues..full warrantee..
Old Apr 14, 2019 | 02:32 AM
  #223
LeonPhelps's Avatar
2019 E63 Wagon
Does the ebay module work on 2019 E63 ?
Old Apr 14, 2019 | 11:46 PM
  #224
jkob5's Avatar
19 E63s
yes, flawlessly
Old Apr 25, 2019 | 01:47 PM
  #225
JODE63's Avatar
e63 Wagon | Porsche 993 Turbo | Ferrari F355 GTS, Defender 130
Ohhh I can't wait to get my e63! I'm thinking I should take the lowering module to Germany when I pick it up and do it straight away... ��
