RIP 2018 E63 - Lemon Law Buyback Completed
Old Oct 30, 2018 | 04:21 PM
  #126
PeterUbers's Avatar
Originally Posted by E634Me
Yes, I think so.
All cars have issues, some more than others. I've had several recalls on my Honda Odyssey. Two different safety related ones for seats, plus airbags, and something else. Truck and Jeep have both had a couple recalls.
Can't think of one car that didn't have something. Had a '79 Mustang Cobra with 5.0 V8 that had a design flaw in the transmission that they never recalled but did issue a service bulletin on some time after I had already spent $1300 on repairs with Ford - at least the repair was lifetime warrantied and the local dealer had to fix the tranny twice after that before I found the service bulletin and showed it to them. After that last fix it was fine.
So far, my problem seems to be resolved - though, I did drive the car for quite a while before it popped up in the first place, so perhaps too early to say its fixed for good.
all cars have issues yes... very few of those issues leave you stranded on the side of a road ... that's where I have issues with car "issues." Look at the takata airbag issues ... those are theoretically catastrophic problems but the car is driveable
im not willing to have a CEL that makes me call for a tow or at least worry enough about damaging the engine to have to resort to a tow
my Acura had three trans issues and was lemoned but it never left me stranded.
Old Oct 30, 2018 | 04:44 PM
  #127
s26singh's Avatar
2015 Toyota Corolla LE
FYI - My 2017 Honda CR-V has an engine problem causing it to lose power and go into limp mode. Apparently its a very common issue with this new gen CRV; some people have reported complete stalls. I've experienced the limp mode once so far - lasted only seconds - and no CEL came on. There is no fix right now - Honda is working on it, and they hope to have something by mid-November.
Old Oct 30, 2018 | 05:52 PM
  #128
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Originally Posted by ItalianJoe1
Those are the first steps they give in any misfire troubleshooting anyway. There have been some cracked manifolds on cars but largely I don't believe there are air leaks causing this. The plugs have to come out to look in the cylinders anyway so plug/coil replacement is normal (coils move from front to rear pairs, not replaced by default). Injector replacement isn't major surgery, just more brackets and things over them but even the coils are hard to get to. Having done them on the S63, it's not difficult, but it is a lot of small things to move. Warranty time is almost 4 hours per side to remove the fuel rail. It only pays 3 hours to remove the dash panel, so that's a lot for warranty work.
Why are you removing the dash panel? Anyway, MB has another two weeks from me before we start a buyback. I only have this one car and im not interested in having it laid up in the shop for 3 weeks while a PTSS case is opened and people start disassembling the car in the hopes of finding something. As I said, 2 weeks and no CEL when keeping the car out of 4 cylinder mode. I'll let the tech and the engineers play with the diagnosis and "fix" on someone else's dime.
Old Oct 30, 2018 | 06:30 PM
  #129
V70cat's Avatar
535XIT, E63S
H what am I missing if you don't have cel, what is your issue?
Old Oct 30, 2018 | 06:35 PM
  #130
HBerman's Avatar
If I allow the engine to go into 4 cylinder mode, I will get a CEL within 1 day! I then go to the shop to get it cleared. My service manager told me NOT to use ECO mode because of the CEL issue.
Old Oct 30, 2018 | 06:43 PM
  #131
V70cat's Avatar
535XIT, E63S
Sorry to hear, has your dealer sent the car data to AMG Germany, do they have a fix?
Old Oct 30, 2018 | 06:57 PM
  #132
E634Me's Avatar
Veteran: Army
2018 E63S AMG
The CEL never left me stranded. In the couple instances where I could feel a misfire and power reduction shortly after start-up, I was either still in the parking lot or just about to the first traffic light. Put the car in park turned it off / on and misfire went away. In a couple of cases the CEL went away too. But I think that if the car senses another episode within 24 hours the temporary code turns into a permanent code that doesn't reset when you cycle the engine power off/on.
Old Oct 30, 2018 | 07:00 PM
  #133
HBerman's Avatar
​​​​​​The CEL is due to software, not hardware. I've been instructed to keep the ECO off and to wait for the software update. They do not want to tear down the engine only to spend hours changing parts that are not the problem. Do you have some other input here? Twice the car has shut off cylinders when the CEL comes on. I don't believe that the car is reliable at this point. They've offered me a loaner while the car is parked in their shop. After 3 weeks, no software update.
Old Oct 30, 2018 | 08:44 PM
  #134
ItalianJoe1's Avatar
2003 CL 600
Doesn't this support my thesis that the fuel injectors are the probably the fix but because of labor cost MB is slow to do that?
One injector cost more than the labor to change any amount of them.
They don't care about the cost, they write that off. The dealership gets paid to fix the car, not an issue.
The problem is, they (AMG/Engineering) aren't really sure what is gonna fix it permanently so they are hesitant to let us throw parts at the cars if it isn't helping, as that will only cause more problems.
Old Oct 30, 2018 | 08:45 PM
  #135
2003 CL 600
Dash panel was just for reference. People think "oh 4 hours isn't much", but it's huge in MB warranty times.
Old Oct 31, 2018 | 01:45 PM
  #136
bsmall1623's Avatar
Current: 2018 GLC63 Retired: 2015 S550, 2012 cls550
I have a 2018 GLC63 and i just took it in for same misfires... cylinder 1, they just swapped out all of the spark plugs and said they didnt like the way they look. Im at 1400 miles and headed over to pick up the car now.
Old Oct 31, 2018 | 02:00 PM
  #137
HBerman's Avatar
1400 miles and the spark plugs are shot? Weird!
Old Oct 31, 2018 | 02:16 PM
  #138
bsmall1623's Avatar
Here is the report from my glc63 (same engine) that I just picked up from service.
Old Oct 31, 2018 | 02:17 PM
  #139
bsmall1623's Avatar
I guess they only replaced cycl 1, my advisor originally said all of them. Who knows.
Old Nov 3, 2018 | 12:53 PM
  #140
E634Me's Avatar
Veteran: Army
2018 E63S AMG
CEL was back this morning
Old Nov 3, 2018 | 01:01 PM
  #141
V70cat's Avatar
535XIT, E63S
Sorry did they change the fuel injectors yet?
Old Nov 3, 2018 | 02:54 PM
  #142
2012 merc amg's Avatar
2018 S560
Oh man, that sucks. I do recall that they changed injectors on E63's car. I think my original theory has something to do with it. When you get in the car turn the ignition on to the run position by not hitting the brake to start and then turn off the Eco mode button (on the right side of the center console) then hit the brake and start the car. My car still has had no check engine lights. I have not done this procedure all along but do it now to be safe. I really believe this the reason the 2019's are being held up is because of this issue and I believe a software update is not far away and will take care of any future issues for all the 2018 and 2019 E63 Amg's.
Old Nov 3, 2018 | 02:58 PM
  #143
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I'd have to go back and look at the service record. They did so much it's a bit difficult to wade through. They for sure swapped them around and recalibrated them.
Checked with the code reader after I got back from my errand this morning. Same random misfire detected C0300 code, and C0301 and C0306, cylinder 1 and 6 misfires, but now there's also a C0308, cylinder 8 misfire.
Will call the dealer Monday and register the issue, but at this point I'm not inclined to take the car back in.
Old Nov 3, 2018 | 04:07 PM
  #144
jkob5's Avatar
19 E63s
Thought about starting the lemon process??? Cylinder 1,6 misfire, mercedes has not shown they can fix this.
Old Nov 3, 2018 | 05:52 PM
  #145
HBerman's Avatar
Exactly what my service manager told me would happen even if they changed all of the parts that Germany wanted. The only valid fix that they made on one of the cars was for a cracked intake manifold (which is made of plastic). Until the software fix is released, the cars with CEL are basically unfixable.
Old Nov 3, 2018 | 10:38 PM
  #146
V70cat's Avatar
535XIT, E63S
Joe, not try to give you a hard time but if changing the injectors seemed to fix my car isn’t that indicative of a problem related to the injectors?
Old Nov 4, 2018 | 07:58 PM
  #147
2003 CL 600
It's related to the injectors, yes.
We use the same part # injector in EVERY engine, 4/6/8 cyl, AMG, regular cars, whatever. So they don't magically know that they are on cyl #1 and #6 in an E/S63. It's software related in regards to the injector coding values. If you get the right combination they seem to work ok, from what I see on the current case we have open at our dealer, they want us to put very evenly matched injectors in the car (had us order 12 to only replace 2 to get matching IMA codes), so it's something with the fine pulse management but not necessarily a defective injector issue or it would be happening in cars all over the place.
Old Nov 4, 2018 | 08:49 PM
  #148
PeterUbers's Avatar
I imagine there are CEL's during factory testing of these cars and those cars get some type of work before coming to the states or destination for "sale as new car"
Old Nov 4, 2018 | 09:40 PM
  #149
HBerman's Avatar
I understand what you are saying, but pragmatically it is likely that every E63S will eventually get a CEL more than once. It also doesn't explain why some cars experience CELs at low mileage and yet others only above 7000 miles. The whole thing still appears to be black magic. I got another CEL as I was entering the interstate and the cylinders shut off. I pulled over to the side and restarted the engine and the CEL cleared. This makes me feel that the cars is unreliable in its current state of operation.
Old Nov 4, 2018 | 11:12 PM
  #150
2003 CL 600
The first one I saw, the electronic records showed the misfires and CEL during the PDI, so it had to be on at some point before delivery I would think, yet it made it?
