W213 E63s RMS Leak
Old Aug 23, 2024 | 10:30 AM
  #376
twist-a-grip's Avatar
I'm being a little lazy here as I did not read the whole thread. Changed my oil yesterday using a youtuber for guidance - I checked the RMS as he advised and I had a very light amount of oil residue where he said to look. Everything I have read so far says this is more common on 18-20s with around 50k miles and you definitely know you have an issue due to oil drips on the floor. I have a 21 with 5k miles and have no drips on the floor, just this light residue. I'm taking the car to a mountain home that is 3-4 hours from the closest MB dealer, so, if needed, I'd prefer to get the issue fixed under warranty and while I'm nearby numerous dealers. Do y'all see anything alarming here?
Old Aug 23, 2024 | 11:59 AM
  #377
chassis's Avatar
2017 GLE350 4MATIC
It’s leaking.
Old Aug 23, 2024 | 12:05 PM
  #378
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by ML550Cruza
Adding another 2019 E63s with 13,754 miles to the mix. No RMS oil leak (bone dry).
Just recently installed the E63 motorsports dual catch can in hopes of preventing any RMS leaks in the future. Time will tell.
Does anyone know if the majority of RMS failures are due to excessive positive crankcase pressure or negative (vaccuum) pressure.
I recently measured my crankcase vaccuum at warm idle of ~16 in of water (~1 in of Hg) which from what I have researched is within normal engine parameters. Curious if anyone has seen or measured or is aware of RMS failure due to excessive crankcase negative (vaccuum) pressure. If so, what values would be considered excessive and be at risk sucking in oil seals vs pushing them out.
Do you mean -1” Hg? That is fairly mild vacuum.
-5” Hg is normal on the current gen EA839 2.9TT Porsche engine. Quite high crankcase vacuum at idle measured at the oil fill cap. The fill cap is sucked onto the fitting and idle speed at idle speed is unstable with the fill cap removed while the engine is running.
The entire crankcase ventilation situation with modern engines is not figured out yet by car companies.
Current gen German engine oil-vapor separators have a more sophisticated operating principle than in the past but, as usual, the car companies are tying to solve a NASA-level problem using $0.79 parts. The result is failed rear main seals on $180k AMGs because of the use of crummy cheap oil-vapor separators.
Old Aug 26, 2024 | 10:30 AM
  #379
ML550Cruza's Avatar
2019 E63s
Wondering if all RMS failure appear like the picture shown in "the leaky seal". That picture seems to show the seal being sucked in (towards the motor) and
not pushed out given the theory that clogged oil separators cause RMS to blow out.
Old Aug 26, 2024 | 10:46 AM
  #380
ML550Cruza's Avatar
2019 E63s
I measured ~16 inches of water which convert to ~ 1 in of Hg. Curious to see pictures of failed RMS to see if they are indeed
blown out (away from the engine side) or sucked in (towards the engine side). I saw one picture "the leaky seal" that appeared to
show a sucked in RMS.
Old Aug 30, 2024 | 06:23 PM
  #381
Bluesummer's Avatar
I'm looking at a 2018 with 50k miles and freshly repaired RMS from the dealership, would I be good for another 4 years and 40k miles down the road? Does dealership usually "warranty" repairs on these type of jobs?
Old Aug 30, 2024 | 06:28 PM
  #382
whoover's Avatar
'19 E63S sedan
Did they replace the oil separators? If not, the new seal will fail prematurely. Since replacing the separators doubles the cost of the repair, some owners/dealers, anticipating selling the car, will just replace the seal. You need to see proof that the separators were replaced with the updated parts.
Old Aug 31, 2024 | 01:52 AM
  #383
Bluesummer's Avatar
yes the oil separators are replaced, part number 87-12 and 88-12. The repair was all bill to dealer not the previous owner.
Old Aug 31, 2024 | 12:17 PM
  #384
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
So are the newer separators are a long term fix or do they just give more time until the seal fails?
Old Aug 31, 2024 | 01:30 PM
  #385
whoover's Avatar
'19 E63S sedan
Time will tell.
Old Sep 1, 2024 | 02:07 AM
  #386
Caro's Avatar
E63s
For those who have fixed the seal with out oil separators how long until it leaks again? Dealer denied the separators under CPO warranty and it ends on oct 5th
Old Sep 1, 2024 | 12:26 PM
  #387
PeterUbers's Avatar
I have yet to read about someone with this circumstance reporting a repeat RMS leak, doesn't me it won't happen but it's unclear the timeline that you're asking for as you stare down the end of your warranty ... you should consider an extended warranty (post 44 in following link)
https://mbworld.org/forums/w213-amg/...ml#post9023470
Old Sep 2, 2024 | 08:34 AM
  #388
chassis's Avatar
2017 GLE350 4MATIC
Not enough time in the field for repaired RMSs to fail a second time and to be reported here.
Old Sep 2, 2024 | 08:58 AM
  #389
ska597's Avatar
21 E63s wagon
Is it normal that the oil separators are not covered under the warranty but the RMS is? Is changing the separators that much more work when you’ve already got the motor disassembled? I’d probably just pay out of pocket and get that done too. At least that’s my plan when I eventually find myself in this circumstance.
Old Sep 2, 2024 | 09:31 AM
  #390
PeterUbers's Avatar
this is a relatively evolving issue and there is nothing standardized about how dealers are addressing it based on the myriad of posts on this forum
Old Sep 2, 2024 | 09:39 AM
  #391
chassis's Avatar
2017 GLE350 4MATIC
Agree with @PeterUbers . The general summary of posts on this site is that RMS failure is usually covered under manufacturer's warranty, and might be covered under a third party warranty. OVS failure seems to be mostly not covered. Sad, because OVS failure is the root cause of RMS failure.
OVS replacement would be "easy" if the engine is removed. I don't believe engine-out is required for RMS replacement.
OVS location at the front of a V8 engine generally means difficult access relative to radiator and intercoolers. DIY-able but time consuming. OVS parts are relatively cheap in the big picture, the cost for this job is related to the time for disassembly and reassembly of the many parts in a tight space.
Old Sep 2, 2024 | 12:09 PM
  #392
whoover's Avatar
'19 E63S sedan
Dealer replaced separators and seal under extended warranty for me. No questions asked. "SA: Of course we have to install new separators since they're the cause of the problem."
Old Sep 2, 2024 | 01:25 PM
  #393
PeterUbers's Avatar
common sense is not common.
Old Sep 3, 2024 | 01:15 PM
  #394
Bluesummer's Avatar
they told me the same thing
Old Sep 3, 2024 | 01:21 PM
  #395
I really hope my local dealer is on board with that. I just dropped my 2018 off at an independent service company as it started leaking oil. They're going to take a look and see what's up with it. If it is the RMS, then off to the dealer (still have 6 months on the extended warranty). It would be nice to have the separators covered too.
Old Sep 3, 2024 | 04:16 PM
  #396
Yes, it's the RMS. Independent quoted ~$2-3K to repair (not including the separators). I'm dropping it off at the dealer on Thursday.
Old Sep 3, 2024 | 06:53 PM
  #397
Big Sam's Avatar
e63 AMG
good price. Not exactly sure how it compares to separators, but that’s cheapest RMS I think I’ve seen in here. (dealer I bought car from did RMS for free)
but separators were just shy of 5k for mine
Old Sep 4, 2024 | 02:26 AM
  #398
Bluesummer's Avatar
I thought you would like this Used 2018 Mercedes-Benz E 63 AMG S for $59251 on Autotrader http://atcm.co/S2PVDP/2B3B2CCE.
I think this the lowest I’ve seen so far
Old Sep 11, 2024 | 02:40 PM
  #399
Dealer stated the RMS and one of the separators were leaking. All covered under the extended warranty and they'll be replacing both separators. I'm at about 38K miles. I'll report back when they're done.
Old Sep 11, 2024 | 03:56 PM
  #400
PeterUbers's Avatar
when you ask the tech if this could happen again - what do they say?
