W213 E63s RMS Leak
Old Sep 11, 2024 | 04:49 PM
  #401
bobblehead's Avatar
go fast grocery getter wagon
when you ask the tech if this could happen again - what do they say?
“a repeat customer is a good customer to us” 😆
Old Sep 12, 2024 | 10:29 AM
  #402
whoover's Avatar
'19 E63S sedan
My SA told me the updated parts, both seal and separators, "should" solve the issue. I think only time will tell.
Old Sep 12, 2024 | 11:21 AM
  #403
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
I don't have access to the tech. That said, it's obvious what they would say.
Old Sep 12, 2024 | 01:17 PM
  #404
PeterUbers's Avatar
thank you for this feedback; indeed time is the test
Old Sep 14, 2024 | 11:42 AM
  #405
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
So... what happens if you just let the RMS drip and solve the separator issue that is causing the higher pressure...
The only reason I ask is on my Aston Martin I had a weeping seal on the engine and the dealer suggested I monitor it... It drips or weeps occasionally and that was 4 years ago and they have not recommended taking things apart.
Old Sep 14, 2024 | 12:01 PM
  #406
chassis's Avatar
2017 GLE350 4MATIC
Interesting thought.
If the RMS fails by excess crankcase vacuum and yields (gets sucked in and creases), hard to guess if the seal either pops back into place or not, or if it pops back into place whether a persistent leak would be present or not.
If the RMS fails by excess crankcase pressure (“blows out”) the theory could be that the RMS returns to its proper shape and seals more or less properly.
The first failure mode is more potentially damaging in my view.
Replacing the OVS never hurts and always helps in my view.
Old Sep 14, 2024 | 01:53 PM
  #407
whoover's Avatar
'19 E63S sedan
These seals fail catastrophically. Huge hunks of seal deform. It won't be long before the small leak becomes a huge mess.
Old Sep 14, 2024 | 06:11 PM
  #408
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I am calling BS on this. I have seen seals like this go a very long time and if anything the leak gets only slightly worse over a very long period of time. The downside is you do have a constant drip of oil that can make a mess of the underside of your car.
Old Sep 14, 2024 | 06:45 PM
  #409
whoover's Avatar
'19 E63S sedan
Look at the last pic in https://mbworld.org/forums/w213-amg/...ml#post8953926 (from this thread). The seal lip is totally deformed. Everyone gets to decide what their garage floor looks like, I guess.
Old Sep 14, 2024 | 08:10 PM
  #410
chassis's Avatar
2017 GLE350 4MATIC
This seal is finished. Any similar failure means the seal is toast.
Old Sep 15, 2024 | 08:02 AM
  #411
whitewagon's Avatar
the lip on that seal is soo thin... what a waste in trying to save a few bucks for such a catastrophic failure...
do we know if they have improved the part or just replacing with the same POS
Old Sep 15, 2024 | 11:43 AM
  #412
whoover's Avatar
'19 E63S sedan
The seal and the oil separators have been updated.
Old Sep 15, 2024 | 01:45 PM
  #413
chassis's Avatar
2017 GLE350 4MATIC
It would be good to see photos of old vs new RMS and old vs new OVS to understand what has changed.
Old Sep 15, 2024 | 05:47 PM
  #414
whoover's Avatar
'19 E63S sedan
The link in my post above contains a side-by-side of the seals. I haven't seen any details about the separator upgrade. I imagine it's internal.
Old Sep 16, 2024 | 02:32 PM
  #415
Richiebell63's Avatar
Mercedes Benz e63s amg
Originally Posted by Bluesummer
I thought you would like this Used 2018 Mercedes-Benz E 63 AMG S for $59251 on Autotrader http://atcm.co/S2PVDP/2B3B2CCE.
I think this the lowest I’ve seen so far
I just bought mine in July from Michigan for $56,900 one previous owner and 33126 miles
Old Sep 16, 2024 | 03:28 PM
  #416
chassis's Avatar
2017 GLE350 4MATIC
The new RMS assembly is a clear cheapening by MB. Stamped steel carrier plate vs cast Al or Mg in the original design. Carrier plate has no influence on the plastic seal design imo. The photos show no discernible detail in seal lip or press bore.
Old Sep 16, 2024 | 05:16 PM
  #417
JM63S's Avatar
E63S
So does anyone have a tsb to give to the dealer for this to assure they understand the issue?
Old Sep 17, 2024 | 09:36 AM
  #418
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Originally Posted by JM63S
So does anyone have a TSB to give to the dealer for this to assure they understand the issue?
I don't believe that there is a TSB for the RMS failures. YMMV
Old Sep 22, 2024 | 03:00 AM
  #419
Wendall's Avatar
'18 E63 S Wagon, '99 SL500, '84 300D
Completed work from the local Indy. Took about a week, picking up the car first thing tomorrow morning. Will ask if they saw which OVS was cracked. Not a terrible deal all in all.
Old Sep 22, 2024 | 04:06 AM
  #420
PeterUbers's Avatar
and you got the updated parts - good for you
https://mbworld.org/forums/w213-amg/...ml#post9012993
Old Sep 22, 2024 | 04:19 AM
  #421
bobblehead's Avatar
Yeah. As expected, parts are not that expensive. It’s all about labor. 😢
Old Sep 22, 2024 | 02:58 PM
  #422
whitewagon's Avatar
A known failure point at a basic cost of 10% of the value of the car is really unacceptable.
Old Sep 22, 2024 | 03:22 PM
  #423
PeterUbers's Avatar
totally agree. And it's unclear if it will reoccur despite a repair with updated parts (or at least, parts with updated part numbers)
on the contrary, though this is very wrong, there are so many things about this engine and car that are so very right and enjoyable.
everyone will make that determination for themselves.
Old Sep 23, 2024 | 09:22 PM
  #424
SerottaD's Avatar
1993 300SL,2007 RAM 2500,2009 CLK350,2011 ML550,2016 McLaren 650S,2018 AMG E63s wgn,2018 AMG SLC43
This thread is surely in the running for longest post... somehow divided in two, perhaps by the system. Part 1 started on Mar 7, 2023. Part 2 started the month April and is still going strong in Sep 2024.
Given the parts aren't terribly expensive, it's almost a good idea to order all the parts--hardware, seals, bolts, oil separator--and put it in a tub. Or, since RMS leak is not catastrophic, buy all the parts, have them at the dealer under your name (like any part order), and then drop the car off for the operation when all the parts are in hand. I'm sure the technicians don't like to start and stop a job. I know I don't like it in my work. So much effort coming back up to speed after each delay.
Old Sep 24, 2024 | 12:57 AM
  #425
whoover's Avatar
'19 E63S sedan
All the parts were in stock at my dealer.
