The Life and Journey of a 2023 Mercedes-AMG E63 S Wagon
Old Feb 17, 2025 | 07:39 PM
  #551
W205C43PFL's Avatar
Originally Posted by I.T. Guy
Thank you
I use the MICHELIN Pilot Alpin 5 snow tires
They are great. This time the snow was just far too deep! Car surfed off the ground via the under trays. Hard to get traction with wheels in the air.
Buffalo gets a lot more snow then we do! We are about an hour from there and about 40 mins from Niagara Falls NY. We cross a few times a month for the best pizza and wings
Backyard was pretty wicked during the storm
Actually, you got me curious, doesn't mounting the front plate there restrict air flow?
Old Feb 18, 2025 | 10:58 AM
  #552
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
I grew up in that stuff. I'm now in CA and the only snow I see is on the news or the internet.
Old Feb 18, 2025 | 12:13 PM
  #553
W205C43PFL's Avatar
You also get the nice lemon laws whenever you need them.
Old Apr 9, 2025 | 05:08 PM
  #554
I.T. Guy's Avatar
2023 E63S Wagon
Service A
Oil Change, Brake Fluid Flush, Air Filters, Rear Dff Oil Change, Transmission Oil Change
They wrote "Minor oil leak from front differential, recommend reseal". Bugger that I just read this on the report at home - I will have to ask if this is a warranty thing.
Vroom Vroom! If the weather breaks it's time for summer shoes!
Old Apr 9, 2025 | 05:16 PM
  #555
bobblehead's Avatar
go fast grocery getter wagon
Would they not fix it on the spot ? It’s stupid to make you go back for this.
Old Apr 9, 2025 | 05:51 PM
  #556
W205C43PFL's Avatar
Service A
So strange it is leaking, not a common issue I don't think, if so, there must be a cause, no cracks in the casing right?
Old Apr 9, 2025 | 06:08 PM
  #557
PeterUbers's Avatar
Service A
as you recall this was common for the w212 2014+
How many miles do you have?
this will blow my mind if they don't cover this under warranty
- the front diff fluid is a non serviceable item for the 213, so how will they claim I wonder that this is not warranty item
File Type: pdf
Old Apr 10, 2025 | 09:06 AM
  #558
I.T. Guy's Avatar
2023 E63S Wagon
All good points
The more concerning thing to me is usually my SA will point stuff like this out, I found out only by reading the papers after getting home. I hope just an honest busy/oversight.
Remember they did replace my whole transmission, I wonder if the leak is from that?
I texted my SA back, confident all will be good. Keep you all posted!
Old Apr 10, 2025 | 08:05 PM
  #559
I.T. Guy's Avatar
2023 E63S Wagon
SA was calling me today to tell me as he forgot yesterday, and when I'd like it done. Booked under warranty for next week.
Oakville Autohaus for the win again!
We all get busy sometimes... it's all good. And note to self - read the **** I sign
Old Apr 10, 2025 | 10:13 PM
  #560
W205C43PFL's Avatar
All good points
Curious what caused the leak will wait for your update after the repair : )
Old Apr 11, 2025 | 08:32 AM
  #561
I.T. Guy's Avatar
2023 E63S Wagon
Who’s Number One?
lol
Old Apr 11, 2025 | 09:20 AM
  #562
W205C43PFL's Avatar
Who’s Number One?
lol
You : )
Old Apr 11, 2025 | 09:21 AM
  #563
W205C43PFL's Avatar
I guess also number 1 in line for checkout for all those groceries in the shopping cart.
Old Apr 21, 2025 | 08:53 PM
  #564
I.T. Guy's Avatar
2023 E63S Wagon
Front differential seal leak fixed!
LIFTED VEHICLE AND REMOVED ENGINE AND TRANSMISSION SPLASH PANELS FOUND FLUID LEAKING FROM FRONT DIFFERENTIAL. REQUIRES REMOVAL AND RESEAL.
DRAINED OIL FROM FRONT DIFFERENTIAL, REMOVED FRONT DIFFERENTIAL AS PER WIS INSTRUCTIONS.
RE-SEALED DIFFERENTIAL, REPLACED MAIN CASE SEAL, PINION HOUSING SEAL, PINION RADIAL SEAL AND BOTH LEFT AND RIGHT AXLE SEALS.
FILL DIFFERENTIAL WITH NEW OIL, RE-ASSEMBLED. CLEANED AREA OF OIL RESIDUE. PERFORMED WHEEL ALIGNMENT CHECK AND ADJUSTED FRONT TOE. ROAD TESTED VEHICLE, ALL OKAY.
Old Apr 21, 2025 | 09:08 PM
  #565
W205C43PFL's Avatar
Any idea why the seal failed?
Old Apr 22, 2025 | 06:22 AM
  #566
I.T. Guy's Avatar
2023 E63S Wagon
It’s a car?
So happy my Black Boost CPC module is still collecting dust on the shelf. Every time I get the itch to start tuning the car seems to need warranty work. Imagine the cost for the new trans and now this diff re-seal?
Anyone know if my CPC can be re-VIN’d for resale? I don’t think I’ll ever be brave enough to use it.
Old Apr 22, 2025 | 08:35 AM
  #567
W205C43PFL's Avatar
It’s a car?
That doesn't explain it and I don't think this is a commonly reported item on this car but fair enough as defects could be the cause.
Old Apr 22, 2025 | 09:09 AM
  #568
PeterUbers's Avatar
Monday car
Old Apr 22, 2025 | 12:09 PM
  #569
I.T. Guy's Avatar
2023 E63S Wagon
Monday car
This
Old Apr 22, 2025 | 12:28 PM
  #570
SM105K's Avatar
2019 E63S and 2014 CLS 63S
Monday car
I am starting to believe mine is as well.
Old Apr 22, 2025 | 12:33 PM
  #571
W205C43PFL's Avatar
Guess same as being a Friday car?
Old Apr 22, 2025 | 12:34 PM
  #572
PeterUbers's Avatar
Given that you're a revolving door customer (appropriately) with warranty work, you're wise not to modify this car in anyway. At least not in the warranty period. I wouldn't even put custom tire valve stem covers on it 😂
Old Apr 22, 2025 | 12:59 PM
  #573
I.T. Guy's Avatar
2023 E63S Wagon
This last time I was wondering, what if the dealer has just figured out a way to make money at it?
Why do some dealers try so hard to NOT to warranty work
And my dealer mentions stuff they inspect and find that I did not even complain about?
Anyone konw how Warranty Work billing works vs. just paying service customers?
Old Apr 22, 2025 | 01:19 PM
  #574
chassis's Avatar
2017 GLE350 4MATIC
Warranty work book hours are set by the car manufacturer. The manufacturer pays the dealer for warranty work, not the consumer, and the manufacturer has power over the dealer in this example. Warranty contract between consumer and manufacturer assures the consumer whatever is broken gets fixed. Manufacturer power over the dealer means the dealer needs to execute the repair in less than manufacturer book hours, if the dealer wants to earn a profit.
Manufacturers acting in self interest seek to reduce warranty book hours over time. Franchise agreement between manufacturer and dealer is the legal instrument through which the manufacturer exercises its power over the dealer.
A version of the warranty book hours and dealer protest to the same can be seen in posts on all German car fora, when third party warranty company representative make comments. Dealers, in their corruption, bill the third party warranty companies max book hours and at the same time tell the consumer the “covered” repair still costs them (the consumer) another five grand. Double-dipping by corrupt dealers. Let’s remember that nearly all employees in a dealer are paid commission.
Non-warranty work is somewhat subject to open market forces (oil changes, brake jobs) but generally is all-out consumer abuse perpetrated by corrupt dealers, who are protected by consumer-harming state-by-state dealer laws. In summary: non-warranty work is the Wild West and a no-bolds-barred invasion of consumers’ wallets.
Old Apr 22, 2025 | 01:43 PM
  #575
I.T. Guy's Avatar
2023 E63S Wagon
Last night I swapped on summer rims and tires and activated the lowering module.
A little better but not great.
The car is getting boring.
Ruh Roh
