Remote starter for Mercedes with Smartkey
I am interested in the long-range antenna packages as well as the ability to use my phone to start the car using cellular towers.
I'm waiting for this one.Also, don't get all defensive about your statement of not caring about the environment or not caring about the pollution your car puts out, it's not like like I said it.
Thank YOU sir.
The remote starter is probably reasonable when extreme cold starts are too rare to purchase the AUX heater and the remote starter is not used too frequently to spoil the engine.
AUX heater is a lot better for polution but that is probably not a significant argument in a country full of S65AMGs and similar cars.
) but I know it can be as cold as in my place at least at some parts of Canada (even colder). In this case you should really get familiar with the AUX heater idea, unfortunate that the local shops do not promote or even support the feature. Steve from MBenzNL installed one for an owner in Southern California.
anyway, to answer your question, yes the Smartkey Starter is shipping for the 08 GL, it has been out in the field now since January. I dont believe EuroMotorcars is a dealer of ours, i havent heard much about them...
W212 has been tested and is working on the coupe. All variants should work without issue but we still have a few that we need to test just to be sure. We should have those done in the coming weeks.
W463 (the G-Wagon) is also tested and working. We tested back to 2006 so far... still need to check some of the earlier models.
W220 is next up in line for testing. The 220 platform uses the same ignition system as the SL (R230) so we believe that the same system that currently works in the SL roadster will work in the older S but again we need to thoroughly test. Expect to see the 220 ready as a plug-and-play kit around september.
Here is some video of the starter in action:
http://www.youtube.com/watch?v=fQomtybKWqk
Here is video of the system in action:
http://www.youtube.com/watch?v=gk6-mfMr0is
http://www.youtube.com/watch?v=uiTmeQvZbio
