BRAKE Pad, Rotors, & Calipers Discussion Thread (OEM, aftermarket, etc...)
http://www.prostreetonline.com/pnsku/ebc-dp31191c.asp
http://www.prostreetonline.com/pnsku/ebc-dp31365c.asp
thay have direrent part numbers but fits the same model? i can't understand it? wich ones fits?
same pages says that i should have 2.3 engine and some says that 1.8?
your car has the sport package right with AMG bodykit and crossdrilled rotors? you need the second pads, the more expensive ones.
however, i don't recommend them. they squeak all the time even after i had the anti-squeal paste applied twice. their stopping power isn't as good as stock medal pads! only good thing is no brake dust now.
Fits:
Mercedes C230 1.8 Supercharged (European model) 2002-2005
Mercedes C230 2.3 2002-2003
Mercedes C230 2.3 Sport 2003-2003
Mercedes C240 2.6 -F150420/R023901 2001-2002
Mercedes C240 2.6 F150421/R023902- 2002-2004
Mercedes C240 2.6 Sedan 4-Matic 2003-2005
Mercedes C240 2.6 Wagon 2003-2005
Mercedes C240 2.6 Wagon 4-Matic 2003-2005
Mercedes C280 3.0 2006+
Mercedes C320 3.2 2001-2004
Mercedes C320 3.2 2005+
Mercedes C350 3.5 2006+
Mercedes CLK 320 3.2 2003+
Mercedes CLK 350 3.5 2006+
Mercedes SLK 280 3.0 2006+
Fits:
The only problem that I could see is when the brake line is hooked up to the caliper it would hit the drive shaft. And possibly when I turn the wheel it may hit.
Is it possible to make your own brake lines? I think that if I use a coupler on the caliper to redirect the line I should be okay.
I still have to do some testing, but it looks promising.
Oh, and damn these things are heavy. I hope my car has enough power to turn them
Looks good. My bad, bro. I took so long, but glad you found a set.
Whats the story with the M3?
Hahahah. Well, they arent on the car yet. There is still a chance that they wont work. I am hoping that I can get around the problem.
