Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Rating: Thread Rating: 64 votes, 5.00 average.
Old Nov 4, 2008 | 07:23 PM
  #1501
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
So as I've been in my search to upgrade my halogens to HID with projector headlights I was wondering if someone could explain the difference between single beam HID and bi-xenon? also if i buy a set of depo's are they set up for d2s or h7? im havin a hard time putting all of these thigns together for some reason?! lol...everywhere i see that bi-xenon aftermarket is for h4 and like 9007 and a few others while d2s, d2r, h7, etc are single beam...so which one to i buy if i get a set of depo projectors?
Old Nov 4, 2008 | 07:29 PM
  #1502
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Originally Posted by DarthR8er
Quick question--I just replaced my OEM halogen headlights with the OEM Bi-Xenons, does that mean I will need some time of harness that you guys are talking about? I haven't set my computer to Xenon-present yet, but they work great (no flickering or errors) as long as I turn on the headlights "before" I turn on the car. If I turn on the headlights "after" I turn on the car, I get flickering and an error message on my dash display. By the way, my car is a 2007 C230 sport sedan.
its always recommended that you use a harness if your car didn't come with hids stock. The newer oem ballast tend to use a lot less amps during start up and tend to warm more quickly.
You can probably get away with it since your using oem bixenons. Most people who buy aftermarket hids are the cheaply made chinese ballasts that tend use a lot of amps during startup and run really hot.
You can definately tell the difference between the oem and chinese ballasts..
Old Nov 4, 2008 | 07:32 PM
  #1503
TemjinX2's Avatar
single xenon is exactly what it denotes, a single low beam. Bi-xenon is a single low beam whose light shield can move at a press of a button to offer a high beam as well.
The depos are single low beam with a separate aux high beam..i believe its h7. Your going to need to get a h7 hid kit if you want to pplug them into the depo projectors. I would email the seller to double check if there h7's.
Old Nov 4, 2008 | 10:21 PM
  #1504
DarthR8er's Avatar
2007 C230 Sport Sedan
Where can I get this harness? Also, what type of harness do you recommend? Thanks for your help!
Old Nov 4, 2008 | 10:33 PM
  #1505
DarthR8er's Avatar
A couple more question: 1.)What is a ballast igniter? 2.)Is it something similar or does it work with in some way with the harness?
Old Nov 4, 2008 | 10:51 PM
  #1506
maverik259's Avatar
whered you get your oem bi-xenons? and i didnt know the bi-xenons were used as both high and low beams...what is the high beam light apparatus used for then? (aka the inner set of headlight sockets)
Old Nov 4, 2008 | 11:01 PM
  #1507
maverik259's Avatar
anyone have any experience with this kit?
http://www.kbcarstuff.com/Xtreme_HID..._2001_s/21.htm
Old Nov 4, 2008 | 11:03 PM
  #1508
maverik259's Avatar
Anyone have any experience with this HID kit?
If anyone has any recommendations as to the best kit and/or kit and projector combo, I'd much appreciate it!
Old Nov 5, 2008 | 12:00 AM
  #1509
hubertt's Avatar
BMW 520i, C180
Talking
I don't have experience with those but if I may recommend you....go to www.vvme.com they have the best prices and awesome products, I have their kit on my BMW for 2 years now and no problems at all. Plug and Play kits.
Old Nov 5, 2008 | 12:55 AM
  #1510
Gramma_Benz's Avatar
2002 C32, 2012 S550
Check this thread:
https://mbworld.org/forums/showthrea...875&highlight=
I asked the same question in the AMG Forum.
I think I'm gonna go for it myself. the light output may not be quite a good as my stock Xenon's, but they look sooo much better!!
Old Nov 5, 2008 | 01:59 PM
  #1511
DarthR8er's Avatar
I got the Bi-Xenons from the classifieds. I got them at a very reasonable price so I knew I was taking a chance. But so far, they work great!
Old Nov 5, 2008 | 03:42 PM
  #1512
maverik259's Avatar
ya me too...and i really doubt the light output is all that worse?! how could it? is it the ballasts or what?
Old Nov 5, 2008 | 03:57 PM
  #1513
maverik259's Avatar
ya im trying to find a set of bi-xenons myself...how much did you end up spending?
Old Nov 5, 2008 | 04:06 PM
  #1514
Ryanr317's Avatar
R129, XF Sportbrake, SC400
The light output is not THAT bad but it is nowhere near stock. It is because the projectors suck. It has nothing to do with the bulbs nor the ballasts.
Old Nov 5, 2008 | 05:44 PM
  #1515
DarthR8er's Avatar
I paid $650 for both.
Old Nov 5, 2008 | 08:07 PM
  #1516
TemjinX2's Avatar
i was talking about something like this..
http://store.theretrofitsource.com/p...cc32244a3f5d8c
at $25-30 its not horribly expensive for piece of mind. Given you have oem, you should be fine though. The newer oem hids are pretty efficient.
Old Nov 5, 2008 | 08:11 PM
  #1517
TemjinX2's Avatar
the ignitor is what it sounds, it ignites the crystals within the bulb..the ballast feeds power to the bulb after its been ignited.
HIDS basically use two crystals that discharges current between them to give off light. Halogens run current through a metal filament until it gives off light. HIDS are more efficient once they get up and running but just cost more to produce.
The harness just draws power directly from the battery and only used the head light harness to tigger the lights, so the only thing you can burn out is the $25 harness.
  #1518
TemjinX2's Avatar
thats a pretty smoking deal.
Old Nov 5, 2008 | 09:44 PM
  #1519
maverik259's Avatar
dang man thats a really good price, something i'd jump all over which im sure you understand! lol
Old Nov 6, 2008 | 12:06 AM
  #1520
DarthR8er's Avatar
My car is up for sale. You can check it out on ebay. The item# is 170276813556. I'm shopping around for a white C63 AMG with two-tone leather interior. I'm gonna place it in the classifieds tomorrow. Let me know what you guys think...
Old Nov 6, 2008 | 03:48 AM
  #1521
TemjinX2's Avatar
why bother installing them? why not just resell them?
Old Nov 18, 2008 | 02:24 AM
  #1522
maverik259's Avatar
what exactly is involved with the "kit" for the piaa tera 6500/5500/etc...is it not just a simple plug n play bulb like any other LED wedge bulb?
Old Nov 18, 2008 | 12:07 PM
  #1523
cntlaw's Avatar
C55AMG W203; 330i E90
Originally Posted by phranksmbz
which do you guys think would match best w/ piaa 6600k? (TERA'S)
So yeah maybe the 5500k would go ok, what do you guys think?
Yes, 5500K can still match the 6000-6200K HID.
Don't worry about if Tera 6500K is blueish, everyone told me they look great on its own.
Yes, they are plug 'n' Play with Built-in Resistor to avoid error code
Six months ago, I saw (@Car-gym) Piaa Tera has a new version with a 'adjustable' resistor which may be safe to cope with any 'exception'.
t
Old Nov 18, 2008 | 01:02 PM
  #1524
billbugger's Avatar
C230 Kompressor Sport Sedan
Originally Posted by JamE55
It looks pretty bright. Where did you buy them? Was it sold as a kit? How hard/long was the install?
Sick ride! Anymore pics??
Old Nov 20, 2008 | 01:21 AM
  #1525
e1000's Avatar
a quarter mile at a time
HID Crazy!!!!!!!!!!!!!! (The Official w203 TOW Thread)
First it was LED, now it's HID.
Just got done installing 4300K HID High beams and 4300K HID fog lights
I'm tired. Going to sleep. Pics to come tomorrow.
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
