DIY: M112 Spark Plug R&R
I've ordered from HF before and need to figure out how they ship stuff. I've ordered from them in the past and they seem to use Parcel Post which is a friggin' disaster to the East Coast...
I recently changed my spark plugs and I can feel the difference at idle - my car's idle is MUCH more stable (the RPMs do not change at all). Furthermore, I have definitely been getting gas mileage similar to when I first got the car. This task is well worth it!
I did not use any of the tools listed in this thread, but I did use a 17mm deep socket wrench to remove and reinstall the wires. As for the plugs, they just took some time and I can see how the tool that splinter posted would be very beneficial for people w/ larger hands working on the rear plugs.
pm me for tips,those pliers make the job so much harder and on the C320 Getting into the boot TruTaing would still be trying to finish the job
m112 and m113 non sc engines use NGK 7090 plugs oe specs and only about $2.75 each.
ohlord
one more addition .Never use anti seize on the new plugs they are plated at the factory and no anti seize is required anymore.
1. Can C320 2001 using Iridium IX for the spark plugs replacement? Or I better to stick with the original one?
2. Do I need to change the sensor when I change the plugs?
No sensors need replacement with a plug change.
Bosch F 8 DPER,
Beru 14 FGH 8 DPUR X 2, or
NGK IFR 5 D 10
MB part number is 004 159 94 03
The C32 has NGK IFR 6 D 10 as original equipment.
MB part number is 003 159 97 03
MB’s spark plug socket, 112 589 01 09 00, helps to make the task easier.
Have available some anti-seize lubricant and dielectric grease.
Raise the hood to its full vertical position. Remove the engine cover and air filter assembly...https://mbworld.org/forums/showthread.php?p=1227088
Remove the coil packs. Each is secured with a single #27 TORX fastener.
Use an 18mm open-end wrench on the spark plug wire connector, leveraged against the cam cover, to pull it free of the plug. It helps to reduce the force required by slightly rotating the connector before removing it. Do not place any undue stress on either the sparkplug wires, or the coil pack wires themselves.
Lay them on the intake manifold.
The plugs are now as accessible as they will ever be. To get them in and out is done mostly by feel, rather than sight.
Here's the ratchet, extension, and socket combination used to reach all twelve plugs. YMMV. The plugs nearest the firewall necessitated fitting the socket to the plug first, and then connecting the ratchet.
Use compressed air to blow any residual debris from each plug recess. Remove the old plugs.
Prepare your new plugs for installation by first verifying their gap. Specification is 1.0 mm/.039 inch. While some may argue with the anti-seize step, I’ve used it successfully for three decades. The rationale is merely to lubricate the respective threads. Because the steel plug is threading into aluminum, it’s obvious which is the stronger of the two. No reason to turn a pleasant plug swap into a Heli-coil repair job.
Rub a very modest portion into the threads. Keep it well away from the firing tip so as not to cause misfires. The washer area of the plug should remain uncoated as well, so that it can properly conduct away its heat, thereby helping to avoid pre-ignition.
Nevermind about the 'nail!
Place a dollop of dielectric grease on the tip to improve conductivity, and help inhibit corrosion.
Thread the new plugs initially by hand to avoid any chance of cross-threading. Because you’ll be compressing a new washer, just get them fully seated on the first attempt. Torque them to 15-22 ft.lbs./20-30 Nm. It will require ~¼ to ½ additional turn to yield the proper reading.
I like to get them snug, then go back to gently sneak up on the correct torque. Go around on all twelve again to establish their final torque and verify your work.
great post
thank you !
As a newbie here and a potential MB buyer, the last thing I want to do is come across as a smart a$$, but I must comment on the use of dielectric grease to "improve conductivity." It won't - it's completely non-conductive. I've used it when changing spark plugs for years, but on the boots (spreading it around with a thin screwdriver), not the plugs, to keep them from sticking to the plugs and to make removing the boots the next time easier.
I'm also very careful about anti-seize on plug threads, as the OP mentioned, it's controversial. The problem arises when torquing steel threads into an aluminum head. Torque specs may be exceeded dangerously when lubricated, causing damage to the aluminum head. It doesn't sound like you can get a torque wrench down there, so it probably doesn't matter in this case, but I understand Bosch plugs are pre-coated with anti-seize and anti-corrosion so probably don't need it. (FWIW, anyway; I've never used Bosch plugs in the other cars I've owned.)
Again, I don't wish to cause offense, and I certainly don't know everything there is to know about DIY car repairs.
Thanks,
Thanks,
TY
Great writeup! Thanks for the effort.
Mike
For me the hardest part was to put the connectors back and be sure they were in all the way. Had to use the same 18 or 17 mm wrench and tapped on it with anything that could fit the narrow space. Big pain in the neck...
Nobody commented on this part so I'm wondering if there was a trick I didn't know.
Luca
http://www.oreillyauto.com/site/c/de...3435&ppt=C0334
Thanks for the helpfu FAQ
Will post results after a few weeks of
Thanks!
