Black top, a little disappointed.
'05 C230K SS Granite Grey Metallic
Well, to follow up my faux cf diffuser that was received relatively well, I tried the same vinyl wrap product on the top, but in black. I was hoping to get the same result as painting it, but without it being permanent. All I can say is I should have painted it. Oh well, so much for trying something new. Live and learn.
What's wrong with it? I was thinking about doing that also since I don't trust that repainting the roof will be as good as factory paint running the risk of fading and oxidizing.
The pictures hide a lot, but if you had a painted roof parked next to it, it would be quite obvious. It's just not as reflective or glossy as I would like it to be. It's not bad and to some it might still be worth it. I'm sure a lot depends on how picky you are.
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
painting it will be better then a vinyl. When I did mine I did 5 coats of black and 3 coats of clear. However, just by force of habit, I waxed my car every time I washed it. Mine had a lot of depth.
Points for tryin somethin different. But I'm kinda with you on it...
Is it because of the vinyl that you used? Any air bubbles?
No doubt there are different types of vinyl and I don't know where this one falls, good, bad or otherwise. There are a few very small air bubbles, about 1/8" or smaller and they should go away after a few sunny days just like tinted windows.
Thanks, the more I look at your car, the more I like it. I don't understand why the Canadian sport models are different from the states. Anyway, I'll probably get coilovers and wheels this spring/summer, but I'm not convinced bi-x are worth the money for me.
it got painted in early may. I got rid of the car in septemeber, but I gaurantee it will be like that [if washed/waxed] for a looooong time. My OpenSkye system is like that from the factory as well. Just gotta take care of it, as with anything. Also being that it was parked in the garage helps. wasnt exposed to the elements. good luck. keep us posted.
06 c230 v6 SS
where did you find vinyl that big? or did you use 2 sheets and seem them together?
ive always thought about doing this, but could never find a big enough piece of vinyl.
MBworld Guru
white and whiter
looks good. vinyl choice could've been better with those glossy type vinyls or even the CF vinyl this one company sells.
http://www.tiptopsigns.com/Vinyl-Sheet-p-1-c-22.html
