View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#4676
2006 C350 SS
ANYONE?? This sucks hahah I'm just running into problems left and right!!
Welll...they definately dont have any bolts...and after looking more thouroughly in the box...i saw that there is two different size "adaptors".
1 - 12MM
1 - 20MM
I think the 12 should cut it in the front but the 20 should be way to large ya?
Also...I needed a small spacer in the rear to prevent runbbing...5MM or so should cut this???
Im lost....once againnnn
1 - 12MM
1 - 20MM
Anyone have any further input? Sorry for all these posts and I'm attempting to do as many 'trial and error' ways I can...I now have the different size spacers and I'm going to run down to my tire place and see how these may work...
20 MM in Front way to large?
and 12MM in Rear...way to big as well?
Also, where can I find longer lug bolts or further hardware??
You guys dont know how much I appreciate the help! You're saving me a lot of time and headaches for the most part! Thanks again!!!
I just want my rimsss onnnnn!!!!!
-Chad
#4677
MBworld Guru
white and whiter
-Chad
-Chad
12mm is going to be way to big with your ET32 offset on the front 8.5 wheels. I would suggest a custom 8mm or less.
did you put the wheel on and physically measure the missing space that would allow you to clear the caliper?
to tell you, my Axis Phin was 19x8.5 ET32 and I had the wheel centerbore machined so that it could fit a hubcentric 8mm spacer on it. The front wheel was flush with the fender, BUT the tires was sticking out and that is with a ET24. The car only had RENNtech springs back then, so it wasn't that low, but if I had gone any lower I would've run into serious problems. I have a picture somewhere I'll look it up and post it for you.
to run 12mm with your ET32 offset is completely stupid period.
here is that pic...can't find the original, but you can see the tire's sticking out
#4679
Frank, I'm hoping you can give me some help...in case you didn't see my post in the main forum.
19x8.5 et35 with 235/35 is hitting the Tein's. It appears that from reading I need about an 8mm spacer....which is not standard. I'm not sure if I should do an 8mm anyway from wheeladapter.com or just go with a standard 10mm from H&R for example. I also have the option of swapping out my 235's for 225's since I haven't driven on them yet.
I'm just trying to find balance between clearing the coilovers and not sticking out or rubbing on the outer fender.
I had a conversation with TruTaing who has 225's with et28 and his car rubs the inner fender on the outside, but clears the coilover. he suggested an 8mm for me. but if he rubs with 225 and et28, i would think i'm going to rub with 235 or 225 and et27. yet there are some here that are runnign et28 with 235's and no rubbing...i just don't understand...
#4680
MBworld Guru
white and whiter
if you are rubbing on the coilover, does it rub on the knuckles or the shock? if it is rubbing on the knuckles you can raise the front up a little so that it clears. if it rubs on the shocks than I would suggest a 3mm.
if you run a 10mm you will have the front wheel like the picture of mine with the Axis.
#4681
with 225 or 235 you will rub on the front plastic inner fender lining. tha'ts something I wouldn't worry about.
when the tire was hitting the coil, there was about a 1/4" gap between the wheel and brake rotor face.
#4682
MBworld Guru
white and whiter
well, when i got the height set where i wanted it, the inside of the tire was rubbing on the last coil of the spring. if i raise it up, it will rub on the perch. it hits significantly...i wedged a 3/8" wrench in between the wheel and brake rotor and it looked like it cleared.
#4683
and do you think i should swap out the 235's for 225's for a little more clearance? perhaps you assumed using the 225's...
#4684
MBworld Guru
white and whiter
thanks....and don't misunderstand, i am in no way doubting you, but it just seems that 5mm is not enough. there was at least a 5mm gap when the tire was hitting, that means i need a few more mm to clear. no?
you need to turn you wheel and look at the spacing on the inside.
doesn't matter what the design of the wheel is ET35 on any 8.5 width rims is still ET35. If your wheel clears the caliper at ET35 that means your wheel most likely doesn't have a lip design or it has one of those ] shape spokes. The spoke distance to the rotor has nothing to do with how much distance there is between the wheel and the shock/perch/springs which ever you are rubbing on.
like I've mentioned above. ET28-31 is the offset used by the 3 major tuners when they put 19x8.5 wheels onto the W203. They don't rub on the coilovers.
you can go down to this height like my car without rubbing on the perch or springs with ET28 offset. If your car sits lower than mine than yes, it would be better for you to swap out the 235 for 225.
#4685
The wheels have about a 1.5" lip (maybe more) and a ] shaped spoke, that's why they clear the calipers w/o spacers. The 5mm I was referring to was the area that a spacer would go between the wheel mount and rotor face. So, imagine I pick up the tire and wheel and slip it over the hub, when it stops, its hitting the bottom coil and the gap at the spacer location is at least 5mm. So, what I'm saying is that with 5mm spacer, the tire will still interfere....so i will need >5mm or a 225 tire.
now, as you state, i can raise it up until the perch is adjacent to the tire and the last coil is just above the tire, then a 5mm spacer would work i think, but then i'm not sure the car will have the stance i want. For example, I like how your car sits in the big pic, but I want it a bit lower...more like your sig pics. that tells me that:
5mm w/235 wont clear
5mm with a 225 might clear
7-8mm with a 235 might clear
7-8mm with a 225 will clear
10mm with a 225 or 235 will stick out too far
As I mentioned, I can get the 225's for basically free as a return for my 235's. all I have to do is pay for shipping one way....about $40. Is it worth it to be safe? What's the disadvantage(s)?
#4686
2006 C350 SS
#4689
MBworld Guru
white and whiter
Now you finally show better pictures of the spokes curve. all i can say is good luck.
I just don't see that they will fit without the front wheel sticking out way past the fender. I hope Albert will have some good laughs while dangling a smoke on his mouth.
#4691
2012 CLS63
Do you have more profile pics of this car? Are those Monoblock S's in Black? If you have more pics please email me at kiamcoj@yahoo.com as Im looking to do the same. TIA
Jon
#4692
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Hey Frank,
Jon
Jon
#4693
2012 CLS63
#4695
This is going to be a newbie question to the max, but its on tires because I'm tryin to figure out what fitament would look best. I bought 19x8.5 ET32 19x9.5 ET36 Sport Edition ST4 and the guy at the wheel shop is recommending me to put on 225/35 in the front and 255/30 in the rear but the thing is I dont want my tire looking thick and he doesnt have any tires that size to shope me how they look. I want the wheel to be thinner but not too thin where it makes the wheel well look empty. And what do those numbers mean, I wikipedia'd it and I didnt really understand the explanation I'm riding on the stock 2004.5 sport suspension. Any help would be appreciated guys. Also how much did you guys usually spend on tires for 19's?
#4696
*most* of the time (assuming the correct offset) a 19x8.5 would have a 235/35 and a 19x9.5 would have a 265/30. however, if the car is lowered a lot or other issues in which you would be concerned about rubbing- a 225 and 255 are used.
#4697
http://www.tirerack.com/tires/tirete....jsp?techid=46
Secondly, 225/255 or 235/265 are common set-ups. i run 225/265 because i wanted my car low in the front and just couldn't get it where i wanted it with 235's (they were rubbing the coilovers). the other thing is that my fronts are et35, so with a 235, a 10mm spacer was too much and a 5mm spacer wasn't enough. with your et32's, if you clear the brakes w/o spacers and have the stock supsension, you should be fine with 235's. the 235/265 set-up will def fill the rim up more, and have slighter bigger sidewalls...but not sure you would be able to see the difference on the rim standing there looking at the car with 225/255 vs 235/265. as for the rear, et36 with 265 and stock suspension should work fine, however, as ^^^ said above, a lot depends on lowering the car.
225/255 is a safer bet all around, on all accounts, to avoid any rubbing at all.
#4698
First off, read this:
Thanks for the great info jfabes. I want it to also keep an aggressive stance, like the front be lower than the rear. I'm sure the tire combo would make the car look like that, right? Does anyone have any pictures with a 2004.5 C230 with sport stock suspension running 19's?
#4699
Ok so I think im either going to buy the Dunlop SP Sport Maxx or the Hankook Ventus S1 evo tires. They're both off tirerack, im wondering if anyone has any feedback on these or just to help my choose a tire.
#4700
