UHI, Phone, Bluetooth, OEM MB Interface Kits, Hands-Free Comms Thread
Rating: Thread Rating: 14 votes, 5.00 average.
Old 06-25-2006, 06:15 PM
  #801
jgsx's Avatar
04 C32
Originally Posted by [iNTx]
As in 24 July 2006, the unit cannot be installed.
My car has Bose,Teleaid,CD changer and such!
Real Pain in the *** to install!
What was the problem? I have Bose, teleaid, and cd changer and the install was plug and play
Old 06-25-2006, 08:46 PM
  #802
mbbodytech's Avatar
04 C320 Coupe MT
Originally Posted by patrick_y
Ohhh, yea, I see these 4 holes at the bottom of my mirror, I never knew those were for microphones.
Thanks Steve!
To tromar1:
No problem, it's weird that Mercedes would change so much in the same car. But it's good we got both sides for the other people wondering where they should speak to.
They did that because for parts standardization purposes, going to the MOST system. It seems like a lot of changes but for Benz in the long run it's cheaper to manufacture.
By the way, you can use an 05 mirror on a pre 05 car, it's just that you have to remove the plug housing on the mirror, select the proper two pins and put them into the plug housing from the old "donor" mirror. The difference is that the 05 mirror has four mics and the control unit uses whichever has the best signal. You have just to pick one and hope for the best. I did this to my car and it works fine.
Old 06-26-2006, 01:18 AM
  #803
patrick_y's Avatar
2006 E55 and 2002 E320
I'm not sure I'll ever understand Mercedes' rationale.
I don't use the car phone, so I'm able to remain quite indignant.
Old 06-26-2006, 08:38 PM
  #804
jgsx's Avatar
04 C32
People still have trouble hearing me. How do I know that the directional mic is pointed correctly?
Old 06-26-2006, 09:19 PM
  #805
SUNILP's Avatar
2015 E250D
look at the slats on the mic in your 04. They should be facing the driver
Old 06-30-2006, 12:22 AM
  #806
TammamB's Avatar
'08 S550 '09 C350 '06 C280
Argos Pains
If you have a CD changer there is a possibility that you may have to rewire your fiber optic network. I had two seperate optical plugs (1 for phone and 1 for CD changer) behind my Comand Nav.
Since there is only one input into Nav/Head unit you will need a fiberoptic loop to daisy chain between your phone sys and nav/head unit, I transplanted the extra one (the one you don't use in Peleli's pics) into the dash, pulled out my cd changer and plugged the transplanted optical fiber into the back of it.
Took an extra half-hour but well worth it. Hope this helps someone.
Enjoy
Old 06-30-2006, 12:38 PM
  #807
[iNTx]'s Avatar
W210, W220, W203
Enjoy
I tried to do that even going to a dealer for it to be installed but ........ it still does not work!!!!!!!
I guess i would have to gave up!
Old 07-01-2006, 10:40 AM
  #808
tjbrum's Avatar
Argos Group Buy
Has anybody kicked around a group buy for the argos??? I'd certainly be inerested.
Old 07-01-2006, 11:41 PM
  #809
Super Moderator
MJ50's Avatar
bone stock E55 AMG
i'll let go of mine for $600 obo...
opened, but brand new.
Old 07-02-2006, 07:41 AM
  #810
Admin Alumni
MB-BOB's Avatar
See Garage
How do inbound calls work? Let's say you are listening to the Radio or CD, and the call comes in... Is the music muted so you can hear the inbound ring? How do you pick up the call?
Old 07-02-2006, 10:26 AM
  #811
raunen's Avatar
2005 C320 4Matic
from their website although doesn't exactly answer your question, these are its features (currently only for D2B systems )
* full duplex hands-free communication with digital echo cancllation
* phonebook upload, recent call lists, caller-id and voice dial supported
* supports the use of steering wheel controls and keypad dial from your radio or Command unit
* fully compatible with Command and Mercedes-Benz voice control
* secure connectiity assured -- pairing MUST be initiated via the head unit
* microphone muting ability - caller can no longer hear conversation within the car
* take the call privately - by pushing a button, you can make your call private from guests traveling in car with you
* support of Smart and PDA phones
Old 07-03-2006, 04:10 AM
  #812
STLcoupe's Avatar
I'd prob take it, MJ. Any reason you don't want it?
Old 07-03-2006, 05:34 AM
  #813
Scott Cairns's Avatar
Phone Question
Hi, I was looking at some C class vehicles on the weekend, ranging from 2001-2003.
They all have the phone mount (or whatever you call it) on the centre console. They also have that squiggly cable hanging out of it.
The dealer told me that all I need is a cradle for my particular phone from Mercedes and that it will cost $200. (Aus dollars in this case)
Is this true? It doesnt seem to gel with a lot of info Ive read about phone systems, installation etc. For example, I keep reading that you need a UHI kit. Is this it? Or something else?
Thanks,
Scott.
Old 07-03-2006, 09:23 AM
  #814
dalazernet's Avatar
2020 GLC300 4MATIC
I believe all Mercedes come prewired for telephone... but a kit (which you are referring to) that comes with a cradle in the center console is also needed... You seem to already have that pricey item, so simply exchanging out that phone mount for one that will fit your phone will work for you. I'm 99% sure... Anyone else want to back me up?
- Eric
PS - completely unrelated, I got a new signature file ;-)...
Old 07-03-2006, 09:54 AM
  #815
SUNILP's Avatar
2015 E250D
He is from Australia and those cars do not come prewired usually. Those cars are also equipped with phone cradles on the dash at times. Any car 2001-2006 C can be retrofitted with a UHI system. The UHI system is the new universal system which will allow you to use various cradles to accomidate various phones.
Old 07-03-2006, 10:02 AM
  #816
Thanks Guys. Im thinking about going with the Argos bluetooth solution, as it seems cheaper than doing a UHI retrofit from what I can gather.
Thanks for the answers,
Scott.
Old 07-03-2006, 10:46 AM
  #817
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Nothing wrong with the kit. I just decided to delay on phone kit for now.
Old 07-03-2006, 11:31 AM
  #818
dalazernet's Avatar
2020 GLC300 4MATIC
Ahh, glad someone else chimed in then ;-)... didn't notice you were from Australia.... As for the Argos - I've heard very good things, and since your lookin in the 01-03 range you'll be fine with it. Its the 05/06 models that can't use the Argos bluetooth kit *yet*... but the second and I mean "second" it becomes available -- ;-)...
- Eric
Old 07-03-2006, 10:38 PM
  #819
patrick_y's Avatar
Right, in the UK and Europe, you actually have to pay extra for the pre-wiring so I'd assume it's the same for Australia.
I'm not sure this applies to the Australian market, but I think the most economical option is to get the "Hands free kit" and get a bluetooth adapter. The Handsfree kit gives you a small plug in under the armrest. You use a bluetooth adapter to plug it in, and voila, your phone (once paired to the bluetooth adapter) will work.
I've even contemplated this extra on my car but then I thought that I'd be talking too much. However, it is a pain for me when people call me, it's very difficult to get my hands into my pockets while driving.
http://www.wireless4mb.com/
Check out the wireless Bluetooth Interface module.
Old 07-03-2006, 10:46 PM
  #820
Thanks guys. Im still shopping for my car, but pretty much every single one I look at (except for early 2000 models) has an existing phone cradle on the center console.
I assume then that the phone wiring has to be in place. I was reading about the Argos solution, and all you have to do is unplug the old "tel" connection. (more or less)
Ive been given some pretty steep quotes for the UHI kit, the Argos will let me get a fully integrated phone system into the car at roughly 30% less than UHI.
It will also let me pair my wifes phone as well, and we wont have to worry about purchasing seperate cradles for each phone/upgraded phone.
Old 07-03-2006, 11:04 PM
  #821
ayman's Avatar
GLC250, X3 30i
I've got 2001 C180 and yes, the phone Nokia ?5110 something and few other old nokias should be ready to go, Australia here by the way
So Scott, how does the Argos solution work? I've got a sony ericcsson with Three, got blue tooth in it.
I asked Mercedes dealer about it and they just shocked me with $1500 or more so I just went away.
Old 07-04-2006, 02:34 AM
  #822
Hi Ayman, its a module of some sort that plugs into the wiring of the car. As its bluetooth, you dont need any cradles for various models of phones. It will also pick up your phone, even if you left it in the boot or something.
There is a thread on it here; https://mbworld.org/forums/showthrea...ighlight=argos
Including information on the install itself. It looks pretty straightforward. Its a little pricey (just over $1000 Aussie dollars) but its stil cheaper than the quotes Ive been given for UHI and other options. More flexible too.
Cheers,
Scott.
Old 07-04-2006, 02:38 AM
  #823
patrick_y's Avatar
Cheers,
Scott.
That's what I like about it, the flexibility. However, still, I rarely need to use the phone and with the phone in the car, that means my phone bill might go up.
I'll get it on my next car, but I'll pass with this one.
Old 07-04-2006, 07:36 PM
  #824
ayman's Avatar
GLC250, X3 30i
$1000! That sorted the issue for me. There are some really nice hands free bluetooth at Dick Smith for $150 or even less. I don't think spending $1000 on a used car is an economical idea.
Old 07-04-2006, 08:18 PM
  #825
jgsx's Avatar
04 C32
Yup, the source is muted, and you will hear a ring through your speakers. Once you end the call, your audio is resumed
You have already rated this thread Rating: Thread Rating: 14 votes, 5.00 average.
Quick Reply: UHI, Phone, Bluetooth, OEM MB Interface Kits, Hands-Free Comms Thread
