View Poll Results: What Tires are the best?
Goodyear
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
21
5.92%
Toyo
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
28
7.89%
Michelin
![](https://mbworld.org/forums/images/polls/bar4-l.gif)
![](https://mbworld.org/forums/images/polls/bar4.gif)
![](https://mbworld.org/forums/images/polls/bar4-r.gif)
140
39.44%
Continental
![](https://mbworld.org/forums/images/polls/bar5-l.gif)
![](https://mbworld.org/forums/images/polls/bar5.gif)
![](https://mbworld.org/forums/images/polls/bar5-r.gif)
43
12.11%
Falken
![](https://mbworld.org/forums/images/polls/bar6-l.gif)
![](https://mbworld.org/forums/images/polls/bar6.gif)
![](https://mbworld.org/forums/images/polls/bar6-r.gif)
25
7.04%
Pirelli
![](https://mbworld.org/forums/images/polls/bar1-l.gif)
![](https://mbworld.org/forums/images/polls/bar1.gif)
![](https://mbworld.org/forums/images/polls/bar1-r.gif)
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
#1001
2003 C230K
Originally posted by 230 Cedan
My 2003 230 sedan came with the Continentals but they are W rated instead of Z. Did anyone else have this happen to them? Also what kind of difference in tread life should I expect from them? Thanks.
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
#1002
Originally posted by Mercedes
This is the tire that I have decided on guys.
http://www.tirerack.com/tires/tires....m=245YR7F1GSD3
Can I mount 235/45/17 on the stock C7 wheels? or should I just stick to 225?
Thanks in adavanced
Thanks in adavanced
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
also, it will make your total wheel diameter larger than your current setup... therefore, it could potentially make it rub (your car looks lowered) and will throw off your speedo & ABS/ESP... somewhat the same effects as putting on 19s on your ride
so, just stick with 225....
#1003
the tire compounds for max performance tires are very soft, thats why the performance is so good, but at the sacrifice of the tire life
and there is nothing wrong with W rated tires... they are actually better because W rated tires are Test Proven to be capable of withstanding speeds of 168mph. whereas Z rated tires are only speed rated for 149mph without a test max speed.
i think the manual actually says that the W rated tires should be stock, but that Z rated tires are acceptable alternatives/replacements
#1004
2003 C230K
Originally posted by mmgrad
there really is no reason to switch to such large tires... it will make your rims look smaller too.
#1005
C230 K coupe Orion blue, Evo, prem leather roof, premium sound and cd changer, auto.
Re No change in driving style
Originally posted by FrankW
I had ContiSportContact 1 on my previous car, which was a 00 328Ci. The tread was almost completely bold after 13k miles. Now with the C32's PilotSport I'm at 20k miles and still going. There's no change in my driving style either.
![beat](https://mbworld.org/forums/images/smilies/beat.gif)
#1006
52K miles on the original Conti's and they still have about 10K to go. Driving style has a big effect on tread wear. Sportier/softer rubber compound tires 'feel' better but you pay the price with quicker wear.
#1007
I think you are understanding the numbers wrong. 225 would be the width of the ture not the diameter. 45 is the diameter.
Since your car is lowered, Mercedes, my concern would be that the bigger tires might hit the front wheel arch or the inner fender when the wheels are turned and the car goes over a bump. But the change from 225 to 235 is not a big one.
I'm guessing that the Goodyears will be quite a bit noisier than the Continentals.
#1008
2003 C320 4Matic
Mercedes - That's a pretty aggressive looking tread pattern on that tire and bound to get lots of looks.
As for life of the tread... just look at the "Treadlife rating" for each of the tires that you are researching. The government or some organization uses some benchmark on treadwear. A treadlife rating of 180 means 1.8 times that benchmark. Regardless, it gives you a relative means to compare tires for tread life.
Hope this helps.
#1009
MBworld Guru
white and whiter
Re: Re No change in driving style
Originally posted by Goggles Piasano
According to your post you did change your driving style...From no style (00 328 Ci) to high style (C32).
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
#1010
C230Kompressor
Originally posted by SOC320
Just to clarify a little.... Actually, 17 is the diameter. 45 is the sidewall. 225 is the width.
Hope this helps.
Hope this helps.
____________________________________________
Tire Dimensions:
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Example...185/60R14 85H or 185/60HR14
185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
And as far as treadwear, tires are tested by each manufacturer on their own test facility, so it is best to only compare treadlife ratings within a manufacturer's product line. A '180' from Michelin doesn't necessarliy translate to a '180' from Pirelli.
HTH
#1011
2003 C320 4Matic
Originally posted by KOMPRESSORnSC
Actually...that's wrong. This is from Luke's Tire Tech over on Wheels & Suspension:
Tire Dimensions:
HTH
Tire Dimensions:
HTH
As for treadwear, yes the manufacturer tests the tire, but the standard for testing and the baseline is set by the government (UTQG). It does give you a tire to tire relative means of comparison. See below:
Uniform Tire Quality Grade (UTQG) Labeling
Required by the government, the UTQG provides comparative manufacturer information. Tires are subjected to a series of government-mandated tests that measure performance in treadwear, traction and temperature resistance.
#1012
a sidewall rating of 45 is not a direct measurement of the sidewall... it is a percentage of the width of the wheel.
so, a tire with, say, a 225/45 and a 255/45 will have a completely different sized sidwall. I know those aren't the sizes you mentioned, but I just giving you a more extreme example so you will understand...
#1013
2003 C320 4Matic
#1015
MBworld Guru
white and whiter
Originally posted by AlBoston
mercedes... did your car come with the conti sport 2's? I was interested in getting those tires.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#1016
2003 C230K
#1017
Mercedes-Benz
Yes they did I don't know why. I presume because my 2002 was one of the earliest builds I got my car in Oct2003. Right now my car has 17,000 miles. The thread wear on the front tires is not that much compared to the rear. If I wanted to get 25,000 out of these tires it's possible. I just do not like the wet traction on them.
#1018
2015 ML350 4Matic
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
My 2001 C320 came with the Goodyears. I have driven over 30,000 miles on them, and they aren't even half way done. I am still on the original brakes too.
I am not a big Goodyear fan, but I've had Michellins on other cars that were more worn out at 15k miles. However, I had Goodyear Wranglers on my GrandCherokee with 20k miles that are garbage, in fact I am changing those for the Michellin Cross Terrains. I think that it all depends on the specific tire and car. I do not think that I would change the C's tires from the Goodyears.
I am contemplating getting a set of snow tires / rims but am not sure if it is necessary. We had a pretty rough winter last year and the car was fine with the Goodyears. Except for getting in and out of the driveway, my 70 mile commute (roundtrip) was without incident. Any advice on the winter tires?
#1019
Mercedes-Benz
#1022
2003 C230K
Guys I bought my tires btw. I got this tire from goodYear http://www.us.pirelli.com/en_US/tyre...productid=2626
So far I love the, and got to test them in the rain.
It was $131 per tire
#1023
Mercedes-Benz
Originally posted by lars
The Conti Sport 2 is a quiet tire.
#1025
Mercedes-Benz
Originally posted by Halifax
Mine are Michelin pilot. I have over 20.000 miles on them, and they still look brand new.
