View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Rating: Thread Rating: 10 votes, 5.00 average.
Old Apr 25, 2006 | 03:06 PM
  #1851
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by Blake P
No problem. Let me know if you have any questions when you install, but I have a feeling you will figure it out. Gonna get a small 1-piece version of your OZ? Looks like tirerack.com has the 17" for $239 http://www.tirerack.com/servlet/Call...filterSpecial=
Depends on what can fit. If the biggest it can fit is a 225/45R17 just like stock, then I'll most likely get one 1 piece rim. I saw the tirerack prices, but I'll probably be able to get a better deal than list at tirerack.
We'll see.
BTW, did you talk to HRE about the center caps? You never know what they'll say.
Old Apr 25, 2006 | 03:10 PM
  #1852
Blake P's Avatar
'09 A4 S Line
Yes, they said they might custom make me some OEM sized caps w/ their logo. He wouldn't quote me a price until I receive the wheels and tell him the serial number from the back of the wheels first, but I was happy he didn't say "NO" and hang up. Keep hope alive!
Old Apr 25, 2006 | 03:26 PM
  #1853
drexappeal's Avatar
I knew they'd be open to it! Good stuff. Let's just hope they don't charge you an arm and a leg to do them! Knock on wood.
Old Apr 25, 2006 | 05:31 PM
  #1854
levelr123g's Avatar
Hows this,
Yesterday I get a flat. I go to replace the tire however the spare requires a different size lug bolt? I call MB roadside and they say yea, the spare lugs should be in the back. I check and check, but no new lug bolts. So roadside comes to me and brings me a brand new wheel/tire. They say the new wheel/tire will fit and use the original size lug bolts. the roadside tech tells me that apparently MB made a change mid year to the spares and some cars have the wrong spare in them. So my point is, make sure your spare fits your car before you really need it!
Why would MB even design a spare that uses a different size lug bolt? Why not just machine the wheel thicker, rather than make a smaller bolt?
PRICELESS!
Old Apr 25, 2006 | 06:35 PM
  #1855
rlee02135's Avatar
2004 C32 ///AMG
Originally Posted by nov0798
Hows this,
PRICELESS!
did you get to keep the wheel?
Old Apr 25, 2006 | 06:44 PM
  #1856
Arn560's Avatar
Black 04 C230 Kompressor SS
I hit a rock & blew out my front tire, I limped to a gas station & dialed 1-800-Mercedes. 30mins later an ML320 pulled up changed my tire to the donut in the back, & sent me on my merry way.
That was when I saw him open a little plastic bag to pull out the spare lugs. (They even have a pair of gloves in there) My tire was under warranty but I didn't realised till I bought a new one but never mind; alls well that ends well.
  #1857
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Blake, I double checked the part #s...
Looks like i ordered wrong shell... at least the bracket matched...
gonna order correct shell this weekend...
this is the pic of full-size spare with incorrect shell...
Old Apr 25, 2006 | 06:54 PM
  #1858
drexappeal's Avatar
Thanks for the pic, mj!
Looks like maximum would be the 17 incher w/ 225/45R17. Well, I guess I'll have to see how much a 1 piece Superleggera will cost.
drex
Old Apr 25, 2006 | 07:21 PM
  #1859
Blake P's Avatar
'09 A4 S Line
drex
Yes, the width for that shell/bracket is 225 Drex. I'm not sure about wheel size because I've never looked into the actual difference in diameter if you get a larger wheel and lower profile tire.
Old Apr 25, 2006 | 07:36 PM
  #1860
MJ50's Avatar
Super Moderator
bone stock E55 AMG
here's the pic w/o the shell
Old Apr 25, 2006 | 07:50 PM
  #1861
MJ50's Avatar
Super Moderator
bone stock E55 AMG
looks like i got the right parts...
got this from c32life.com
Old Apr 25, 2006 | 07:55 PM
  #1862
mleskovar's Avatar
'17 Jaguar XF
Why would MB even design a spare that uses a different size lug bolt? Why not just machine the wheel thicker, rather than make a smaller bolt?!
The full sized spares, being temporary, are made of stamped, rolled, and welded steel and much thinner than the alloy wheels. Saves $$. What I don't get is why they use bolts instead of nuts and studs....it's inconvenient to use the 'wheel locator' pin when reinstalling tires, there's no issue with bolt lengths with the studs and nuts, and if you cross thread a stud you just replace it instead of the whole hub. I also doubt that there's any cost saving with bolts...especially if you have to supply a whole extra set for a wheel.
Old Apr 25, 2006 | 08:00 PM
  #1863
drexappeal's Avatar
Hmmm...Well, based on my measurements of my front wheels, I think I may be able to put in a full replacement wheel. Whether that is worth it for the $$, I'm not convinced, but the overall circumference will be the same (if I put on 225/35R19 tires).
We'll see what I decide, but gotta take some measurements after I buy the part first. Then decide afterward. Just like always, gotta do the research first before jumping the gun.
Old Apr 25, 2006 | 09:28 PM
  #1864
MJ50's Avatar
Super Moderator
bone stock E55 AMG
drex, not sure if u can put 19x8.5 spare wheel cuz it's 1" taller (in terms of lookig at spare in the trunk)... but if u can squeeze it in, it'd be sweet!
Old Apr 25, 2006 | 09:35 PM
  #1865
MB-BOB's Avatar
Admin Alumni
See Garage
I don't know whether the tire well has been changed for the later models, but my 2001 C320 has a full-size, 215/55 R16 spare tire on a standard size rim that fits fully within the well, no prob at all.
Old Apr 26, 2006 | 01:35 AM
  #1866
drexappeal's Avatar
Well that's the thing, I checked the tire calculator and the size of the wheel in combination with the size of the tire is actually the same circumference.
Either way, I just have to take measurements when I get it first.
Old Apr 26, 2006 | 01:40 AM
  #1867
Blake P's Avatar
'09 A4 S Line
16" is certainly not "full size" for those of us with big brakes, Bob.
Old Apr 28, 2006 | 02:26 AM
  #1868
patrick_y's Avatar
2006 E55 and 2002 E320
I have the same car with the same tiny space saver spare. But it's not too bad, some cars don't come with spares at all, they just come with a tire repair kit! That's scary!
In fact, I heard that our space saver spare doesn't work on the front since the 2005 models have that big brake up there. Can anyone confirm this? I don't believe Mercedes to be that stupid.
Best policy, get run flats. Small investment, lots of return especially if you get into a sticky situation.
I'm thinking of just having another whole set of wheels and tires. One for my A/S tires and one for summer tires. I live in NorCal and I don't need it but it'd be a nice decoration for my plain garage.
Old Apr 28, 2006 | 10:28 AM
  #1869
MJ50's Avatar
Super Moderator
bone stock E55 AMG
patrick, if you have steel spare, then it won't fit the front. you will need full-size spare wheel to clear 05+/amg brakes.
Old Apr 30, 2006 | 01:38 PM
  #1870
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Full size spare!!
After the pot hole incident I thought this is better for AMG brakes, and being able to drive more then 50 mph and more then 50 miles.
Old Apr 30, 2006 | 01:40 PM
  #1871
MHPHOCKEY's Avatar
2014 Audi S5 Cabriolet 3.0T
Very nice...BTW its Bi-Xenons (In your signature)
Old Apr 30, 2006 | 04:09 PM
  #1872
mkaresh's Avatar
If you're planning to hit potholes those probably aren't the best rims/tires for the task.
Old Apr 30, 2006 | 05:02 PM
  #1873
rlee02135's Avatar
2004 C32 ///AMG
looks nice.
did you have to change the bracket or did the wheel just fit right in there?
Old Apr 30, 2006 | 07:27 PM
  #1874
kickR's Avatar
'14 CLA 45
Originally Posted by rlee02135
looks nice.
SHELL - A 203 898 01 07 7c45 - for 225 width tire
BRACKET - A 203 899 04 14 7c45
The total was only about $25 and it was very easy to replace ...
from BlakeP
Old Apr 30, 2006 | 08:17 PM
  #1875
WaveyKat's Avatar
Something Slow
whats the biggest size Tire & Rim can u fit in there? right now i have a 225/50/16
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
