View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Rating: Thread Rating: 10 votes, 5.00 average.
Old May 12, 2006 | 11:45 PM
  #1901
Oh Cool's Avatar
2021 GLB35, 2007 E350, 2014 ML350 4Matic, 2008 C350 Sport
Tire Question Please
If anyone can help me with this question please. I'm looking to put a wider tire on the standard rim on my 2002 C240. I don't want to change the 55 tire height size. What is the widest tire the rim will take i.e: 215, 225 or 235/55/16 width without a problem? Thanks
Old May 12, 2006 | 11:51 PM
  #1902
e1000's Avatar
a quarter mile at a time
on a tire, the "55" is a percentage of the width. therefore, if you get a wider tire, you will need to have a smaller aspect ratio, but the actual thickness of the tire will stay the same.
your stock tire is 205/55/16
you could probably go 225/50/16
Once again, with this setup, the overall diameter of the tire is almost the same (0.1% smaller than stock)
Old May 13, 2006 | 12:07 AM
  #1903
Oh Cool's Avatar
Thanks the reason I'm asking is that I don't want to mess up the speedometer by changing the tire height.
Old May 22, 2006 | 03:25 PM
  #1904
spyder2005's Avatar
Tire Size Question C230 Coupe
Hey guys,
Right now im running :
225/45-17 Front
245/40-17 Back on 2005 SS Wheels
Need new tires and wheels. Was thinking about getting 18" 's :
http://www.konigwheels.com/catalog_p...ID=1&ss_id=214
With new BFGoodrich g-Force T/A KDW 2 Tires
Now .... i have checked sizes in this forum, but couldnt find limits for 18" wheels . I saw that tirerack said it would fit 255's on 18" 's on the back, but i know they dont fit on 17's (tried it, got rubbing) .
Can anybody help me out ?
Regards Spyder
Old May 22, 2006 | 03:49 PM
  #1905
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Tire Size Calculator...
Here is something that you can always reference (save the link to your favorites), regardless of what size you go with.
http://www.miata.net/garage/tirecalc.html
All you have to do is enter the OEM setup and then enter in different sizes that'll match the same rolling diameter or very close to it. So you don't have to DIY this time, according to the calculator, ideal size would be:
225/40R18 Front
255/35R18 Rear
Old May 22, 2006 | 04:17 PM
  #1906
spyder2005's Avatar
Well, im actually trying to figure out if the size of the tire
will rub against anything if put on my car, less than if the
tire will fit the wheel.
Very useful tool though, Thank You
Old May 22, 2006 | 05:58 PM
  #1907
drexappeal's Avatar
Okay, well, if you order the correct offset on the wheels and you get the rolling diameter that is closest to the OEM rolling diameter, you shouldn't rub at all.
Old May 23, 2006 | 11:57 AM
  #1908
spyder2005's Avatar
Does anybody else have some input for me ?
Maybe somebody who did something similar (to my Coupe owners)
Old May 23, 2006 | 12:41 PM
  #1909
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
The size Tire Rack is telling you I believe is the same as a c55 and should fit with no problems. And the thing you should understand is the sizes are not exactly the same in all tire brands. And the sizes are different from 17" to 18" and 19" wheels. That is why it was suggested that you use the calculator to figure it out. I run 235/35/19 front and 265/30/19 rear with no rubbing. Here is another sight to try. http://www.1010tires.com/tech.asp
Old May 24, 2006 | 12:05 AM
  #1910
CM208's Avatar
2005 C180K Sports Sedan
Sorry.. kinda here. but....
From STFF... I found out most ppl are having this setup for sports sedan:
Front: 235/40/18 on a 18x8.5 Offset 32
Rear: 255/35/18 on a 18x9.5 Offset 35
However, IF I want to stick to the original width of 225 (Front) and 245 (Rear) in 18"s, What size rims (in width) should I got for and what offset? Would 18x8 and 18x9 fit nicely? I would like the tire fit nicely with the rims, hence better "lip protection".
thanks in advance.
Old May 24, 2006 | 12:55 AM
  #1911
spyder2005's Avatar
Well its nice to get estimations and stuff, but i was hoping that a coupe owner with this or a similar SETUP could give me advice, because although the sedan and COUPE are a lot a like, they are very different when it comes to tire sizes.
I NEED A GOOD SETUP WITHOUT RUBBING
Now the size calculator helped with selecting right wheel and tire match,
but WILL IT FIT THE CAR WITHOUT RUBBING ?
Thanks again to all those who already took their time to comment.
Where are my coupe people ???!!! Wake up lol
Im going please help
spyder
Old May 24, 2006 | 11:40 AM
  #1912
drexappeal's Avatar
Well, the thing is, people with coupes have been able to run the same setups as the sedans without rubbing on 19's (235/35R19 F, 265/30R19 R), so as long as you follow the proper guidelines wheels (correct offset) and tires (18 inch rolling diameter as close as possible to the 17 sport sedan wheels you're currently using), you should should have no problem with rubbing.
My main point is, do you have any problems with the 17's you are running on right now (which are made for the Sport Sedan)? If not and you get the proper offset on whichever 18's you decide to get and keep the overall rolling diameter the same, it doesn't matter if you're putting the rims on a coupe or a sedan. If you are having problems with rubbing on the current 17's, then I really can't be anymore help. If not, then the information many people have provided should work WITHOUT rubbing (again, regardless of whether it's a sedan or coupe).
Now, if you're considering DROPPING the car, that's a different story.
Old May 24, 2006 | 09:31 PM
  #1913
kickR's Avatar
'14 CLA 45
hes got the 2005 SS staggered wheels with 245 tires and 14mm spacers.
it only rubs when his car is full of ppl, i believe.
Old May 24, 2006 | 11:40 PM
  #1914
drexappeal's Avatar
Hmmm...Are the rear wheel wells folded from factory like the SS?
Old May 25, 2006 | 10:21 AM
  #1915
kickR's Avatar
'14 CLA 45
2004 coupe - dont believe so.
Old May 25, 2006 | 12:24 PM
  #1916
drexappeal's Avatar
spyder2005 - did you have your rear fenders rolled/folded/trimmed?
Old May 25, 2006 | 12:28 PM
  #1917
kickR's Avatar
'14 CLA 45
BTW - that doesnt come equal with what you mentioned 2 posts earlier. with the SS models having their wheel wells folded, right?
Old Jun 2, 2006 | 12:13 PM
  #1918
PsiTERROR's Avatar
2003 c230k sport 4 door
What size tires?
What is the widest tire i can use with a 19x8x5 in the front and 19x9x5 in the rear?
03 C230K 4 door
Old Jun 2, 2006 | 12:28 PM
  #1919
MJ50's Avatar
Super Moderator
bone stock E55 AMG
it's normally 19x8.5, 19x9.5. STFF and u'll find the answer
Old Jun 2, 2006 | 01:54 PM
  #1920
Newtigger's Avatar
235/35/19 front and 265/30/19 rear is the best combination
Old Jun 2, 2006 | 10:07 PM
  #1921
PsiTERROR's Avatar
Can I fit 265/40 /19?
Old Jun 2, 2006 | 10:13 PM
  #1922
jan ken po's Avatar
'05 SS Brillant Silver
Not only no, but HELL to the naw! Does anyone even make that??
Your question has been answered for the most part. However, if you insist, make this site your best friend.
http://1010tires.com/TireSizeCalcula...?action=submit
Old Jun 3, 2006 | 03:04 AM
  #1923
JP@CarLAB's Avatar
First of all, a wheel with a 40% profile won't be very forgiving if you plan on lowering the car. Will you be lowering?
flip
Old Jun 3, 2006 | 10:16 AM
  #1924
PsiTERROR's Avatar
No lowering for me.
Old Jun 3, 2006 | 11:08 AM
  #1925
kickR's Avatar
'14 CLA 45
i have 19/235/35 in front ... and this is what happens when i turn the wheel all the way.
if you have 40 in the back ... you should have 45 in front. imagine how much rubbing you would have just in front and not even turning the wheel all the way.
Attached Thumbnails W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES-mb.jpg
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
