Group Buy for LCD? $66 for those with heat related fading.
BTW I am going to go take some more pictures of the installation as well as test the extra screen.
So here are three pictures
First is my screen
Second is what happens if connector is a little loose even though it looks ok
Third is placement of screen the little tab thing goes to your right when looking straight on.
I also took a video which is hard by myself so forgive the bad quality I was using one finger to move the connector around.
http://youtu.be/3Oa5xCAqgAI
I could make the screen look just like the 2nd picture but could not get it on video by myself. I also got the screen to display nothing like both of you if only one tab was locked and the other was almost locked. You really have to have someone help hold the connector and IC while someone else pinches both tabs down at the exact same time or the connector moves causing issues. Oh and if you pinch/ bend the lcd cable itself it changes what the screen looks like so check for pinch points.
I think I have found the problem.
After very very very careful inspection with a magnify glasses.
I found that the little resister that is connected to this end its hanging on by a thread. looks like it wants to fall off? So I think I have a defective one.
I'll go ahead and ship this thing back to you first thing in the morning and wait to see what the company says.
Will Minitools.it exchange them if they are defective?
I feel I had the connector in right since each time, I took it out and put the old one back in, it worked fine.
Is it possible I'm putting it in too far?
I'll try leaving a little play in the connector black plastic things, tweak the position of
the cable, side to side see if it can get it work. But like I said, put the original back in and it works.
I'll give it one more try tomorrow.
I'm sure they are other people who haven't yet tried there displays.
If we end up with defective ones I'm sure you'd want to return them all together.
Previously, I tried (I think) one of the Chinese ones and I got similar results...it wall too bright. It did appear to have some lettering, but the background was too bright. I do recall when messing with it that the contacts are very important. You might want to try some contact cleaner (isopropyl alcohol) or as someone had mentioned before, put a little tape or film on the back side of the contacts. That way it will press harder when the lock is in place.
Good luck guys. I'm gonna drive my car tomorrow for the first time and see how it all goes. My old one would fade even when it was only 60 degrees outside.
BTW- the catalog is quite extensive! I wondered if any of those plastic gears might work for the
sunroof?
http://www.mte.net/sites/default/files/minitools-en.pdf
9. REQUEST TO RETURN GOODS
The request to return goods must be made with
Savi Elettronica srl within 10 days after receipt
of the goods*, indicating the reason and specifying
the invoice references of the purchase.
In case the goods were wrongly ordered by the client,
it will be up to Savi Elettronica srl’s discretion to authorize
a possible return of the goods. The goods must
be returned undamaged, in the original or equivalent
packaging, complete with accessories and protected by
adequate packaging. Goods returned without these requirements,
will be returned to sender.
10. COMPLAINTS
Any mistakes in shipping or lack of goods mentioned on
the order, must promptly be mentioned to Savi Elettronica
srl, quoting the invoice number and the details of
the order.
11. GUARANTEES
Savi Elettronica srl guarantees its products, based on
the conditions set in Italian law. All products are guaranteed
for 12 months against manufacturer’s defects.
The present guarantee does not cover damage caused
by: neglect, faulty installation, repair or maintenance
work wrongly executed by non-qualified personnel,
unauthorized modification, any damage caused during
transport. For products called “flat parts”, we also have
the added guarantee of swapping the products even in
case the product has been damaged following faulty installation.
* 10 days after Trey received them! How much time is left?
Christ you need to get an RMA by TOMORROW! The 10th day is Sat.
Then again, they say they warranty for 12 months.
Everyone better test their displays ASAP.
Installed it, and display went up correctly (tucked the thingy in the bottom so it didn't just hang there, ie, no teabagging in the display), except for the SRS, Airbag, and Display Error warnings came up (DE warning is a pretty cool arrow that looks like the decal on Air Force helmets, but I digress...).
So removed it, redid it twice, and both with the same thing - the bright orange display that 230SC got. So, out of complete paranoia, I quickly put everything back to normal with the old one, and it works fine, except for the SRS warning, which I'm sure will reset itself in due time (and yes, reset the clock to normal).
So Trey, I appreciate your hard work on this, but I would like another penny back from you for my trouble.
It was a worthy effort, but sh*t happens. Good thing that I replaced it before with a stock piece before, and it's still showing fine. If it does get worse, I'll probably try to track down another low mile cluster and swap out the OEM screen.PS - that little gray plastic bar you raise up to remove the tail of the screen is very fragile. Don't ask me how I know.
Ok sent off an email saying that there were 3 screens so far that don't work correctly but I need more time to test all of them.
and what do you guys want refunds or new screens?
While your in contact with them, if you get a chance, as them why they can't cut the glass properly so the polarization is correct? lol
With all this that some people are having problems with it, I will live with the polarization issue, not that I wear sun glasses that much anyways.
On another note, Trey, will you be around this weekend to scan my car with Star to see if any more error codes came up?
Thanks again for your hard work.
lol and
I will be around this weekend Sunday would be best for me so give me a call or txt.
I did try out sunglasses this morning that say they are polarized. I can atleast while sitting in the passenger seat my display is still readable. Grant it's not as clear as without glasses but it definitely could be seen. We'll see what the ride home from works brings.
You say I have your address? Where?
Yeah, if it doesn't work today, I'll send it back.
I don't expect to get the shipping back. Thanks for the effort.
My existing screen is readable most of the time. In fact, reseating the
connector, it seems to be clearer than ever!
It's not as bad as some around here, but figured down the road, I''d regret not getting in on the group buy.
Anyone remember $550 AMG brake kits? Or how about $550 Supersprint headers?
I missed both of those.
My old one wasn't all that bad before, mostly the top row was much less bright or full when hot, but looked fine when cooled.
The 82 degree "before" shot shown was outside high noon - interior from sitting in bright sun March 14 in Syracuse...outside it was a record 70 ish...
I can see the new one while uniform all over, is also a little brighter overall too. The "after" shot is in a dark garage (Mar 16, 18:00) so the Iphone shots look way different.
Regarding defective ones the group is finding? We are all in this as a group IMHO. Thanks for the interface for us all, and your continued working out the defect issues for the unlucky few.
Once you know the fees ......those of us who got usable units all can anti up the small change to make you whole...for the return freight and losses the $5 or $10 more to make you and/or the few defective folks paid up & whole. It is just bad luck to those who got a defect, still with a little more fee to the working ones, we still got a great deal!
Ps. the change went very easy per the DIY post...I was less than 1/2 hour start - finish.
I'll take a new screen
about to start driving back and forth to miami for school. Its super duper hot down there. If that other new screen you got works, i'll take that one or tell the company to ship me a new one.
I do ask that everyone that gets one to please check it ASAP because we don't have much time. I know that one is going to Canada and last I checked it was still in new york and that the other one going to Canada is going there through Florida so I hope yours is fine.
Keep me updates as you install yours so I know I don't have to worry about you. I doubt I will get a response from the company till Monday so if you have time try to test it over the weekend.
On a side note, I drove mine today and all's well. I did notice the "W" in the upper right hand corner that has been illegible for well over a year...wondering how long it has been driving in the winter mode
