2006 C230 - Power Steering Flush?
Thank you!
I bet they are trying to get some money from you.
How much did they quote, $300?
You can do it yourself: https://mbworld.org/forums/c-class-w...flush-diy.html
1 litre does 3 years.
I would be a little concerned about running the PS pump with air in the system..
I also have attached a couple of small magnets to the dip stick level indicator & I wipe them clean every year of the fine metallic build up. My Peugeot 405 SRDT had these magnets OEM & there has been no PS problems in 400,000 km.
Reading up, it does look as if most hydraulic oils are mineral based therefore not hygroscopic. With 3 refills my PS fluid is stored for 2 years. At $50 a litre here ,I don't think I will be tossing it out.
Proper Fluid Handling and Storage http://www.machinerylubrication.com/...-contamination
Hydraulic fluids should be kept in their sealed containers until ready for use. Both new and partially used containers should be carefully handled and stored. Lids should be checked routinely and tightly secured, with drums being kept in a relatively benign environment. Large temperature swings cause the containers to "breathe" from expanding and contracting air and liquid inside. This, combined with moisture from rainfall or humidity, can cause the ingress of water into the container. Some fluids are hygroscopic, meaning they absorb moisture when exposed to humid air, thus requiring extra measures to be taken to reduce the chance of contamination.
