Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
While you were posting, I was editting the last post. I think that the light sensor turns on all the lights when it is dark and the light mode is set to "CONSTANT". Tomorrow is supposed to be sunny. I'll see what lights are on then, but I'm pretty sure it is just the low beams.
I tried mine when I was on the freeway under the sun around 3 pm today. All the lights was turn on when I switched the "constant" on.
Just went out and did a little test. Started the car in the garage. All the exterior and instrument lights came on. When I back out into the sunshine, all the lights went out, except the low beams which dimmed to the DRL intensity.
I didn't get a chance to test mine today, it wasn't even that sunny here today. But that makes sense what yours did. Mine all came on last night, but it was dark. I'm sure mine works the same way, so I'm not going to worry about it. I don't use DRL's and I don't plan on it because of my 100W low beams. I don't think I would want to have these on all the time.
I hate the look of the lenses, but I want Xenon and don't want to lose the warranty.
Erik
They will be VERY expensive. Maybe you should wait and see if Steve has anything available later this year.
Erik
Yeah, but the horror stories I have heard about regular HIDs on these cars I think it might be worth the extra $'s. I'd also rather buy from a dealer who can't complain later I got them from a non authorized place...I would have been stuck with my defective climate control if I didn't give the dealer the extra $20 they wanted over Ebay.
Erik
Icic.....very true.
Hey Erik, how's yr puppy doing? Have you dropped the idea of getting the AMG sway bars already?
Icic.....very true.
I have your info and will let you know when I can get them installed.
Erik
huh? xenon equipped cars have different internal wiring than non-xenon? i thought that was only an issue for retrofit kits.
Xenon equipped cars have a wiring harness to support the autoleveling feature of the headlights. Autoleveling is required by European regs.
Erik
The lighting portion is plug and play. The autoleveling, of course, is not. I doubt that you will find a dealer to install them, because the autoleveling is not there, and it is an integral part of the HID system. They could get themselves into serious liability problems if some one claimed your xenons blinded them causing an accident. Also, I have read that under Federal regulations it is illegal for dealers to retrofit HID's.
Erik
oh okay, that i know. however, regarding the harness, is an non equipped xenon wiring differnent than that with xenon? because i installed oem xenon into my halogen car. will the wiring deteriorate or is it nothing to worry about? thanks.
Erik
I am about to order C230 with Bi-Xenon lights (now available) with evolution pkg/C-7.
Dan
The cost is high , $1420.00 canadian for the Bi-Xenon option which includes headlight washers ( byitself $450.00 canadian) which brings down the price to $970.00. This seems to be more than what Audi charges, $750.00 canadian on A4 1.8T/ or $850.00 on BMW 320i sedan.
Are the Bi-Xenon lights better than what Audi or BMW offer?
Dan
