Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Nov 2, 2004 | 06:06 PM
  #1051
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Originally Posted by Saprissa
Originally Posted by Posting & You
Looks like you've got some more learning to do first...
... you dumb@$$ !
Old Nov 2, 2004 | 06:07 PM
  #1052
CitronC230K_03's Avatar
2003 Citron Green C230KMT
i love that posting and you, i cant get enough of it!
Old Nov 3, 2004 | 01:48 PM
  #1053
jaimedls's Avatar
C200 Kompressor Sport Sedan
Bi-Xenon Headlamps
Hi everybody, i want to buy an a set of bi-xenon headlamps por an W203 Sedan 2003, do you know someone that sells this product ?
I will apreciate so much, i check on e-bay but i dont find anyone could fit the w203 model
Old Nov 3, 2004 | 01:53 PM
  #1054
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Contact MBenzNL on this site.
Old Nov 3, 2004 | 01:56 PM
  #1055
you can email him at s_krabbenborg@hotmail.com or Steve@MBenzNL.com
Old Nov 5, 2004 | 07:38 PM
  #1056
jaimedls's Avatar
Instalation Instructions for Bi-Xenon Headlamps
Hi :
I want to know if someone have the instructions for install the bi-xenon headlamps, foglams, and clear blinkers mirrors for an C200 Kompressor Sport Sedan 2003.
I will apreciate so much if someone have it, please dont send me the webpage about to drink a beer between the steps jeje......
Old Nov 5, 2004 | 07:54 PM
  #1057
you might wanna try a search. i remember seeing them for a coupe, but its basically the same instructions. try benzworld.org if you cant find them here. you have to remove the front bumper in order to install. not hard at all, just 6 screws and a bunch of clips.
Old Nov 5, 2004 | 09:00 PM
  #1058
jaimedls's Avatar
thanks Citron
Old Nov 5, 2004 | 09:18 PM
  #1059
Originally Posted by jaimedls
thanks Citron
hey dude, i found em. they are on mbklasse.com
here's the link:
http://www.mbklasse.com/forums/showt...&threadid=7385
Old Nov 5, 2004 | 09:37 PM
  #1060
jaimedls's Avatar
Citron :
Did you have the instructions to remove the old blinkers for the new cristal clear blinkers for w203 i know that you have a beter ones, but i buyed the W203 ones and if you have the instructions to remove the old fog lights ?
thanks for answer my cuestions, and thanks again you re a great friend.
Old Nov 5, 2004 | 09:55 PM
  #1061
do you mean the amber side markers? those you just pop right off. for the sedan you would want wedge a small flat blade screw driver between the lens and the impact strip, and the lens just pops right out. you take off the bulb from the back, replace with the clear lens and and put the lens back into the strip. they are very easy. actually written instructions will be located in your owners manual for your car. should be in the under replacing the light bulb for the side marker, it give written instructions as well as illustrations i believe.
im confused because you ask for the removal of the blinkers, and then you mention the foglights. but you want to put in a clear lens.
Old Nov 5, 2004 | 10:12 PM
  #1062
which one?
Attached Thumbnails Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread-presentation1.jpg
Old Nov 5, 2004 | 10:33 PM
  #1063
Only4ZQ's Avatar
2004.5 C320 Sport Sedan (Metallic Pewter 723) & 2005 ML350 Special Edition (Alabaster White 960)
I think he means the blinkers on the side-mirror housings. Kinda like what Carlos is going to do with mine, replace the stock W203 ones with W211 ones.
Old Nov 5, 2004 | 10:39 PM
  #1064
ok, i got it now. he wants instructions to remove the mirror housing in order to install 2005 indicators or W211 indicators in the mirrors AND instructions to change the fog lights.
Old Nov 5, 2004 | 10:47 PM
  #1065
Only4ZQ's Avatar
Smile
No silly. He never said markers. You are the one that brought up the markers issue. Read his post again. He's asking about the side blinkers, the ones on the side mirrors.
edit: OK, never mind. You got it. Funny.
Old Nov 5, 2004 | 10:59 PM
  #1066
Here are the foglight instructions:
From 'patronus' at mbworld.org:
On the driver's side, you must replace the bulb from under the car. There is a panel just below the light. There is a seam between that panel and the one under the engine. Remove the screw between these two panels and fish your hand up through the crack (no need to remove the panels). You should feel the back of the bulb and.... Good luck!
to add to this, the bulb base twists 90 degrees then you pull out the bulb from the socket. replace the bulb and screw back in. its not hard, ive changed my fog light bulbs 2x so far. finally happy with the color.
here is a thread i started with instructions (under my pen name ) for removing the mirror housing.
https://mbworld.org/forums/c-class-w203/87118-mirror-removal.html
you must remove the housing in order to get to the indicators in the housing. two screws hold them in. indicators are plug and play for 2005 W203, W211 will require changing the plug from 4 prong to two.
hmm, maybe not though now, they got rid of the puddle light on the W211's i thought, so maybe it is just 2 prong plug. the 4 wires were: 2 to the puddle light bulb, and two to the LED's in the blinker.
not sure how many plugs they have now. mine had 4!
Old Nov 5, 2004 | 11:24 PM
  #1067
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Question Replace the whole fog light assy
Has anyone updated to the clear version of fog light assemblies? I tried to MBSD to do it, and they said "they are meant for only the C32; it won't fit on a C320."
Old Nov 5, 2004 | 11:33 PM
  #1068
yes, they can be changed out. steve does it all the time. the clear fog light installation will require the removal of the front bumper which can also be found on buellwinkles website!
http://www.buellwinkle.com/howtos.html
i bought my car at MBSD, some of those guys are but some are really good. contact Saprissa, he know's a part's guy at MBSD. also steve sells the foglights. youll probably get them cheaper from Steve.
Steve@MBenzNL.com
Old Nov 6, 2004 | 12:53 PM
  #1069
jaimedls's Avatar
thanks guys i am going to check all the information that i received.
Old Nov 8, 2004 | 01:53 PM
  #1070
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
CHATMANR,
at MBSD, here are the ONLY people who know what they're talking about... everyone else, worry !!
Sales: Martin Datnow & Robert Nadel
Parts: Duane & Chris
Service: Travis Cupples
Regarding the clear foglights, you really need to be specific with these guys when you ask them about stuff. They assume too much. For instance, the new 2005 clear foglights are meant for the new 2005 sedan body kit which happens to be identical to previous years C32 AMG kit, so they automatically say that it's only for a C32. In a way they are right, they won't fit the older style body kit. The 2004.5 and earlier clear foglights however will fit all regular C-class sedans just fine, and those are the ones you're after. They fit just fine, and are an easy install.
Carlos
Saprissa@aol.com
Old Nov 8, 2004 | 01:55 PM
  #1071
CHATMANR,
Robert Nadel is awesome!
Old Nov 8, 2004 | 03:23 PM
  #1072
Saprissa's Avatar
I was probably way too harsh, saying that you should "worry" about everyone else at MBSD. I haven't dealt with every single salesman there, so I'm sure there are more good guys/gals out on the floor.
But once again, I do HIGHLY recommend the names mentioned in the Parts & Service Departments.
Carlos
Saprissa@aol.com
Old Nov 9, 2004 | 12:39 PM
  #1073
JohnCL's Avatar
Bi-Xenon question
My next mod after my COMAND is going to be bi-xenons for my coupe and I was wondering if you can set the computer to bi-xenon=present before you install the lights. Will this work? I am having Steve do some mods later this month and will get the lights soon after. Any input would be appreciated.
Old Nov 9, 2004 | 12:56 PM
  #1074
jlm003's Avatar
2009 Porsche 911 Carrera S
Originally Posted by johncl
... I am having Steve do some mods later this month and will get the lights soon after.
There's your answer right there! If anyone show know, it's Steve.
Old Nov 9, 2004 | 01:05 PM
  #1075
respdoc's Avatar
CLS
If my memory serves me right, it's fine to preset them but do double check with Mr. NL just to make sure.
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
