Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Mar 7, 2008 | 03:47 AM
  #1951
yeuchau's Avatar
Stage 2 C7 A6, QX60
check DIY page for instructions
Old Mar 12, 2008 | 01:26 AM
  #1952
maecclass's Avatar
2005 C230 K and 2009 Smart
bi-xenon shutting off while driving.......
tried searching for related topics cant find any but my bix is flickering and high beam will flicker and now bix will shut off for a sec and come on again while driving. anybody have same experience and possible fix for problem
Old Mar 12, 2008 | 01:38 AM
  #1953
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
Hi bro, how you been? Sounds like a ballast or igniter issues.
Old Mar 12, 2008 | 01:54 AM
  #1954
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
+1 ballast is failing, have the dealer check it out or replace it
Old Mar 12, 2008 | 09:37 PM
  #1955
maecclass's Avatar
good, you? after saw the post called the dealer and have them check it out tom morning. Your car is looking good, and i really like the front lip and like the dual exhaust
Old Mar 12, 2008 | 09:38 PM
  #1956
maecclass's Avatar
i called my service guy and made appointment for tom morning thank you
Old Mar 12, 2008 | 11:19 PM
  #1957
SlvrC230SS's Avatar
I'm good. Thanks, man. Update us with the dealer's finding on the bix.
Old Mar 13, 2008 | 10:47 PM
  #1958
maecclass's Avatar
my service adviser told me that bulb was shorting out so the replaced the bulb i dont have my car back yet due to other stuff i had checked out so cant say if problem is solved
Old Mar 17, 2008 | 11:55 AM
  #1959
CaptV's Avatar
C230 Kompressor, 2003 1.8L
Peet,
if it ballast - it will be $50 if ignitor then $699 (full light assamly) becouse ignator inside of the light body and to change it you have to open it up, which is not easy and dealer won't mess up with it. You may ask someone in indishop if they can do it. I have similar problem with R light ( flicks but stays on). There is instrution how to do it on the forum. i need have look.
regards,
CaptV
Old Mar 30, 2008 | 12:18 AM
  #1960
powa's Avatar
C320 Coupe
Ok im stupid, how do i remove the cover to change my bulb for the Bi-xenon Headlight?
I can open the bi-xenon cover no problem on the driver side, but on the passenger side, the bi-xenon cover has a screw beneath the the adapter thingy on the cover, which is very hard to reach. Also i heard from a friend that it's a special mercedes screw that only mercedes can open the cover.
So question is, do i really have to remove the bumper to open the cover?
Is there an alternative way or what type of screw driver i could use to open it?
Old Mar 30, 2008 | 01:09 AM
  #1961
andy_meng1024's Avatar
2003 SL55, 2010 C63
I took my car to Goodyear and they changed the bulbs for me for $20
Old Mar 30, 2008 | 01:12 AM
  #1962
rlee02135's Avatar
2004 C32 ///AMG
sorry to tell you, but you got ripped off....it takes 2 minutes to change a bulb.
the black cover behind the lamp unclips, then twist off the connector and them twist off the ring holding the bulb in. reverse process, then you're done.
Old Mar 30, 2008 | 01:35 AM
  #1963
2003 SL55, 2010 C63
I tried myself but somehow just couldn't put it back on. So after I see they put it back on I think it was worthy tho.
Old Mar 30, 2008 | 02:18 AM
  #1964
coin's Avatar
'06 CLK500
Might take you a few minutes longer if it's your first time ...
Andy, changing bulbs should only cost you $7 at most, $20 is rip off
Old Mar 30, 2008 | 06:55 PM
  #1965
powa's Avatar
C320 Coupe
here is the pic of the screw that i need to unscrew before i can do anything, anyone have any idea how i can open it? i heard only mercedes dealership has the screwdriver of it
Attached Thumbnails Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread-p1030365.jpg
Old Mar 31, 2008 | 05:28 PM
  #1966
jchristian11's Avatar
2007 C230
That requires a torx head, not sure of the size though. Should be available at any auto parts store.
Old Mar 31, 2008 | 07:07 PM
  #1967
ChristianJan's Avatar
c230 Kompressor Coupe
It looks like a Torx screw. If you have a ratchet set, you should just fiddle with the different screws to see which one fits. It looks like it's a torx screw with a lot of treads (or whatever you call it).
Old Mar 31, 2008 | 07:50 PM
  #1968
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
my question is why the hell is there a screw there? both side should be a black snap-on cover that's easy to take off.
Old Mar 31, 2008 | 09:12 PM
  #1969
moosejaw's Avatar
none
Powa Did you xenon bulb go out?
Did it flcker on and off before it went. Mine just went out tonight. Where do you get a new bulb? Ebay?
Old Apr 1, 2008 | 11:14 AM
  #1970
hubertt's Avatar
BMW 520i, C180
Smile Easy
check at www.vvme.com
Old Apr 1, 2008 | 01:11 PM
  #1971
powa's Avatar
C320 Coupe
i just bought the bulb from a local auto shop (friend of mine). yes it flicker few times then turned off. Most likely it's the bulb's problem.
To answer FrankW, i donno, stupid coupe bi-xenon is different then? lol
Old Apr 8, 2008 | 10:27 AM
  #1972
powa's Avatar
C320 Coupe
Quick Help Please! Bi-xenon with aftermarket ballast
Need quick help immidiately! I bought 2 aftermarket ballast, now because one of my bi-xenon headlight ballast was gone, and i think might as well change both OEM ballast (which i think is a piece of crap) to aftermarket ones. Now question is, the power to the bi-xenon is from the battery of the car directly output into the bi-xenon whole set. Thus i need to do re-wire for the ballast itself. Will the light flash after i change to an aftermarket ballast? Note that I have already done xenon present programming.
Old Apr 8, 2008 | 12:51 PM
  #1973
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
The bi-x are made by Hella, why don't you just by the ballasts from Hella? I don't know the part numbers, but you could always call them to find out.
Old Apr 8, 2008 | 01:09 PM
  #1974
powa's Avatar
C320 Coupe
i already had one of my ballast replaced last year, and they are very expensive. Also you need to feed them with those expensive light bulb else they will die fast. I don't want to go for any of those OEM trouble anymore. So i decided to get aftermarket ballast, feed it with cheaper light bulb.
For example, if you have been eating great and expensive food for years, suddenly you eat some cheap foods, i can garrantee you will get food poisoning right away. Same deal with ballast and bulbs. Also, aftermarket ballast and bulb these days are made better reliability than the OEM parts now. See how reliable Honda and Toyota are versus MB and BMW
Old Apr 8, 2008 | 01:16 PM
  #1975
drexappeal's Avatar
Hella is a very reputable company and has been around for a long time. They also make aftermarket parts, so your statement is somewhat confusing.
I'm also confused what the ballast would have to do with the xenon bulb? Are you saying that you're thinking of changing the entire assembly (including the xenon bulb) to an aftermarket HID kit?
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
