Old Jun 10, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
DIY oil change, step by step, with pictures
Old Oct 3, 2010 | 03:56 PM
  #126
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Originally Posted by MBNA109
UPDATE - it a 76mm wrench.
Used the same 1 from my mazda3.
I just picked up a 75mm 14flute from O'Riley's (made by Pennzoil), and it seemed like a good tight fit, but when I tried to actually turn the filter housing cap with it, it just kept on jumping through flutes. So then I put a cotton rag between the wrench and the cap to try to tighten up the clearances, and at that point the top of the wrench (where the 3/8" socket is) just stripped since it's all made of plastic. Cheap crap. On the other hand, I wonder what kind of Hercules tightened this cap before? He must have used way more than 25 Nm of torque.
So, I extracted the oil (got about 8.2 qt out), but I'm unable to replace the filter. Can anyone recommend a high quality wrench?
If the 75mm wrench is too loose, I'm thinking a 76mm would be even worse. Plus, none of my local stores seem to carry a 76mm/14 flute wrench. The 76mm is 15mm and it does not fit at all.
Does the MB service department sell this type of a wrench?
Old Oct 3, 2010 | 07:01 PM
  #127
Pete7874's Avatar
FYI, I found this wrench that appears to be well made (steel) and possibly the right fit: 74.5mm, 14 flutes.
link
Anybody have one of these?
Old Oct 3, 2010 | 07:40 PM
  #128
ohlord's Avatar
I take a large
C- clamp and put the pads on opposite flats of the cap and gently
gentle twist of the clamp easily removes cap a gentle snug installs it when done.
Old Oct 3, 2010 | 08:10 PM
  #129
nyca's Avatar
advance auto parts, amongst others, sells the oil filter flute for this car.
I really can't see how it can be overtightened, there is a natural stop in it - and you will see a mark from the factory where the cap lines up with the base, so you know to turn and stop at that point - you don't really need a torque wrench.
Old Oct 3, 2010 | 09:47 PM
  #130
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Filter wrench
I have used a Hazet 2169 filter wrench on all my MBs with spin on filters and also on my Porsche for decades.
You can Google it or go to Ebay where one is advertised by ZDMAK Tools at 877-938-6657.
It is a bit more expensive than the Assenmacher tool previously mentioned.
Using the correct tools makes everything so much easier and low cost is not always your first choice.
Old Oct 3, 2010 | 10:54 PM
  #131
Pete7874's Avatar
Is it metal or plastic? The plastic ones just deform and skip.
Old Oct 4, 2010 | 03:23 PM
  #132
Benzo 003's Avatar
2008 ML350 4matic
You can try a large set of Channel Locks or even a pipe wrench for now until the right wrench/tool is found for the next time.
Old Oct 4, 2010 | 03:29 PM
  #133
Peabody's Avatar
Holy ****, your oil filter should not require a wrench at ALL. You do not need to apply more torque than hand tightened. maybe you need one to break it loose, but do not use it to tighten it back on!
Old Oct 4, 2010 | 04:42 PM
  #134
Pete7874's Avatar
Well, the recommended torque is 25 Nm, as written on the cap itself, alas, it looks like someone tightened it more than this.
Old Oct 4, 2010 | 05:23 PM
  #135
Pete7874's Avatar
I just ordered the Assenmacher tool. Hopefully I'll get it within a week, at which point I'll change the filter. Shouldn't be that big of a deal. I just hope the darn cap does not break on me.
Old Oct 5, 2010 | 02:13 AM
  #136
JimPap's Avatar
2008 C300 Sport, RWD, US
I didn't notice the marks you're describing. Will have to check in the morning.
Thanks for posting about this.
Old Oct 8, 2010 | 11:39 PM
  #137
Pete7874's Avatar
Update: the Assenmacher 2175 cap wrench did the job. Perfect fit and sturdy construction.
BTW, I did not see any marks on the cap nor base.
Old Oct 9, 2010 | 12:33 PM
  #138
aowhaus's Avatar
2008 C300 Sport 4matic
I wished I didn't give away my Mityvac before I moved.
I never tried it on my C, but it worked beautifully on my Passat -- best of all, there was very little mess, took very little time, and I know I will always have quality synthetic oil of my choice replaced everytime.
Old Oct 20, 2010 | 03:29 PM
  #139
Tartan43's Avatar
2016 Mercedes C300 4MATIC
Originally Posted by Tartan43
I changed the oil in my 2009 4Matic Sport this weekend using a Motive Power Extractor 1708 and the aluminum dipstick tube adapter from Fluid Evacuators (Part # PR381Q). Pressurized the extractor to approximately 12 in.Hg (see pic) and pulled 8qt of oil in 20-25 minutes before the pump started sputtering and the pressure dropped to 0. Not bad considering the oil soaked filter. Ignore the metal hose clamp in the second to last picture; I thought I would need to clamp the tube around the aluminum dipstick adapter to make it air tight, but the O ring on the tip of the adapter created an air tight seal with the tube.
Just performed my second oil change using the Motive Power Extractor 1708 and the aluminum dipstick tube adapter from Fluid Evacuators. Worked perfectly; pulled 8.5+ qt. (see pic)
Attached Thumbnails DIY oil change, step by step, with pictures-img00005-20101020-1244.jpg
Old Oct 21, 2010 | 10:44 PM
  #140
Pete7874's Avatar
Just curious, did you insert the plastic tubing all the way down the dipstick tube or just to the aluminum adapter?
Strangely, I pulled close to 8.5 qt but was only able to put in about 7.5 qt afterward before it read full on the dipstick. This leads me to believe that:
1) I did not get all of it out, and
2) The dealer overfilled the engine the last time the oil was changed - it may explain the occasional "check engine oil level" warnings I was getting sporadically.
Old Oct 22, 2010 | 04:48 PM
  #141
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
i am trying to get the aluminum dipstick tube adapter from Fluid Evacuators. How did you go about contacting these guys?
anywhere else i can order this from?
thanks
Old Oct 22, 2010 | 04:51 PM
  #142
Pete7874's Avatar
I just called them.
Old Oct 23, 2010 | 10:51 AM
  #143
Tartan43's Avatar
thanks
See http://www.fluidevacuators.com/mercedes.html for the product description. Call their number is at the bottom of their home page to order: http://www.fluidevacuators.com/
Old Oct 23, 2010 | 03:08 PM
  #144
moofish's Avatar
2010 c300 4matic sport 18"AMG SilverBullet
Hello everyone. 2010 c300 4matic sport owner / sorta newbie. I just did the service A oil change myself the old fashion way underneath. I used Mobile 1 0w40, changed the copper oil plug washer, MANN HU 718/5 X metal free filter.
Now my panic mode is setting in. Wife asked the dealer yesterday the oil capacity since I wasn't near a computer nor did I have my owner's manual. He stated 8.5qt. So Advance Auto is having an oil change special (5qt Mobile 1, Mobile 1 filter -- $32.99 no, didn't use the Mobile1 filter, bought it to fit the other vehicle). So, today I do the change, all is well. Drained, put 8.5qts in. I then measure the amount I got out. ~7.5qt. Run to owners manual at this point and find the 4matic sport takes 7.4qt. 1.1qt less than the regular c300 sport!!!!! Why would there be a different capacity for the 2? And do I need to pull the plug and drain out a quart or what? Will it harm the vehicle if I don't? I have an additional copper crush washer, so if I have to, I will pull out a quart.
Thanks for the advise in advance. I've been a longtime lurker on the forums and finally joined.
Old Oct 23, 2010 | 04:56 PM
  #145
Pete7874's Avatar
That's interesting. My 2008 owner's manual says 8.5qt for all models.
But the funny thing is, when I changed my oil, I was only able to put in about 7.5qt before it read full on the dipstick. However, I attributed it to the fact that maybe I did not extract all of the old oil out using my MityVac. But now I'm curious... Can you post a picture from your owner's manual where it does say that it only takes 7.4 qt?
EDIT: I just downloaded the 2010 owners manual, and you are right: it says 7.4 qt. Wow! I'm sure the M272 engine hasn't changed from 2008 to 2010. The values in 2008 owner's manual must be incorrect for the 4Matic. Now it makes sense why I was able to extract 8.5qt but was only able to put in 7.5qt. The previous oil change was done by the dealer, and it did look like the engine was overfilled judging by the dipstick. I am guessing dealer service dept doesn't know the correct quantity either. I am really surprised MB hasn't corrected these figures for earlier year models.
Thanks for bringing this to my attention.
Old Oct 23, 2010 | 05:28 PM
  #146
Pete7874's Avatar
Here is what moofish was talking about. This is from the 2010 owner's manual:
So, the 4Matic has a smaller engine oil capacity but larger auto trans capacity, by about 1 qt.
Old Oct 23, 2010 | 05:50 PM
  #147
moofish's Avatar
yeah, pretty weird. So what's the consensus about the overfill? Should I worry about it and draw a quart out or let it be? My wife drove it about 60 miles and didn't notice anything. No smoke, no dash alerts.
Im going to take a look at the dipstick level here in a few minutes. If it's within range, I'm calling it okay.
Old Oct 23, 2010 | 05:59 PM
  #148
Pete7874's Avatar
With 8.5qt of oil on board, I was getting an occasional "check oil level" warning on the dashboard. If you get it, I'd say drain some out.
Engine oil pan shape of the two is different. On the 4Matic models, the transmission oil pan takes up more space and thus encroaches on the engine oil pan space. Now it all makes sense.
Old Oct 23, 2010 | 06:12 PM
  #149
moofish's Avatar
Sounds like a plan. I just checked the level and it's right at the high mark on the dipstick. Slightly above actually. Okay, I'll just keep an eye on it. The manual says that the quantity of oil between lower and upper mark is approximately 2.1 qts. So if I wouldn't of followed the c300 (non 4m) I would of been dead on.
Just makes you kinda pucker a lil on a 40k+ car.
Old Oct 25, 2010 | 06:56 PM
  #150
RLE's Avatar
RLE
MB has always warned about overfilling on the older engines since the excess can be expelled out the rear main crankshaft seal. Read the warning on the oil filler cap. Looks like nothing has changed.
I think you should drain it all out into a clean container so that you can refill the correct amount. The correct level is anywhere between the two marks.
You have already rated this thread Rating: Thread Rating: 11 votes, 4.27 average.
