C-Class (W206) 2021 to
View Battery Voltage ?
Old May 16, 2025 | 12:48 PM
Steely's Avatar
C300 W206 2022
My car is driven about 5k miles/yr, almost daily but short distances 2-5miles per drive. It has been the same pattern over many years and cars. I am used to replacing batteries about every 4+ years. At the 2 ½ year mark in January I went on vacation for 3 weeks. Car sent me battery low warning, understandable. Displayed in car as well, went away once it was driven again. I just got another low battery warning a week ago in my app (not car). Now that warning is on the main screen of the MercedesMeh app all the time (does not indicate which date it is from). Car is running fine without warnings. Long story short, is there anything on the app or MSUX that shows battery voltage so I can keep an eye on it? The service screen does not show it.
Old May 16, 2025 | 02:40 PM
W205C43PFL's Avatar
Get in the workshop menu, you should also put vehicle in standby mode if not using it (parked in the garage).
Old May 16, 2025 | 02:41 PM
W205C43PFL's Avatar
Make sure: Hood, doors, trunk, windows all closed, ignition position 1, key in marked place, odometer screen and trip menu showing.
Old May 16, 2025 | 02:43 PM
W205C43PFL's Avatar
In the workshop menu, go to the first option available :Vehicle data (video timestamp 0:21)
As for standby mode, activate here: https://www.mbusa.com/en/owners/manu...-a-long-period
Old May 17, 2025 | 10:14 PM
streborx's Avatar
Top Answer: 1
G550
You can buy inexpensive battery voltage monitors that plug into your cig lighter socket for continuous monitoring.
Amazon Amazon
Old May 18, 2025 | 02:27 PM
W205C43PFL's Avatar
https://www.amazon.com/Charger-Adapt...22&sr=8-3&th=1
I just realized MB (non amg models as amg modles are replaced by something else I think it was the transmission temperature) have it available just from the infotainment, in the vehicle data or was it engine data screen. Some dashcams also shows the battery voltage like Thinkware.
Old May 19, 2025 | 09:38 AM
Steely's Avatar
C300 W206 2022
I went into the workshop menu and battery voltage showed around 12.6V. Car had been sitting for 24 hours.
When I started the car it jumped to 14.85V. What is Status? That fluctuated from 60 to 2,3 &4.
Old May 19, 2025 | 10:04 AM
streborx's Avatar
Top Answer: 1
G550
12.6 volts is the expected voltage level for a healthy charged battery. 14.85 volts is the charging voltage level output by the alternator, which will usually kick in after the battery starts the engine. Status? I have no idea.
Old May 19, 2025 | 03:47 PM
W205C43PFL's Avatar
Sounds about right, I would had thought "status" meant amp but doesn't make sense, 60 amps is impossible, does it have anything to do with the 48V mild hybrid battery?
Old May 19, 2025 | 03:48 PM
W205C43PFL's Avatar
It wouldn't have anything to do with the 48V mild hybrid battery right?
Old May 19, 2025 | 03:54 PM
streborx's Avatar
Top Answer: 1
G550
I am not blessed with a MH system in any of my cars, so I cannot speak to that. The Workshop menu is not documented in the owner's manual, and its contents are cryptic to a large extent. I would like to know more about the service codes displayed there.
Old May 19, 2025 | 03:59 PM
W205C43PFL's Avatar
I wonder if WIS will talk about it.
Old May 19, 2025 | 08:28 PM
Steely's Avatar
C300 W206 2022
There is a separate reading for amps, which is fluctuating between 18-20
Old May 19, 2025 | 10:26 PM
W205C43PFL's Avatar
That number is much more normal. Although a fully charged battery should drop down to single digits.
Old May 20, 2025 | 01:37 AM
streborx's Avatar
Top Answer: 1
G550
Maybe state of charge?
Old May 20, 2025 | 04:47 AM
Felix2024's Avatar
W206 C200 4Matic
No, 48V system has own screen in service menu. It shows current in negative and positive values, depending if battery is being charged or discharged.
Not really. It's not showing charging current, but generator current as far as i know, so includes current dranw by 12V systems. So 20A is not that high, as it's only ~240W of power, used by all conputers, sound system, lights etc.
Old May 20, 2025 | 09:32 AM
W205C43PFL's Avatar
True, but 48V mild hybrid battery doesn't go to 100% right? So we can confirm if that is it and see if the value stays within 100 and not go above.
Old May 20, 2025 | 09:35 AM
W205C43PFL's Avatar
I see, so the 48V system has its own screen.
Interesting, on W205 for example, that number does go down to like 1 to 2amps, they changed it for the W206? Here is an example of it going to down to 3.7A, are we talking about the same thing? the IB number? https://cimg2.ibsrv.net/gimg/www.mbw...fde15b1ac.jpeg
Here is an example of a W204: https://cimg5.ibsrv.net/gimg/www.mbw...eb07aaeccc.jpg
Old May 20, 2025 | 11:01 AM
Steely's Avatar
C300 W206 2022
Here is what I'm seeing
Old May 20, 2025 | 04:08 PM
W205C43PFL's Avatar
I see, thanks for the image.
Did you have a chance to check it after driving for 60 minutes on the highway or something? Or check it after fully trickle charging it? If you have a CTEK, you could use AGM float as well.
Old May 20, 2025 | 04:09 PM
W205C43PFL's Avatar
I am also thinking that since the voltage converter needs to assist with charging the 48V mild hybrid battery when engine is on, so since they have to charge two batteries, they prioritize the 48V mild hybrid battery, so the 12V battery never gets the attention it deserves. Unless I am missing something or a technical aspect of it?
Old May 20, 2025 | 07:01 PM
Steely's Avatar
C300 W206 2022
The previous image was with the engine running. I checked it today right after 20 minutes of Hwy Driving , with the engine off and it read (-)21.5A and 12.4 V. I will take one with it running next time.
Old May 20, 2025 | 07:23 PM
W205C43PFL's Avatar
Need to drive for at least 60 minutes on highway. Don't worry about it to be honest but fully charge should go down.
Old May 20, 2025 | 07:39 PM
Thekiller114's Avatar
c 300 w206
Mine has a fault code 22 what does it mean
Old May 20, 2025 | 07:43 PM
W205C43PFL's Avatar
Originally Posted by Thekiller114
Interesting yours say fault code the other forum member's say error code, does it change when the ignition and engine is on, I can see your engine is not on.
