C218 CLS63, 2011 - 2019
Driver’s Side Front Axle Creak/Squeak
Old Aug 28, 2021 | 11:24 PM
Kevhitch's Avatar
2014 CLS63 S AMG
I just picked up a 2014 CLS63 S AMG a couple of weeks ago, and I have noticed a squeaking/creaking noise coming from the front left axle. It occurs when entering/exiting the vehicle, while driving the vehicle, and if you just push down on the hood or rock the vehicle while it’s sitting. Anyone else experience this?
Old Aug 29, 2021 | 05:35 AM
decorily's Avatar
GLC 300d 4matic
Try lubricating the rubber bushings in the suspension and see if the noise stops.
Are you in a dry climate?
Old Aug 29, 2021 | 07:29 AM
Kevhitch's Avatar
2014 CLS63 S AMG
No, I’m in a very humid climate. The car has been owned primarily on the east coast, but I’m in the Ohio Valley region. I’m going to get the car on the rack tomorrow and get some lubricant on the bushings as that seems to be the consensus solution. Thanks!
Old Aug 29, 2021 | 10:02 PM
Rehabguy's Avatar
E63S
Sounds like the Cross Strut/Thrust Arm (Control arm) squeaks got someone else... Front End Squeak Discussion
Old Aug 29, 2021 | 10:17 PM
Kevhitch's Avatar
2014 CLS63 S AMG
Thanks for linking that other thread. I’ll mention the control arm bushings to the tech and see if he can get them replaced under warranty. If not, I’ll try lubricant first to see if that helps. If not, replacements will be ordered.
Old Aug 30, 2021 | 03:58 AM
leriksen's Avatar
2013 CLS63 AMG S
use a silicone/rubber grease, petroleum -based lubes will make the rubber swell and squeeze the metal harder, making the squeak worse.
Old Aug 30, 2021 | 04:34 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
I had a suspension creak for over 5 years. Long story, lots of drama. Not your problem. Car was always quiet after going through a car wash or on a rainy day, though.
In the end, the culprit was the left bushing on the front anti-sway bar. To diagnose, the tech disconnected the sway-bar link and drove the car. Noise gone. Sway bar replaced under warranty. Quiet now for months. . .
Bushings cannot be replaced without replacing the entire anti-sway bar. Not cheap on 4Matic cars due to labor required to change it, but the peace of mind would be worth the price to me.
Old Aug 30, 2021 | 06:07 PM
Kevhitch's Avatar
2014 CLS63 S AMG
Thankfully I have warranty coverage. My day was cut short and too hectic to have it checked out today, but I’ll get it on the rack tomorrow and hopefully get it fixed ASAP.
Old Sep 8, 2021 | 08:15 PM
drrckh1's Avatar
2015 CLS 63 totaled by drunk driver , 2018 E63s
I had this problem with my CLS63 and found it to be a bushing migration on one of the control arms. I could have pressed it back in but I just replaced the control arm. I wrote about it in one of my post. simple find and simple fix.
Old Sep 10, 2021 | 08:11 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Everyone gets this, it's your driver's side control arm. Mine had to be replaced on my CLS.
