Info on changing Transmission oil/filter and differential fluid
Old Nov 28, 2013 | 05:47 PM
Og Asr's Avatar
2008 CLS 63 amg
Can anybody point me to a link for transmission oil/filter diy service and differential fluid change?
I am at 36,000....and want to do this by my 40,000.
Also...what recommended ATF fluid have you used for the CLS63.
Any help would be great. I am trying to do this myself instead of paying the dealer $365.00.......
I know the oem gasket and filter for the tranny is $36.00....just not sure how many quarts of ATF to buy.
Thanks.
Old Nov 29, 2013 | 01:22 AM
Jawzey's Avatar
CLS55 AMG
I'd like to know information about this as well.
Old Nov 29, 2013 | 03:46 PM
06cls55amg's Avatar
06cls
search button is your friend , e55 is the same drive train as cls 55
https://mbworld.org/forums/w211-amg/...ion-flush.html
https://mbworld.org/forums/w211-amg/...need-help.html
https://mbworld.org/forums/w219/2615...-cls-55-a.html
Old Nov 29, 2013 | 05:01 PM
Jawzey's Avatar
CLS55 AMG
Thank you.
Old Nov 30, 2013 | 03:52 PM
Og Asr's Avatar
2008 CLS 63 amg
This is what I was looking for......we have the 722.9 transmission.......no dipstick...no locking cap.
Thanks.
https://mbworld.org/forums/c-class-w...ce-thread.html
Old Nov 30, 2013 | 04:48 PM
skeppa's Avatar
CLS 500
Thanks.
Correct me if I'm wrong, but that link is for the 7G-tronic. I know the CLS55 has the 5speed and I'm assuming the CLS63 does as well, so that link is not what you're looking for.
Old Nov 30, 2013 | 05:02 PM
Og Asr's Avatar
2008 CLS 63 amg
I just checked with the dealer...my 2008 CLS 63 is equipped with the 722.9 transmission....so for me...this link would work.
Old Nov 30, 2013 | 05:03 PM
Og Asr's Avatar
2008 CLS 63 amg
I have the 7-speed transmission.
Old Dec 5, 2013 | 07:04 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
I just changed the transmission fluid and filter on my 2006 cls55 amg and it does indeed have a five speed auto trans. Mine also had a garbage plastic pan that had warped and was leaking which prompted the change since it had lost enough fluid that it was not engaging properly so I ordered an OEM metal pan and its tight, no leaks and shifts perfectly.
Old Dec 5, 2013 | 10:41 PM
skeppa's Avatar
CLS 500
It seems like 2008+ AMGs have the 7-speed and anything before that is the 5-speed. Either that or the 2007+ AMGs all have the 7-speed.
Old Dec 9, 2013 | 03:32 PM
06cls55amg's Avatar
06cls
og asr has the 722.9 7 spd. https://mbworld.org/forums/clk-class...ion-drain.html, i think this is where you found your DIY as well
