can someone confirm that 255 35 20s will work on a et 25 front wheel
Old Mar 16, 2015 | 12:49 PM
06cls55amg's Avatar
06cls
need to order tires for the front, 255 35 20 are 27" od, 255 30s are 26.1" od.
i bent 2 of my old fronts on a 245 35 20 on my wonderful CT rds and would rather do a slight larger profile on my new wheels. i think the 245s were 26.7" od. car is lowered with star
Old Mar 16, 2015 | 02:37 PM
GuestFromTampa's Avatar
W212 E250 BT 4M
i am pretty sure you cannot go bigger then 245/35/20 if you will use search you will find alot of info and pictures regarding this .
Old Mar 16, 2015 | 04:33 PM
06cls55amg's Avatar
06cls
i did search, it seems like a gray area when it comes to 255 35 20, im not worried about ride height, i ran 245 35 20 with zero issue with clearance but still managed to bend the wheels on our ****ty rds. im worried that a lower profile is going make the ride harsher, and less meat on the tire to absorb the rds. that and my rears are 295 30 20 which around 27" od. I was hoping someone is maybe running a 255 35 20.
https://mbworld.org/forums/w219/5120...-20-rears.html
https://mbworld.org/forums/w219/4719...ear-cls55.html
https://mbworld.org/forums/cls-coupe...-rims-cls.html
https://mbworld.org/forums/cls-coupe...cls-front.html
Old Mar 16, 2015 | 08:10 PM
Manofsteelpt's Avatar
Veteran: Army
S63
Some say you can, some say no. I have a 245/35/20 on a 9" wheel. I don't like the look, my next set will be 265/30/20 I believe. I run a 295/30/20 in rear...
Old Mar 17, 2015 | 01:22 PM
06cls55amg's Avatar
06cls
i would keep a 245 35 20 tire but it wont cover the full width of the 9" wheel, hence why i am trying to stick with a 255 35 20. im just hoping it wont rub on the suspension for most part.
Old Mar 17, 2015 | 01:36 PM
Veteran: Army
S63
Right, the 245 is too stretched... Did you order the 255/35? Please lmk how they fit, I need new tires before the wheels go back on.
Old Mar 17, 2015 | 10:45 PM
W212 E250 BT 4M
From what i remember 255/35/20 will rub against suspension bolt.
Couple years back we had several forum members ( including myself ) who were getting ready to purchase 20 inch wheels so we did alot of research and agreed that 255/35/20 will not fit right because of the suspension bolt.
However you can try it and let as all know if it fits or doesn't
Old Mar 18, 2015 | 08:52 AM
Veteran: Army
S63
Sirboostalot's CLS had 255/35's as well as Maxwerks...
Old Mar 19, 2015 | 12:32 PM
06cls55amg's Avatar
06cls
i already ground down the suspension bolt, and re tapped so its almost flush from when i had wheels with spacers. so if thats the only issue i should be ok. ill be placing my order this week, will report back once i get these wheels and tires mounted,
Old Mar 19, 2015 | 10:28 PM
W212 E250 BT 4M
Can you take a picture ?
Old Mar 22, 2015 | 01:21 AM
Already's Avatar
E55/335i
How did this work out for you?
Old Mar 23, 2015 | 08:34 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I've had 255/35/20 on both my E55 and CLS55 for years. They never rubbed but I filed a few of the extra threads hanging off the upper ball joint anyways. IMO You want to have 6-7 mm clearance minimum because the tire will grow in diameter at high speed.
The E55 has a 20x9 with ET29 and CLS55 has 20x9 with ET25
