W219 CLS M113 to M113k
Decided to do a project car from the ground up, dissasembling and modifying pretty much everything that can be modified on this engine or this car in general.
Is there anyone who had encountered or custom ordered forged pistons/rods for a naturally aspired 5.0 M113 as I am trying to keep the original higher compression. The forged aftermarket pistons for an M113k are not an option due to a different stroke. Thanks
Any ideas what the peak hp for the amg rod is? want to know if i can go with the amg rod or custom H which is a lead time of 5+ weeks and dont feel like waiting.
that being said let me know if someone has the rods laying around somewhere either stock amg or custom ones.
Where I still think the weakest parts of this engine are the rods I can not neglect the question of pistons where I can not simply exchange them with the amg ones and do not know the stock m113 piston point of failure even though they are forged and making sure i run lean i have a bad feeling it wont be enough. Problem. Solutions?
https://mbworld.org/forums/w211-amg/...gine-swap.html
Here’s a couple posts that should help you out. The 5.0/5.4 NA block does perform pretty nice with a K blower and I’d definitely pick up the full AMG engine wiring harness first things first.
