Need help calculating...
Old Oct 17, 2007 | 10:52 AM
c32used's Avatar
LET C32 2002
Question Need help calculating...
Ok I know there are methods out there but none are known by me so I ask the forum for help. How do you calculate 0-60 times on a track slip?
Old Oct 17, 2007 | 11:49 AM
1FSTAMG's Avatar
C32 AMG - RIP :(
http://www.wallaceracing.com/0-60_equation.php
Old Oct 17, 2007 | 11:53 AM
c32used's Avatar
LET C32 2002
Originally Posted by 1FSTAMG
Thanks!!!!!
Old Oct 17, 2007 | 12:37 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Cool. I plugged in your times from your track day slip (#4) and it shows you had a 0-60 time of 4.81. Very nicely done.
Old Oct 17, 2007 | 12:41 PM
c32used's Avatar
LET C32 2002
that was with the K&N filter what about the Green filter result of 13.46@103? Did you use the weblink above or another service?
Old Oct 17, 2007 | 06:27 PM
ScottW911's Avatar
I used the link posted here and input the numbers for car #1 on the 4th slip.
Old Oct 17, 2007 | 07:16 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
why wouldn't you have used his fastest pass, which is the left hand side of slip #1? This one is 8.70@81.84 in the 1/8th. This shows a 0-60 time of 4.68 in the calculator.
Old Oct 17, 2007 | 08:34 PM
ScottW911's Avatar
Oops. I thought that 4 was the fastest from my initial read of that thread. I guess I need to look closer at the slips.
Geez, 4.68 is downright awesome for a stock C32.
Old Oct 17, 2007 | 09:11 PM
c32used's Avatar
LET C32 2002
Talking
Well using that link I got 4.68 to sixty with the K&N filters and 4.74 with the Green filters
Old Oct 17, 2007 | 09:22 PM
c32used's Avatar
LET C32 2002
Talking
Also I am car #4 in all the time slips provided. #1 is the stock W211 E55 belonging to ChicagoX #2 is a W210 modded E55 belonging to Samas #3 is a W203 modded C32 belonging to AMG-Jerry.
Old Oct 20, 2007 | 04:21 AM
ohlord's Avatar
Something
does not compute here.
almost 5/10 from an air filter?Oem filters have proven to flow more air and cleaner air then any k/n.So how would a car pick up nearly 50-60 h.p. by a simple filter change?Not to doubt your figures,but that would be like a short shot of juice.
ohlord
"GOT CODES?"
Old Oct 20, 2007 | 07:40 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
ohlord
"GOT CODES?"
I agree completely that it isn't what I expected (looks downright ) - but I believe he did runs with all three filters on the exact same day (so hopefully weather stayed fairly consistent and wasn't a factor), and the filters were the only "variable" changed in the car's setup.
If you had unlimited resources and really wanted to do a more scientific test, you'd probably have to do 15 runs, 5 with each filter, throw out the best and worst times for each and then average the other three - and when you're collecting the data, the driver shouldn't be aware of what filter is in the car on any of the runs. Then, to top it all off, do about 9 dyno runs (3 with each filter), and see if it supports the 1/4 mi times.
That being said, it'd be a hell of a lot of work, time & money, just to prove/disprove filter effectiveness - I applaud c32used's filter trials, because I for one wouldn't have put that kind of work into checking out filters, so he's certainly improved my knowledge with his results... strange as they may appear to be.
Old Oct 20, 2007 | 11:22 AM
c32used's Avatar
LET C32 2002
ohlord
"GOT CODES?"
Hey this thread was suppose to ask for help calculating the 0-60 times maybe you read my other thread but even so it only shows about a fifteen hp not 50-60
I took the two popular filters to the dyno and all three to the track so what better comparison right? Keep in mind the C32 already from factory comes with 349hp/333tq. By taking the filters to the track I simply proved factory filters for the C32 are more air restrictive so I am only coming out with track figures not hp figures on the last thread refering to the filters on the track that all. I am going by the feel of driving and numbers of the results.
Old Oct 20, 2007 | 11:48 AM
c32used's Avatar
LET C32 2002
Guy I am left speachless in the begining of this thread I said my car is stock and we ran each filter 3 times minimum each on a track but maybe I should have included that the track was rented from 9am-3pm and only four cars used it that day during the rented time. I did at least 8-12 runs in an hour and my friend did like 20+ runs through the entire rented time on my car#4 and different cars also. Keep in mind that the C32 with OEM filters is suppose to be capable of 4.9 and 13.5s quarters so don't know what the big fuss is aboutI am car #4 in the time slips any other is either car #1 W211 Wayne(ChicagoX) #2 W210 Samas #3 Modded C32 AMG-Jerry and me #4 stock C32. These figures are not altered in anyway and all are based off runs completed on my car #4 in some slips it shows another car but my run was purely for results not drag racing.
Old Oct 20, 2007 | 11:55 AM
c32used's Avatar
LET C32 2002
Maybe this will help:
https://mbworld.org/forums/c32-amg-c55-amg-w203/214404-track-results-k-n-greens-stock-filters.html
Old Oct 20, 2007 | 08:30 PM
c32AMG-DTM's Avatar
Hey sorry about the thread hijack - thanks for the link to the correct one!
Old Oct 22, 2007 | 09:01 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
It says that I have a 0-60 time of 4.07. Sounds too low, but I'll take it.
1/8 mile time 8.3481
1/8 mile speed 85.88
Old Oct 22, 2007 | 10:23 AM
c32used's Avatar
LET C32 2002
Thumbs up
Jerry with all the work you had done I can't see why its not possible. You were able to best or hang with E55 in prime conditions so don't feel doubtful imo.
