A turning point in Mercedes tuning...Performance Supercharger Pulley
Rating: Thread Rating: 15 votes, 5.00 average.
Old Jan 13, 2009 | 10:54 AM
  #801
jturkel's Avatar
02 C32 AMG
Originally Posted by Gramma_Benz
I thought IK16's were colder...
no.....i'm pretty sure they are colder. i would search the spark plug threads to double check that I am not giving incorrect information, but I am running out of the house for my medical school interview
Old Jan 13, 2009 | 02:56 PM
  #802
Gramma_Benz's Avatar
2002 C32, 2012 S550
You sir, are correct! From Denso's Website:
Q. Why are there different heat ranges? Which one should I use?
A. Part of your spark plug’s responsibilities, in addition to firing a spark, is to remove heat from the combustion chamber. This is accomplished by channeling the heat through the insulator material and metal housing. From there, the heat is transferred to the cylinder head where the engine cooling system can go to work. A spark plug’s heat range is its ability to dissipate heat. The “colder” the plug, the more heat it can channel out of the combustion chamber. In a performance application, colder heat ranges may be necessary to handle the extreme temperatures brought on by higher compression ratios, forced induction, and high RPM’s. While “Colder” plugs may seem to be the way to go, please remember that the spark plug must achieve its “self-cleaning” temperature where it can burn off fuel and carbon deposits. Otherwise, the plug could “foul out” where it is prone to misfiring and poor acceleration. A plug that is too “hot” can overheat, also causing power loss, detonation, pre-ignition, and possible engine damage. A good, general rule of thumb is to start with the factory recommended heat range. For every 75 to 100 hp you add to your engine, you may go to the next colder step. DENSO heat ranges move up as they get colder; 16 would be our hottest Iridium Power plug, 34 would be our coldest (ranges; 16,20,22,24,27,31,34)
Old Jan 14, 2009 | 12:32 PM
  #803
SilverBulletAMG's Avatar
C32 AMG
Any update on the C3P beltwrap?
Old Jan 14, 2009 | 07:54 PM
  #804
tyleryoung32's Avatar
2002 c32 AMG
Hey,
I am new to this site and looking for the best info on how to get some more extra poney out of my 02' C32. I have read all on this forum about the ASP, and the Code 3 pulleys? Also do you suggest a tune after the pulley? I am located in Utah, does that present a problem for tuning? Any good deals on pulleys on this forum? Thank you in advance for all your help.
Old Jan 14, 2009 | 09:30 PM
  #805
SRTpowa's Avatar
Srt-6 Crossfire
x2
Need more powa! Stacked pulleys would be nice.
Old Jan 17, 2009 | 06:57 AM
  #806
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
yeah any info on the mid size pulley that was originally plan? or the idea of duel pulley's been shelved?
Old Jan 17, 2009 | 03:01 PM
  #807
jturkel's Avatar
02 C32 AMG
check out the code3 website under the s/c pulley section....it has been updated with relevant information regarding this
Old Jan 17, 2009 | 11:14 PM
  #808
TemjinX2's Avatar
For those of you running 178mm crank pulleys, your power increase is finally here. In the next run of pulleys, we are also producing a mid-sized pulley that works in conjunction with your crank pulley, without the need for an injector upgrade. We tested this dual pulley setup for six months with great results. The power increase we saw on the dyno was +13/30 peak, +30/36 curve, all rear wheel numbers. That was power created over the 178mm dyno. We will have a new page up shortly for this product.
On the website it saids he's about to release a mid size pulley, but i assumed it was a old post, since there's no talk of it on any new threads.
Old Jan 27, 2009 | 02:46 PM
  #809
TemjinX2's Avatar
did anyone notice, code3 ninja posted there new mid size 178mm pulley?
http://shop.code3performance.com/pro...3&productId=22
anyone knows if you can run the new mid size pulley and sc pulley together without any problems?
Old Jan 27, 2009 | 03:16 PM
  #810
jturkel's Avatar
02 C32 AMG
yah, its been up for about two weeks
the mid-size pulley IS a supercharger pulley. it is just slightly larger than the current s/c pulley. its one or the other. the new midsize was made for people with 178s to safely run stacked without crazy tuning for fuel issues or upgrading the fuel system
Old Jan 27, 2009 | 03:17 PM
  #811
TemjinX2's Avatar
oh ic..is it the same as just running at 185?
Old Jan 27, 2009 | 03:18 PM
  #812
jturkel's Avatar
02 C32 AMG
i think it makes about 20psi before a tune. Brandon tells me it was made for those with 178s who want to run similar boost or make similar power....and apparently there are no fuel issues and A/F is nice. i think you might need the belt wrap kit for this.
Old Jan 27, 2009 | 03:25 PM
  #813
TemjinX2's Avatar
bah, i wish he just made a smaller crank pulley kit so those who bought the original code3 pulley can just upgrade.
Old Jan 27, 2009 | 03:46 PM
  #814
C32 AMG
I was in the same boat. I'm going 185 with tune.
Old Jan 27, 2009 | 03:49 PM
  #815
2002 C32, 2012 S550
I'm interested in the belt wrap kit, but it's not for sale yet apparently.
Jturkel, do you notice a big difference with it on? Any significant gains?
TIA!
Old Jan 27, 2009 | 03:52 PM
  #816
TemjinX2's Avatar
i still wish someone just came out with a turbo kit already..lol
Old Jan 27, 2009 | 04:39 PM
  #817
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
That's a pretty big conversion. Not to mention to make a fail-safe kit with no problems first time around is a hard task to achieve.
Old Jan 27, 2009 | 06:08 PM
  #818
jturkel's Avatar
02 C32 AMG
TIA!
I have not dyno'd with it. You can definitely feel a difference. Brandon estimates about 7-10whp or about .5 lb of boost. It helps eliminate belt slip and, somehow, the car seems to shift faster, particularly during WOT
what does TIA stand for?
Old Jan 27, 2009 | 06:39 PM
  #819
2002 C32, 2012 S550
Thanks in Advance.
Old Jan 31, 2009 | 12:32 PM
  #820
BLKFIN's Avatar
SRT-6
TIA!
Brandon emailed me the other day and said he would try to have the Belt Wrap Kit on the site in the next day or two. We will see~
Old Jan 31, 2009 | 06:39 PM
  #821
jturkel's Avatar
02 C32 AMG
i recommend it....it isnt a drastic difference, but you can definitely feel it pull harder throughout the entire powerband
Old Feb 3, 2009 | 09:46 PM
  #822
SRTpowa's Avatar
Srt-6 Crossfire
When will the mid sized pulley be available and is there any belt slip issues? I would love to pick one up.
Old Feb 3, 2009 | 09:50 PM
  #823
TemjinX2's Avatar
its already on there website.
Old Feb 13, 2009 | 04:55 PM
  #824
kevkranker's Avatar
C32
Good news !
The belt wrap kit is now on there website. http://shop.code3performance.com/pro...3&productId=23
I need to order one but I am waiting to get my boost and a/f gauges installed...
Old Feb 13, 2009 | 05:25 PM
  #825
jturkel's Avatar
02 C32 AMG
Originally Posted by kevkranker
Good news !
been driving with it for 2+ months! well worth it!
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
