R&D Update #5
R&D #3
R&D #4
Engine:
We are in the process of finalizing ODPS pulley design. Production has already started. ODPS will be available in mid December. Expect 20-25HP and 20-25 ft.lbs. of TQ at the wheels and more consistent car in warmer weather. (Please see dyno in R&D #4 post). Pricing will be finalized within a week.
We are evaluating several software upgrades from a number of different suppliers. As soon they make power as promised we will make upgrade available.
Y-splitter at the throttle body is the main restriction on factory air box. SL55/E55 splitter will fit. However, new hoses need to be fabricated as SL55/E55 hoses are different. We are in the process of making some. On my C32 I was able to make connection with some generic hoses, but it is not pretty.
I have some ideas for intake manifold that will add some TQ in a mid-range. Prototype will be tested shortly.
We've just completed headers for V8 engine. C32 is next. Seeing how small factory exhaust manifolds are, they are the same as C240 through E230, we can expect some decent gains (15-20HP). Headers will be CARB approved and will bolt on directly to factory H-pipe.
We have two different cam profiles coming from Germany. One is mild (+20 degrees) one is wild (+35 degrees). I will of course post the results.
Between components above IMHO we should get around 350-360HP at the wheels. Next step will require head porting, as exhaust port is fairly small and restrictive. A 3.7L upgrade is also a possibility, as MB switches over to new 3.7L engines.
SUSPENSION:
I have a new H&R coil-over kit (***) on my car. Love it. My old setup with just C320 H&R springs and stock AMG shocks worked well, until shocks started to wear out. Car ran OK on the track, but was jumpy and nervous on the street. *** when combined with our sway bar kit is solid and composed. I am constantly backing off gas pedal, as I find myself cruising at 100 +. There is also camber kit just released by H&R that I am going to add next week.
I am thinking of adding a front strut tower brace, although it will likely be more cosmetic, as W203 body is pretty stiff.
BRAKES:
Stock 13.6’’ brakes will handle quite a bit on the street. On the track, after about 5-6 laps they start to go away. Undoubtedly, a set of better pads will help. None are available, unless you go with custom made Portefields. Brembo is in the process of developing 14’’ front kit and 13’’ rear kit. Front kit will possibly use 8-piston caliper. I am taking my car in to Brembo for R&D by the end of the month.
BTW, we tried adapting SL55 8-piston caliper. Not enough room. It would of been nice from performance and appearance standpoint.
I'm looking for isolated impact, i.e, a dyno with your ODP and stock plugs vs ODP and cold plugs. Same with the Y-splitter.
SL55 splitter is worth about 3-5HP through out RPM range. The biggest difference is in "crispyness" of throttle response. I will look for the dyno graph.
Zeppelin: We use H&R kit, which is basically the same as Eibach. I should have ODPS by December 14th. Come to Fontana I will be there.
Do you think that the ODPS kit may be compatible with my mods (H&S ECU and BMC)?
Thanks,
Bye
Pierre32///AMG
SteveL: Colder plugs did not add any power. We used them to make sure that there were no misfires at higher boost levels.
A dyno graph would be great. Will you sell the hoses seperately? I assume that you would just order the SL55 splitter from MB parts or will you provide it as a kit including the splitter?
Steve: The plugs are NGK, one step colder. I do not have a part number in front of me, but any shop that sells NGKs can look them up for you.
Zeppelin: Yes, I will be in for drags at Fontana on 14th
Charlie: Expect my call very soon.
I live in Belgium and dont know if your engine kit is/will be available here (or in Germany).
Could you mail me an offer for your engine upgrade kit at >
bverotti@hotmail.com
I am still comparing prices and performance.
Thx in advance.
Give me couple of days to finalize things and I will e-mail you a quote, including shipping. Thanks.
As far as C320 upgrades. We have Underdrive Pulleys set that add 15HP in th first, 9HP in the second and 7HP in the 3rd. Cold Air intake, cams and software are in planning stages. Check in early next year.
Thanks.
Are you still the only shop addressing the higher temps as you increase pressure issue? Your IC improvements had some GREAT gains.
Are the other pulley manufacturers still missing that issue, or have some of the others finally come around to follow?
Anyway, can you see us sitting here trying to be patient like kids knowing Christmas is near?
Cheers everyone,
More power to the people!
The prototype "sixtopuss" is about ready. You will understand when you see the pics from under the hood. I got to go and pick it up from fabricators.
Two remaining pulleys to complete ODPS are at the platers. They are promising next week. You will definitely have it before Christmas:-)
