drag question
however, spinning the tires is important. Heating the tires will help maximize traction for your launch.
http://www.youtube.com/watch?v=tzY104e5VqE
Things did get better for me that day and I managed to complete the 1/4 mile in 12.52.
I left my car in reverse when the tree went green
I backed up bc i was over the line, the guy came to talk to me and i forgot all about it.
Second yellow goes and i Go backwards
However i still beat my freinds NA Cobra Vert
Nice one tire fire, though! Wow these cars need an LSD big time...
I have a Quaife lsd. Here is a video of my second best run that day (12.66)
http://www.youtube.com/watch?v=aerbO0SxCyU
RobAMG,
Here is a log file from the 12.66 run.
http://www.mediafire.com/?migzzvog21d
The outside temperature was just above 60*F. I have already made about 10 passes by then so my starting IAT was 104*F. During the run the IATs do go up to 156*F but are quickly down to 106*F -104*F. I have a split cooling system via a Code3 reservoir, PTE 180*F Tstat and a 10* fan mod. As Josh noted earlier, with the proper mods you should not have to worry about stressing the system for a short period of time since it will recover quickly. What are your cooling mods?
RobAMG,
Here's the painful truth, you nearly put a car with only 350whp into a wall while not even going that fast. Learn how to drive before you hurt yourself and/or others.
RobAMG,
LET 181mm pulley
NW Pulley Saver Kit
SL55 full intake with K&N filters
NW Oil Catch can
Code3 HE
Code3 Reservoir (separated cooling)
CM30
Eurocharged Headers
Supersprint exhaust, minus secondary cats, minus resonator
LET v1 tune
Quaife LSD
Bielstein PSS9
Toyo T1R rear tires
There are also other exterior, interior and electronics mods but they didn't get me to 12.52 1/4 mile.
Experienced tank slappers at the ‘strip and looped some of mine far worse on road courses.
Pure chance that no one posted my foibles on YouTube.
Appreciate you disclosing your Zeitronix data. Another respected and contributing member shared his as well.
Only hope the Mrs. clicked “checkout” on the link I conveniently sent her so one for mine is under the Christmas tree.
And the car does have an LSD.
