custom intercooler system
The market is just too small for any real company to make an honest effort at it, IMHO.
https://mbworld.org/forums/w211-amg/...ubes-what.html
Does it deliver what was promised?? What was promised by Brandon on this? I don't know, but it seems to work fine.
OT, the Code 3 cool can works very well and Brandon's HE is probably the best I have seen.
Does it deliver what was promised?? What was promised by Brandon on this? I don't know, but it seems to work fine.OT, the Code 3 cool can works very well and Brandon's HE is probably the best I have seen.
What was promised was a MUCH larger core, less pressure drop, ability to increase boost and still contain the IATs.
Thats all my friend.
I NEVER said it wasn't a good piece, I just said it did not live up to the hype/expectations
I had Brandon's very first HE and loved it. And yes it was an excellent piece that lived up to its expectations. Although it did not clear the headlight washers. Which was an easy fix.
https://mbworld.org/forums/c32-amg-c...eparation.html
whether or not it fits is a question only someone with a c32 can answer. what i was hoping to show you was that a larger than oem can be built for under 350$ and installed as a diy. you would need to measure the area in front of your radiator and then look thru jegs catalog for a rad that fits the dimensions. cut the inlet and outlet off weld them up and install tubes on the pass. side of the rad. a couple brackets and your golden!
I guess we could make some space BUT there is simply not a lot to work with. Our only alternative, and this has been explored in other posts, is to isolate the IC (as you did) and use the washer tank/other tank as a reservoir in the battery box area with battery in trunk. I've seen this done on other AMGs.
i want to reiterate that my supercooler may not fit your car but with some research im sure theres a rad that can be modded the way mine was that would fit and give more surface area to cool and allow for more fluid to be used. as theres no more c3 h/e and the ones on the market are only marginally bigger its worth looking into.
remember thicker isnt always better. a thinner(1") rad will allow air to pass quicker than a thicker core will. more surface area cooling is what you are shooting for. and just for clarity my supercooler is in front of my oem radiator on the grille side of the rad. support
if you look at post 46 i have a few pics of the h/e installed. you can see were the oem tubes were welded up and the new tubes welded in
https://mbworld.org/forums/w211-amg/...estions-2.html
16"t x 26"w 1" d
