c55 eurocharged ecu flash
Old Mar 29, 2011 | 09:58 PM
  #201
MIKESV8's Avatar
Aston Martin V8 Vantage
Originally Posted by loungn14
sorry it was a question not a statement as he posted that on facebook....
sorry was a question not a statement....i should have been more clear instead of using the ? guy pic....
Sorry, I was going off of what it said at the top of the sheet.the only people that would know are either jerry or vlad.
Old Mar 30, 2011 | 02:46 PM
  #202
mikekuriger's Avatar
2010 C63
did you get any runs in at the track or are you going tonight?
Old Mar 30, 2011 | 03:00 PM
  #203
MIKESV8's Avatar
I should be going tonight, just waiting on my friend to tell me he's free.i just got new rear ps2's
  #204
Newzchspy's Avatar
PLAID
Originally Posted by michael kuzni
+1 i think he'd be happy if anything though. he really wanted it to work, but had no idea it was possible. thanks robert.
Glenn has been on Spring Break in FL and this is my first log-in.
Yes Mike, I DID want it to work. Those are not C32 #s on a tune BUT I'd certainly take 20 RWHP if thats what you got!!!
Can I say I'm impressed? HMMMM..... Well, in fairness to Mike and Jerry, I had called Jerry about 2 weeks ago and had an idea as to what the results would be. Now it becomes an issue of, "would I pay $ XX.XX dollars for less than 20 RWHP. " I don't know. Its now a matter of cost/benefit analysis. If the flash is less than $ 400 bucks, I'd say it is. If its more than that, then a KN and a cat/ res delete and some exhaust work may get you the same benefit??
I am still wondering what the real A/F ratios are on this run?? Anyone get a "real read" on that?? Is it PIG Rich or lean and mean?? I don't know?? I know that the goal is to "lean it out a tad" to get some more HP, BUT what were the #s.
Also, why did you get bumped after two flashes??
Old Mar 30, 2011 | 03:10 PM
  #205
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by Newzchspy
[/U][/I][/B]
Can I say I'm impressed? HMMMM..... Well, in fairness to Mike and Jerry, I had called Jerry about 2 weeks ago and had an idea as to what the results would be. Now it becomes an issue of, "would I pay $ XX.XX dollars for less than 20 RWHP. " I don't know. Its now a matter of cost/benefit analysis. If the flash is less than $ 400 bucks, I'd say it is. If its more than that, then a KN and a res delete and some exhaust work may get you the same benefit??
shop was full so he got bumped....
we sare getting numbers for the shop for af...
cost of the flash- $399!
Old Mar 30, 2011 | 03:16 PM
  #206
Newzchspy's Avatar
PLAID
I'd jump all over that for less than $400 bucks!!!
Old Mar 30, 2011 | 03:27 PM
  #207
MIKESV8's Avatar
Glenn it's worth it! AND I haven't even done pedal reset yet.
Old Mar 30, 2011 | 10:07 PM
  #208
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Infineon wednesday night drags.
Bruton Smith’s SMI makeover of Sears Point is how any track ought to be properly managed.
Next time out, I’d suggest having a go on the road circuit.
Yours should be in the ~13.2 @ 108 (1.9x 60’) neighborhood. Good luck.
Old Mar 30, 2011 | 10:24 PM
  #209
MIKESV8's Avatar
Lol guess again, my best time so far is 16.2 at 100 even.I'm going to 22psi now since all I'm doing are burnouts.we'll see.oh and on my first time it went into limp mode and got 27
Old Mar 30, 2011 | 10:31 PM
  #210
MBfinatic's Avatar
e36 318i, 2004 sti
ouch.
16.2? should have raced my old c240
Old Mar 30, 2011 | 10:33 PM
  #211
MIKESV8's Avatar
I'm in elimination round now,i lowered my tires from 30 to 22psi and I dialed in at 14.5
Old Mar 30, 2011 | 10:49 PM
  #212
MIKESV8's Avatar
Still broke loose at 22psi. 14.5 at 102 was my best time. Damn torque
Old Mar 31, 2011 | 01:39 AM
  #213
splinter's Avatar
Super Moderator
Damn torque
14.5 @102. Stupid wheelspin
All due respect, Michael, that “damn torque” is your ticket to go much more quickly.
Even my pedestrian Michelin Pilot Sport A/S’s hooked enough to record 1.9x 60’ times.
Your 102-mph trap speed is a bit bewildering since a stock C32 or C55 will easily do 106+ as delivered.
There’s always next time. :y
Old Mar 31, 2011 | 01:45 AM
  #214
MIKESV8's Avatar
it was a great first time. but i know what i need to do differently for next time. oh well. no excuses. it was 90degrees out if that makes a difference. and my tires were about 4 hours old.
Old Mar 31, 2011 | 11:15 AM
  #215
C_DirtyTwo's Avatar
a land yacht.
the track prep can also be a factor. When I had a tune only (VRP tune only ~10whp) and some slight cooling mods I could barely break into the 13's with a 13.8x or something. Your 60' is where you get your e/t to improve but I could not hook up either, neither could my dad in his C55 with a similar time. Even getting 13.2 as advertised from the factory takes skill as well as ideal conditions
Old Mar 31, 2011 | 11:37 AM
  #216
dynomite05's Avatar
04 CLK 320 > CLK32K
Ouch, tough numbers. You planning another run anytime soon?
Old Mar 31, 2011 | 12:45 PM
  #217
2010 C63
most tracks are set up for slicks so street tires just slip and slide off the line. You can easily get 13's out on the boulevard on a saturday night, but it's hard at the track without drag radials at least. It's just not the right surface for your tires.
that being said, your MPH is very low. It looks like you're losing some HP somewhere. a custom tune that make the car feel peppier on the street doesn't always translate to the track like you'd expect. Dyno conditions are usually very controlled where on the track it's a crap shoot sometimes.
Old Mar 31, 2011 | 12:57 PM
  #218
MIKESV8's Avatar
put it this way, i had a passenger and i didn't really grip until 60'. i have a video of me getting sideways the first time i went actually. next time i'll deflate to 18 psi and baby it off the line. i'm not losing hp anywhere, i just suck at launching. i caught up to my friends e46 m3 who ran a 13.7 and i ran a 14.5 but i had a higher trap speed. i just got to get launch down. no big deal. summer is the next time i'll go, i have to focus more on school.
Old Mar 31, 2011 | 01:11 PM
  #219
loungn14's Avatar
SPONSOR
lol guys...his track slip says it all....
2.78 60' Hes spinning like a madman...
Old Mar 31, 2011 | 02:58 PM
  #220
MTLdude's Avatar
2005 CLK 55 AMG
The reading of the a/f was done at the tailpipe. For a wideband usually you have to have a bung 36" after the manifolds.
Might be really interested in that tune. It's just in time for spring!
Old Mar 31, 2011 | 03:10 PM
  #221
MTLdude's Avatar
2005 CLK 55 AMG
2.78 60' feet is terrible. Are you smoking the tires or what? Light em up! Seriously, you need a quaife to get the 60'. I Got one on order and with a tune i'm hopin for a 12.9999
We'll see about that! Don't stock c55 can run 13.5 without a problem?
Old Mar 31, 2011 | 03:47 PM
  #222
MIKESV8's Avatar
i did not want to ruin my 5 hour old tires so i didn't heat them up or anything. i'll post a pic of the ticket later on tonight unless jake beats me to it
Old Mar 31, 2011 | 04:05 PM
  #223
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
I did horrible my first time out and could only manage a 13.8 or 13.9. All I did was spin my tires. My 60' was my achilles heel. Practice is all it takes...
Old Mar 31, 2011 | 06:37 PM
  #224
MIKESV8's Avatar
Originally Posted by wawy
I did horrible my first time out and could only pull manage a 13.8 or 13.9. All I did was spin my tires. My 60' was my achilles heel. Practice is all it takes...
+1 on that. it sucks that i only had 3 tries to perfect it, but i got better every time. i'll get in the low 13's next time i'm out. this was also my first time actually really getting on it since the flash and new tires so i needed to get used to the power. might i add though, it was fun as hell!
Old Mar 31, 2011 | 06:47 PM
  #225
Gramma_Benz's Avatar
2002 C32, 2012 S550
BTW, I heard that Infineon has crappy track prep(hearsay) and that the Sacramento track is now where near as busy, so you can get a lot of runs in....
Maybe we can get a bunch of us to all go up someday??
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
