My New Project
Old Mar 13, 2012 | 04:28 PM
  #51
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
the E55 V8 would fit right in. i did mine.
http://www.crossfireforum.org/forum/...t=ultimate+mod
picture here.
Old Mar 13, 2012 | 05:09 PM
  #52
Robert AMG's Avatar
Cls63 & C32
picture here.
You installed the 55k engine in the crossfire srt6, but what i am doing is installing the 55 kompressor on the V6, plus converting the v6 3.2L to 3.7L and lowering compression ratio to 8.5 to make room for the 180-190mm crank pulley, i am starting by 178mm pulley as you can see from my previous picture (engine in the car).
Old Mar 13, 2012 | 05:13 PM
  #53
Robert AMG's Avatar
Cls63 & C32
Originally Posted by loudandheard
Couldn't read the compression in the video, did come out the same as your calculations?
yes sir. but the precise way to check the CR is the engine on the car with intake and TB.
Old Mar 13, 2012 | 05:18 PM
  #54
Robert AMG's Avatar
Cls63 & C32
The V8 will not fit on the C32, you have to swap the front of the car with C55 one or W209. it's an expensive project, to buy the 55k engine/transmission/diff with all ECU's plus convert the front of the car.
i went the easiest/cheapest way for me, i didn't touch any electrical component.
Old Mar 15, 2012 | 03:50 PM
  #55
70GS455's Avatar
1970 Buick GS 455
Originally Posted by Robert AMG
I think Eurocharged made only 3 to 5 long tube headers before they stopped production of them.
video when checking compression ratio:
To clarify, you are checking cranking pressure (psi, atm, bar, etc) , not (static) compression ratio (y:x)
And there is a dynamic (or effective) compression ratio, which takes into account the effect of the closing of the intake valve on mechanical (static) compression ratio.
Old Mar 18, 2012 | 05:45 AM
  #56
Robert AMG's Avatar
Cls63 & C32
+1, but i don't want to enter in the cam degrees and valve closing calculations, i have lowered the static CR, then i'll compare cranking CR with another car wich have same degree cam like E55K with the same gauge.
Old Mar 18, 2012 | 06:18 AM
  #57
Robert AMG's Avatar
Cls63 & C32
Old Mar 19, 2012 | 02:14 AM
  #58
MIKESV8's Avatar
Aston Martin V8 Vantage
http://www.youtube.com/watch?v=WNZLCA2_8uQ
what's wrong with the ratio? i heard someone at the end say in arabic "something is wrong here"
Old Mar 19, 2012 | 02:33 PM
  #59
Robert AMG's Avatar
Cls63 & C32
Nothing wrong, he thought it was at first, cause you need to make a lot of cranking to make oil go into heads.
Old Mar 20, 2012 | 12:50 AM
  #60
Kinghorn26's Avatar
02 C32
Awesome build!! Glad to see someone stepping away from the norm. Good luck!
Old Mar 20, 2012 | 12:58 AM
  #61
C_DirtyTwo's Avatar
a land yacht.
in for results!
Old Mar 20, 2012 | 02:53 AM
  #62
dre5373's Avatar
2006 C55, 1995 C36
Damn Kuzni, you speak Arabic?!?
Robert AMG, your build is awesome, thanks sharing with us!
Old Mar 20, 2012 | 03:23 AM
  #63
MIKESV8's Avatar
one of many languages my friend.
hey robert, if i end up going back to lebanon this summer, do you think we could meet up and i check out the car? the country itself takes 3 hours to cross as a whole so depending where you are, i'm not too concerned on time
Old Mar 21, 2012 | 05:50 PM
  #64
Robert AMG's Avatar
Cls63 & C32
Call me when you'll be here (03/523899), i live in north Lebanon, Zgharta, but we can meet in Beirut.
Old Mar 21, 2012 | 08:30 PM
  #65
loudandheard's Avatar
C32/C55 AMG
Looking good, but that picture confuses me. What about the large hole above the throttle body hole, do just cover it up?
Old Mar 21, 2012 | 08:47 PM
  #66
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
sounds like fun.
Old Mar 22, 2012 | 02:01 PM
  #67
Robert AMG's Avatar
Cls63 & C32
This is the 55 SC inlet where the other hole is for bypass tb, today i cut/weld it, no bypass tb in my built.
Old Mar 26, 2012 | 02:10 PM
  #68
Robert AMG's Avatar
Cls63 & C32
Old Mar 26, 2012 | 03:06 PM
  #69
C32/C55 AMG
That's going to look awesome. Are you going to use the E55k intake or do you have something better? Do you think the transmission or rear end will have any issues with the added hp?
Old Mar 26, 2012 | 03:19 PM
  #70
Robert AMG's Avatar
Cls63 & C32
there is no place in the rear (firewall) to put the y pipe so no 55 intake and also to make room for top mount ic, maybe i'll put a foam filter directly on the tb, but i am concerned about heat in the engine bay, i'll see.
i don't think the c32 transmission will handle the new hp/tq, i have found an used 55k transmission at about 1200$, i will buy it.
Old Mar 26, 2012 | 03:24 PM
  #71
C32/C55 AMG
Be careful with the axles and driveshaft, hopefully they can with stand the added hp. I think PTE's supercharged clk55 twisted an axle and I remember the reading about the E55 converted to a 65 twisted the driveshaft, but he added a huge amount of torque to the car, so you might be ok there. If only we could drop in the complete rear end of an E55.
Old Mar 26, 2012 | 03:42 PM
  #72
Robert AMG's Avatar
Cls63 & C32
you'r right, but first i wanna start the engine and check everything ok then i'll see. the drag radials and sticky track play a big role on those issues.
Old Mar 26, 2012 | 04:15 PM
  #73
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
+1 to both. I snapped my axle at the track using drag radials at 14 PSI. And my car (although fast) is not nearly the beast as what Robert is building. Thanks to dodger for landing me his "tow truck".
There is a promising axle related thread in the 211 AMG section.
Old Mar 26, 2012 | 04:29 PM
  #74
Robert AMG's Avatar
Cls63 & C32
14psi!!! oh yes i remember you're chasing the record
Old Mar 26, 2012 | 04:51 PM
  #75
Lenin's Avatar
Seems like I have more luck chasing girls than records. It was dodger who kept me going that day.
