AMS Pulley Install
Just rang MB dealership for a labour quote to get an idea of price to save me from doing it myself. They DON'T list any working times in their system, so they gave me a 3 hour quote which came from an MB workshop technician as he has done V8's in the past something about "there is not much room to work on these engines"? ............................£370 what the F%@#! but they agreed if it took longer they would not charge me extra......... great!
I did the viscous fan coupling the other month using the correct tool with no problems of space, I have not had time to look yet but there must be loads of room underneath to get to the pulley bolt with a lever bar?
Questions if anyone can help please, so I have peace of mind as always when I do the work myself:
1. Where is the tensioner/release located (is there any special tool required)?
2. There are timing marks on the new pulley, but a section is cut out inside to locate I asume, so its seems that it is straight of and straight on job?
3. Any tips if I find it difficult to remove the crank bolt, please guys no hammer hitting suggestions I know that one already..... it sometimes makes things worse.
That is a total load of crap. They are trying to squeeze $$ out of you. The pulley should be 1.5 hours of labor TOPS! In America it usually costs $150 USD or less and thats at the dealership. If you do it elsewhere it can be even less. It sounds like the $tealer is trying to get more $$ out of you. There is plenty of room to do the Crank pulley on the C43. The C36 crank pulley is the one that is a bit more difficult and requires slightly more labor (roughly 2.5 hours) but the C43 is literally one bolt, and the pulley just slides in & out freely with no obstruction.
I know for a fact in US its 1.5 hours and it IS listed in the book that thats a load of crap if they say its not in the book. I hate $tealers that think b/c their customers own mercedes that gives them the right to scre them out of their money. Hopefully you can resolve the situation, if not try and find a reputable mercedes independent shop.
I am really looking forward to seeing if there is any difference. I removed the secondary cats and center silencer recently and that has made a difference, will probably get ecu done also after the pulley and maybe a sprint booster for the throttle? I want to really see what this car a capable of without super charging, which I think is a bit ridiculous for the cost in the uk...
Please tell me how to release the tensioner in the correct way, I want to do it myself as I have done everything that I could.
We put it on the ramp and took off the engine cover, fan, viscous, fan belt and under tray, which took 15mins.
UNFORTUNATELY for the next 2 hours we broke a couple of breaker bar socket adaptors and sweated a lot....... with no results...............................
We used a chain grip pulley clamp to stop the pulley from rotating and at one point there were two guys including myself (my weight is about 90kg) on the breaker bar and two on the pulley clamp ...........but we were slipping and felt the breaker bar flexing......we even lowered the weight of the car on the floor against the pulley clamp and tried from the top of the engine, in the end we stopped altogether due to getting worried about shearing the bolt off and having a more serious problem!!!!!!!!
He suggested heating it up with a blow torch but we agreed it was a little risky. I might take the radiators so we can get the air gun on it, but I really feel to just leave it.
Does anyone want to buy the parts off me....... I will post to anyone in the UK for £300 delivered?
I really wanted it installed on the car and give the forum feedback information ,,,,,,,,but I get put off when something simple becomes complicated
Maybe we just don't know what we were doing it so complicated, maybe we are dumb and should have been trying to undo the pulley nut clockwise instead of anti-clockwise?
If I could get the bolt off straight away it would have only taken 30mins!
The prongs lock into the spokes of the pulley wheel, and the arm sits on the frame.
Jeff
Jeff
After reading the pulley thread that has recently been closed I thought this wouldn't sound strange as there seems to be a 50/50 mix of realistic and unrealistic people that need to come back to reality. Fortunately my car is not a priority over my life and health......Its more important I don't break down as its more difficult to fix me.
I have booked it in to have the pulley changed next weekend. Could any realistic people that have had this installed on their C43 please quote from
experience so that I can compare with mine, PLEASE I would appreciate it that people do not give their opinion if they have not 'FACT' changed to an AMS pulley on their car as this will be useless information.
https://mbworld.org/forums/showthrea...ght=pulley+ams
hey bud can you show some pictures of the engine bay, how it looks like inside with the AMS pulley
cheers.
I am still really disapointed,,,,,,,,,,,,,,,,,,,,,,I took the car to another local mercedes specialist workshop last weekend and an ex MB tech tried to get the old pulley off, with the proper locking tool and an extended breaker bar (YES 6ft).
Unfortunately he also broke his breaker bar at the knuckle end which snapped clean off, he didn't charge me for the half hours work or his bar. He said if I still really wanted it taken off he would have to use a stronger/bigger bar which to get into the engine bay he would need to remove the radiator/fans/air con radiator etc. 4+ hrs labour and would need a re-gas and coolent and thats was if only if nothing gets broken when dismantling, like the air con rad pipes conections as he said they could be siezed/damage threads?
So I went home that day with the same feeling, but worse than the last time ...........this is one stupid and tough old bolt.........looks like I will go to the main dealer with this one but can't see them having any different tools. I hope this doesn't end up F@*%ing up my crank or having the bolt snap inside!
