NEED HELP ASAP!!!!!!
Old Mar 18, 2009 | 10:43 AM
tristantiojanco's Avatar
1998 c43
this thing started yesterday and it happened to me twice; before i went to the dealership my car's tranny wont shift up it gets stuck on second gear so i pulled over and turn off the engine and then after a few second i start it and run and shift like a champ without any hesitation, so i took it for a tranny service filter, fluid etc etc, after the service was completed they test drove it still ran like a champ, i told the mechanic what happened to me earlier and he did hooked it up to a code reader and gave him a transmission code saying to check the SPEED SENSOR, he said; just observe the car if it will act up again, so i drove off the dealership and after driving for about 3 miles it did happened to me again and just turned of the engine and the car ran like a champ again...did this thing happened to anybody??? coz im 99% sure its not my tranny coz after i shut off the engine and turn it back on it just ran and shift like brand new, did anybody changed their SPEED SENSOR...PLS HELP I DONT WANT MY CLEAN C43 TO DIE ON ME!!!!...THANX IN ADVANCE
Old Mar 18, 2009 | 01:24 PM
AMGjamesC43's Avatar
1999 C43 ///AMG
How many miles are on the car? Mine started doing this to me around 85,000 i eventually had to replace the transmission computer and wiring harness. hope it isnt the same problem.
Good luck!
Old Mar 18, 2009 | 01:29 PM
1998 c43
Good luck!
103K..how long it acted this way until u eventually changed the tranny, i have to i better trade this car today!!
Old Mar 18, 2009 | 01:30 PM
1998 c43
Good luck!
just the tranny computer and harness right??? not the actual tranny...and how much$$$$$
Old Mar 18, 2009 | 03:05 PM
JonMBZ's Avatar
06 C55, 09 E350
The electronics in the valve gear go out quite often, for that you are looking at $246 and the cable harness is $187.00
Old Mar 18, 2009 | 03:13 PM
1998 c43
thanx for the info...i wanna know where is this part located?? like what i said after i shut off the engine it gets out of the limp mode and back on the road running like a champ, shifting like brand new...so its DEFINITELY not my TRANNY..
Old Mar 23, 2009 | 01:34 PM
john89011's Avatar
MB C32 AMG
sounds like a speed sensor to me and would probably be your cheapest fix no?
Old Mar 23, 2009 | 02:01 PM
1999 C43 ///AMG
The computer and harness along with labor and misc. parts was about $1400. Not cheap. You def. want to have it checked out throughly because a cheap fix now means more $$$$ down the road. But like i said i hope that this is not the issue. Keep us updated.
Old Mar 23, 2009 | 08:01 PM
MarcusF's Avatar
2002 CLK430
You need a speed sensor and they determined this AFTER the transmission service? They have to replace about 5 quarts of fluid to change the sensor. You may want want to ask about a price reduction because they really should have caught this beforehand.
I had a P0715 code last year. That's the speed sensor failure code. I had the same symptoms. I don’t think they can tell you whether it’s the speed sensor or the plate that it sits on until they remove the plate. The plate is in the transmission, and that's why you're going to lose 5 quarts of fluid. To get to the sensor, they drop the pan, pull the filter, remove the valve body, and then remove the plate. At that point they can test the sensor and check the plate. In my case, the plate was cracked. That resulted in a bad signal from the sensor.
They replaced the plate and did the infamous "transmission wiring harness o-ring job". My o-ring wasn't leaking, but it's a $2 o-ring, and they were right there, so it made sense to do it. The total bill was about $800. I have a parts list if you're interested.
Old Mar 24, 2009 | 10:48 AM
1998 c43
yes sir can u pls send me the parts list...i appreciate your help...for some strange reason it never happened again to my car, im crossing my fingers on this one..
Old Mar 24, 2009 | 11:22 PM
MarcusF's Avatar
2002 CLK430
electronics kit (plate), part number 140-270-08-61 - $223.45
transmission pan gasket, part number 140-271-00-80 - $12.00
seal ring, part number 140-271-00-60 - $2.09
transmission fluid, part number 001-989-21-03-10 - 5 @ $14.50 each
Transmission oil filter, part number 140-277-00-95 - $15.50
Lock pin, part number 140-991-00-55 - $1.69
Spacer, part number 203-540-02-53 - $11.02
Old Mar 25, 2009 | 10:40 AM
1998 c43
thanx a lot sir!!!!
Old Apr 2, 2009 | 11:54 AM
1998 c43
is there any reputable shop that can do this valve body job in southern california? i called some MBZ shop they said they dont wanna touch it..
Old Apr 2, 2009 | 12:06 PM
JonMBZ's Avatar
06 C55, 09 E350
What dealer did you call? I can't imagine anyone turning down a simple repair like this. You can call ARA@ 562-804-4679 he's a master MB tech for many years.
Old Apr 2, 2009 | 12:56 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
what part of socal? i have a tech i use in west LA. let me know and ill pass on the info.
Old Apr 2, 2009 | 01:59 PM
Carcrazy1's Avatar
Volkswagan
The transmission system has a problem, get it maintained
Old Apr 2, 2009 | 03:04 PM
1998 c43
i live in the inland empire but im willing to drive just to get this problem solved..thanx
Old Apr 2, 2009 | 03:07 PM
1998 c43
penske in west covina..i called one MBZ shop and he said i could do it for $700 parts and labor..is that sound right??? or he said he can have the computer re-learn the tranny for $100...does it sound right?? it only goes to LIMP MODE at least once in a blue moon n just pull over to turn off the car and start it again and run like a champ..no check engine or what so ever...thanks
Old Apr 2, 2009 | 03:09 PM
1998 c43
i dont think its the actual tranny coz it only goes to limp mode once in a blue mood all i have to do is turn off the ignition then after a minute turn it back on, it runs and shift like a champ...just did the tranny service 2 weeks ago, fluid,gasket and filter..
Old Apr 3, 2009 | 12:01 AM
MarcusF's Avatar
2002 CLK430
Call Walter's MB. Tell them to give you the Cayman loaner.
Old Apr 3, 2009 | 10:08 AM
ohlord's Avatar
P0715
can be triggered by the leaking o ring and fluid leaking up to the tcu.
Go to the w210 forum on benzworld and follow the diy r/r get the parts about 20 bucks and clean the harness with tuner cleaner and replace the fitting.You more often than not have fluid in there and not a bad sensor or plate.
722.6 transmissions are known for this problem.
Old Apr 7, 2009 | 01:33 PM
1998 c43
i cant find it on the w210 forum..can u pls help me out here its getting annoying for this LIMP MODE kicking in all the time
Old Apr 7, 2009 | 09:00 PM
JonMBZ's Avatar
06 C55, 09 E350
Not really sure what's required installation wise, I would give ara a call first and just mention I (Jonathan) recommended you and he should take care of you. If you have any more questions just shoot me a pm.
Old Apr 8, 2009 | 02:24 AM
jnolte's Avatar
744 C36 AMG,040 C43 AMG, CLK55 208, CLS55 IWC, CLK500 Rocketbunny widebody
700 for valve body is good, 100 for the tranny re learn... wtf is that?
Old Apr 8, 2009 | 11:31 AM
1998 c43
yes sir!!! i already have an appointment next wednesday to leave my car in the shop to have the tranny open and make sure its the valve body coz he said it could just be a little sensor or something small...hopefully!!!!!!! so i will keep you guys updated on this...about the RE-LEARN i had him do it for free and see if anything change but after he reset everything or after the so called re-learn my car ran like and shift like a brand spanking new..enjoyed it for 3 days then it went to LIMP MODE again...i gotta get this TRANNY, LIMP MODE thing off my car.....
