changing the oil myself on the C43, questions.
Old Apr 27, 2009 | 06:48 PM
SL-ML-C's Avatar
2000 MR-S daily driver, 1997 SL600 weekend fun, 1999 ML430 tow vehicle
hello all,
I have owned my C43 for 3 years now, and I change the oil on most of my other cars, I am just checking to see if there is anything special to know on this particular car,
Thanks,
Erik
Old Apr 28, 2009 | 07:44 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Pretty straight forward. Four bolts hold in the undertray cover, so remove those and then it has some plastic snaps. I don't remember the sizes off the top of my head, but either a 14mm or 17mm on the drain plug. When you pick up a filter, some dealerships will give you a new drain plug washer, others won't. I would ask for one if they don't give you one. I think it is a good idea to replace that. Refit the drain plug and the cover. Oil filter housing is in the engine on the front right corner when viewing the engine from the front. I just use an oil filter band wrench to open it. The oil filter slides on and off, might seem hard to get off at first, but you may just have to twist it a little while you pull. There are four O-Rings on the filter assembly that can be replaced and should come in the filter box. I always get five in the box but I only see four on the assembly, so maybe I am missing something. Anyways, slide new filter on and put the filter assembly back in. Eight quarts of oil and you are good to go.
Old Apr 28, 2009 | 09:00 AM
Vardar's Avatar
1999 C43
I have used oil extractor, so i have nothing to do with the bottom of the vehicle while changing oil. I have done it about 5-6 times, no problems...
Here is the link
Good luck
Old Apr 28, 2009 | 10:06 AM
NitrogenBalance's Avatar
none
As Vardar said, go to pep boys and buy a $50ish oil extractor. Very clever way of doing it without having to hit the ground or even use two hands. I jokingly(sp?) once did it with a beer in my hand almost the whole time. You just pull the dipstick and losen the oil fill cap. 10 min later and a filter change and your done.
Old Apr 28, 2009 | 09:37 PM
SL-ML-C's Avatar
I change the oil on so many cars, and I have a lift in my garage, so getting dirty and under the car is not a problem - I was just concerned that the M113 engine didn't have a drain plug and required a Topsider to perform the change.
Thanks a bunch!
-Erik
Old Apr 29, 2009 | 03:01 AM
ohlord's Avatar
go out the top
the angle of the engine and drain plug placement make it better to evac than to drain.Electric pumps to suck it out I have for 45 bucks.
Fleece filter autohausaz.com about 12 bucks,mobil1 ow40 become a mobil club member get two rebates for 10 qts 2 bucks off per bottle.
Diy on www.mercedesshop.com resource section diy articles diy oil change #2
Takes all of 10 minutes and you are done with never leaving the ground.
Old Apr 29, 2009 | 04:25 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
That's a good look!
Old Apr 29, 2009 | 05:26 PM
SL-ML-C's Avatar
well I have no doubt its easier, but I really dont see the need to go spend money I dont need to spend when I have the tools I have...
as long as doing it 'the old fashioned way' isnt going to hurt anything, I'm going that route!
cant believe the darn thing takes 8 quarts! that's almost as much as my 87 190TurboDiesel.
Old Apr 29, 2009 | 07:43 PM
M-bENZ's Avatar
Corrolla
Fleece filter autohausaz.com about 12 bucks,mobil1 ow40 become a mobil club member get two rebates for 10 qts 2 bucks off per bottle.Diy on www.mercedesshop.com resource section diy articles diy oil change #2
Where did u buy that after u registered?
Andy
Old May 13, 2009 | 07:12 PM
Vicious_c43's Avatar
'98 AMG C43 / '70 Cougar
Oil filter wrench for the C43 anyone know the size or part # for this tool?
